查看: 4556|回復(fù): 2
51單片機(jī)里面的定時(shí)器2如何使用中斷
ID:440202 發(fā)表于 2018-12-15 11:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
void init2()
T2CON|=0x04;
EXEN2=0;
TH2=0xff;
RCAP2H=0xff;
TL2=0xf7;
RCAP2L=0xf7;
EA=1;
ET2=1;
TF2=1;
PT2=0;
TR2=1;
ID:277550 發(fā)表于 2018-12-15 14:47 | 只看該作者
/*   interrupt vector */
#define                INT0_VECTOR                0
#define                TIMER0_VECTOR        1
#define                INT1_VECTOR                2
#define                TIMER1_VECTOR        3
#define                UART1_VECTOR        4
#define                ADC_VECTOR                5
#define                LVD_VECTOR                6
#define                PCA_VECTOR                7
#define                UART2_VECTOR        8
#define                SPI_VECTOR                9
#define                INT2_VECTOR                10
#define                INT3_VECTOR                11
#define                TIMER2_VECTOR        12
#define                INT4_VECTOR                16
#define                UART3_VECTOR        17
#define                UART4_VECTOR        18
#define                TIMER3_VECTOR        19
#define                TIMER4_VECTOR        20
#define                CMP_VECTOR                21
ID:230975 發(fā)表于 2019-11-23 15:20 | 只看該作者
#include "reg51.h"
#include "intrins.h"
//測(cè)試工作頻率為11.0592MHz
sfr     T2L         =   0xd7;
sfr     T2H         =   0xd6;
sfr     AUXR        =   0x8e;
sfr     IE2         =   0xaf;
#define ET2             0x04
sfr     AUXINTIF    =   0xef;
#define T2IF            0x01
sbit    P10         =   P1^0;
void TM2_Isr() interrupt 12 using 1
    P10 = !P10;                                 //測(cè)試端口
    AUXINTIF &= ~T2IF;                          //清中斷標(biāo)志
    T2L = 0x66;                                 //65536-11.0592M/12/1000
    T2H = 0xfc;
    AUXR = 0x10;                                //啟動(dòng)定時(shí)器
    IE2 = ET2;                                  //使能定時(shí)器中斷
    EA = 1;
    while (1);
無(wú)效樓層,該帖已經(jīng)被刪除
