查看: 3577|回復: 2
16*64漢字點陣顯示仿真原理圖+單片機代碼
新人發帖
  1. #include <REGX51.H>
  2. #include <INIT.H>
  3. /************漢字點陣*************/
  4. uchar code        hanzi[4][32] =                                         //一個漢字分兩行,所以數組二維數為字數的兩倍
  5. {0x02,0x00,0x01,0x00,0x01,0x00,0xff,0xfe,0x08,0x20,0x08,0x20,0x08,0x20,0x04,0x40,
  6. 0x04,0x40,0x02,0x80,0x01,0x00,0x02,0x80,0x04,0x60,0x18,0x1e,0xe0,0x08,0x00,0x00
  7. },        //"文",0
  8. {0x08,0x80,0x0c,0xc0,0x09,0x88,0x12,0x3c,0x17,0xe6,0x31,0x14,0x52,0x08,0x95,0x04,
  9. 0x19,0xf8,0x11,0x10,0x12,0x90,0x14,0xa0,0x10,0x60,0x11,0x98,0x16,0x06,0x00,0x00
  10. },        //"俊",1
  11. {00x24,0x04,0x34,0x04,0x24,0x24,0x3f,0xa4,0x44,0x24,0x04,0x24,0x7f,0xa4,0x04,0x24,
  12. 0x3f,0xa4,0x24,0xa4,0x24,0xa4,0x24,0xa4,0x24,0x84,0x27,0x84,0x05,0x14,0x04,0x08
  13. },        //"制",2
  14. {0x08,0x80,0x0c,0x80,0x09,0x00,0x13,0xfe,0x12,0x80,0x34,0x88,0x50,0xfc,0x90,0x80,
  15. 0x10,0x80,0x10,0x84,0x10,0xfe,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80
  16. }        //"作",3
  17. };
  18. /************位定義**************/
  19. sbit STTP = P2^7;
  20. /************變量聲明***********/
  21. uint n,i,j;                        //delay()延時函數計數變量
  22. uint x,y,z;                        //out_hanzi()
  23. /************函數聲明***********/
  24. void        delay(uint n);                        //延時函數
  25. void        out_rxd(uchar *d);                                //漢字輸出
  26. /************主函數**************/
  27. void main()
  28. {
  29.         SCON = 0x00;
  30.         while(1)
  31.         {
  32.                 P1 = 0;
  33.                 for( x = 0; x < 32; x+=2)
  34.                   {
  35.                         STTP = 0;
  36.                         out_rxd(&hanzi[3][x+1]);
  37.                         out_rxd(&hanzi[3][x]);
  38.                         out_rxd(&hanzi[2][x+1]);
  39.                         out_rxd(&hanzi[2][x]);
  40.                         out_rxd(&hanzi[1][x+1]);
  41.                         out_rxd(&hanzi[1][x]);
  42.                         out_rxd(&hanzi[0][x+1]);
  43.                         out_rxd(&hanzi[0][x]);
  44.                         STTP = 1;
  45.                         P1 = x/2;
  46.                 }
  47.         }
  48. }
  49. /************子函數定義?********/
  50. void delay(uint n)
  51. {
  52.                 for( ; n > 0 ; n--)
  53.                 {
  54.                         for( j = 0; j < 10; j++)
  55.                         {;}
  56.                 }
  57. }
  58. void out_rxd(uchar *d)
  59. {
  60.         SBUF = *d;                        //啟動串行口傳送
  61.         while(TI == 0);                        //等待串口傳送結束
  62.         TI = 0;                                //將串口中斷標志位置0
  63. }
漢字點陣顯示.rar (150.33 KB, 下載次數: 95)
ID:474538 發表于 2020-5-5 22:32 | 只看該作者
太差勁了,程序都編譯不了,最基本的位定義都搞錯了,還有里面的字模和仿真里面的都不一樣
ID:474538 發表于 2020-5-5 20:51 | 只看該作者
仿真效果不是很好
