查看: 5541|回復: 2
Arduino三片74HC595控制雙色8x8LED點陣程序
三片 595 聯級控制雙色點陣(共陰)顯示
問題:綠色總是少顯示一列.  有高手看看代碼指出問題.   (有誰做過 三片595 控制雙色點陣,歡迎交流)
代碼:
#include <TimerOne.h>
int latchpin = 8;
int clockpin = 12;
int datapin = 11;
int i;
int j;
int k;
void setup()
  pinMode (latchpin,OUTPUT);
  pinMode (clockpin,OUTPUT);
  pinMode (datapin,OUTPUT);
void loop(){
//綠色全亮
  digitalWrite(latchpin,LOW);
  shiftit1(B00000000);
  shiftit0(B11111111);
  digitalWrite(latchpin,HIGH);
  delay(1000);
//紅色全亮
shiftit2(B00000000);
delay(1000);
//陰極 595
void shiftit0(byte dataout){
  int i=0;
  boolean pinstate;
  digitalWrite (datapin,LOW);
  digitalWrite(clockpin,LOW);
  for (i = 0;i < 8;i ++){
    if(dataout &(1 << i)){pinstate = HIGH;}else{pinstate = LOW;}
    digitalWrite(datapin,pinstate);
    digitalWrite(clockpin,HIGH);
    digitalWrite(datapin,LOW);
//綠色 595
void shiftit1(byte dataout){
  int j=0;
  boolean pinstate;
  for (j = 8;j < 16;j ++){
    if(dataout &(1 << j)){pinstate = HIGH;}else{pinstate = LOW;}
//紅色 595
void shiftit2(byte dataout){
  k=0;
  boolean pinstate;
  for (k = 16;k < 32;k ++){
    if(dataout &(1 << k)){pinstate = HIGH;}else{pinstate = LOW;}
ID:1 發表于 2018-12-16 21:37 | 只看該作者
電路原理圖如下:
ID:426684 發表于 2018-12-16 22:17 | 只看該作者
參考的電路圖
