2018-12-16 16:06 上傳
- #include <iom16v.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar Table[12]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x79};
- uchar Data1[4]={10,0,5,0};
- uchar Data2[4]={3,9,1,0};
- uchar Key1,Key2;
- void DelayMs(uchar i)
- uchar j;
- for(;i!=0;i--)
- for(j=150;j!=0;j--);
- void Display(uchar *p)
- uchar i,sel=0x01;
- for(i=0;i<4;i++)
- PORTC=sel;
- PORTA=0xff-Table[p[i]];
- DelayMs(2);
- sel=sel<<1;
- void Sub_Process(uchar *p)
- uchar temp;
- temp=p[1]*10+p[2];
- if(temp!=0)
- temp=temp-1;
- p[1]=temp/10;
- p[2]=temp%10;
- void Key_Process()
- if(Key1==1)
- Add_Process(Data1);
- Key1=0;
- if(Key2==1)
- Sub_Process(Data1);
- Key2=0;
- void Init_IO(void)
- DDRA=0xff;
- PORTA=0xff;
- DDRC=0xff;
- PORTC=0xff;
- DDRB=0x00;
- PORTB=0x00;
- DDRD=0xff;
- PORTD=0xff;
- void main(void)
- Init_IO();
- TCCR1A=0xc3;
- TCCR1B=0x02;
- DelayMs(50);
- while(1)
- Key_Process();
- Set_Process(Data1);
- Display(Data1);
完整代碼見附件
pwm_數(shù)顯.zip
(15.36 KB, 下載次數(shù): 52)
2018-12-16 16:09 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
