ps2手柄,所有的運行程序,arduino資料
2018-12-20 16:58 上傳
Arduino源程序如下:
- //#include <Servo.h>
- #include <PS2X_lib.h> //for v1.6
- PS2X ps2x;
- //Servo myservo;
- #define PS2_DAT 13 //14
- #define PS2_CMD 7 //15
- #define PS2_SEL 8 //16
- #define PS2_CLK 12 //17
- #define PWMA1 3 //Motor A's pin
- #define PWMA2 5 //Motor A's pin
- #define PWMA3 9 //Motor A's pin
- #define PWMA4 6 //Motor A's pin
- #define SERVOPIN 4 //servo's pin
- #define SERVOMIN 30 //the angle of servo
- #define SERVOMID 90
- #define SERVOMAX 150
- #define TURNLEFT myservo.write(SERVOMIN) //turn left
- #define TURNMID myservo.write(SERVOMID) //turn middle
- #define TURNRIGHT myservo.write(SERVOMAX) //turn right
- #define MOTORFOWARD setMotorA(255) //motor foward
- #define MOTORBACK setMotorA(-255) //motor back
- #define MOTORSTOP setMotorA(0) //motor stop
- bool EnableRockerR = 1;
- bool EnableRockerL = 1;
- int RMid = 0 ;
- int LStop = 0 ;
- #define pressures false
- #define rumble false
- int error = 0;
- byte type = 0;
- byte vibrate = 0;
- void setup() {
- Serial.begin(57600);
- pinMode(PWMA1, OUTPUT);
- pinMode(PWMA2, OUTPUT);
- pinMode(PWMA3, OUTPUT);
- pinMode(PWMA4, OUTPUT);
- myservo.attach(SERVOPIN);
- SERVOMID;
- delay(300);
- error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble);
- if (error == 0) {
- Serial.print("Found Controller, configured successful ");
- Serial.print("pressures = ");
- if (pressures)
- Serial.println("true ");
- else
- Serial.println("false");
- Serial.print("rumble = ");
- if (rumble)
- Serial.println("true)");
- else
- Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
- Serial.println("holding L1 or R1 will print out the analog stick values.");
- Serial.println("Note: Go to www.billporter.info for updates and to report bugs.");
- else if (error == 1)
- Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
- else if (error == 2)
- Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
- else if (error == 3)
- Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
- type = ps2x.readType();
- switch (type) {
- case 0:
- Serial.print("Unknown Controller type found ");
- break;
- case 1:
- Serial.print("DualShock Controller found ");
- break;
- case 2:
- Serial.print("GuitarHero Controller found ");
- break;
- case 3:
- Serial.print("Wireless Sony DualShock Controller found ");
- break;
- void(* resetFunc) (void) = 0;
- void loop() {
- if (error == 1) //skip loop if no controller found
- resetFunc();
- ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
- if (ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed
- Serial.println("Start is being held");
- if (ps2x.Button(PSB_SELECT))
- Serial.println("Select is being held");
- if (ps2x.ButtonPressed(PSB_PAD_UP)) {
- Serial.println("PAD_UP just pressed");
- MOTORFOWARD;
- EnableRockerL = 0;
- }else if(ps2x.ButtonReleased(PSB_PAD_UP)) {
- Serial.println(" PAD_UP just released");
- MOTORSTOP;
- EnableRockerL = 1;
- LStop = 0;
- if (ps2x.ButtonPressed(PSB_PAD_DOWN)) {
- Serial.println("PAD_DOWN just pressed");
- MOTORBACK;
- }else if(ps2x.ButtonReleased(PSB_PAD_DOWN)) {
- Serial.println(" PAD_DOWN just released");
- MOTORSTOP;
- LStop = 0;
- if (EnableRockerL) {
- if (0 <= ps2x.Analog(PSS_LY) && ps2x.Analog(PSS_LY) < 100) {
- Serial.println(" f");
- MOTORFOWARD;
- LStop = 0;
- } else if (255 >= ps2x.Analog(PSS_LY) && ps2x.Analog(PSS_LY) > 170) {
- MOTORBACK;
- Serial.println(" b");
- LStop = 0;
- } else {
- if(LStop == 0){
- MOTORSTOP;
- Serial.println(" s");
- LStop ++;
- if (ps2x.ButtonPressed(PSB_CIRCLE)) { //will be TRUE if button was JUST pressed
- Serial.println("Circle just pressed");
- TURNRIGHT;
- EnableRockerR = 0;
- } else if (ps2x.ButtonReleased(PSB_CIRCLE)) {
- Serial.println("Circle just released");
- TURNMID;
- EnableRockerR = 1;
- RMid = 0;
- if (ps2x.ButtonPressed(PSB_SQUARE)) { //will be TRUE if button was JUST released
- Serial.println("Square just pressed");
- TURNLEFT;
- } else if (ps2x.ButtonReleased(PSB_SQUARE)) { //will be TRUE if button was JUST released
- Serial.println("Square just released");
- TURNMID;
- RMid = 0;
- if (EnableRockerR) {
- if (0 <= ps2x.Analog(PSS_RX)&ps2x.Analog(PSS_RX) < 100) {
- TURNLEFT;
- Serial.println(" l");
- RMid = 0;
- } else if (255 >= ps2x.Analog(PSS_RX)&ps2x.Analog(PSS_RX) > 160) {
- TURNRIGHT;
- Serial.println(" r");
- RMid = 0;
- } else {
- if(RMid == 0){
- TURNMID;
- Serial.println(" mid");
- RMid ++;
- if (ps2x.NewButtonState(PSB_CROSS)) { //will be TRUE if button was JUST pressed OR released
- Serial.println("X just changed");
- MOTORSTOP;
- delay(50);
- void setMotorA(int m1Speed) //電機驅動函數
- if (m1Speed >= 0)
- digitalWrite(PWMA2, HIGH);
- analogWrite(PWMA1, 255 - m1Speed);
- digitalWrite(PWMA4, HIGH);
- analogWrite(PWMA3, 255 - m1Speed);
- else
- digitalWrite(PWMA1, HIGH);
- analogWrite(PWMA2, m1Speed + 255);
- digitalWrite(PWMA3, HIGH);
- analogWrite(PWMA4, m1Speed + 255);
PS2運行程序.zip
(320.1 KB, 下載次數: 38)
2018-12-20 16:44 上傳
zip 下載積分: 黑幣 -5
