查看: 1544|回復: 0
報警與LED之中斷與定時應用加AVR及51單片機原檔資料
//--------------------------------------------------------51部份代碼----------------------------------------------------------------//
#include <reg52.h>
#include <intrins.h>
sbit SPK = P3^7;
uchar FRQ = 0x00;
void Delayms(uint ms)
         uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
         P2 =   0x00;
        TMOD = 0x11;
        TH0 = 0x00;
        TL0 = 0xff;
        IT0 = 1;
        TR0 = 0;
        TR1 = 0;
                 FRQ++;
                Delayms(1);
void EX0_INT() interrupt 0
         TR0 = !TR0;
        TR1 = !TR1;
void T0_INT() interrupt 1
         TH0 = 0xfe;
        TL0 = FRQ;
        SPK = ~SPK;
void T1_INT() interrupt 3
         TH0 = -4200/256;
        TL0 = -4200%256;
        P2 = _crol_(P2,1);
//--------------------------------------------------------AVR部份代碼----------------------------------------------------------------//
#include<iom16v.h>
#include<macros.h>
uchar  key = 0;
uchar  led_huayang = 0xe0;
void delay_1ms(unsigned char z)
    unsigned int i,j;
        for(i=0;i<z;i++)
                for(j=0;j<200;j++);
void   main()
        DDRC = 0xff;
        DDRD =~ (1<<2);
        PORTD = (1<<2);
        GICR = 0X40;
        SREG=0x80 ;
                chushizhi++;
                delay_1ms(1);
#pragma interrupt_handler Timer0:iv_TIMER0_OVF
void Timer0()
        TCNT0 = 183 ;
        if( led_huayang & 0x80) led_huayang =( led_huayang<< 1 )| 0x01;
        else    led_huayang<<= 1;
        PORTC = led_huayang;
#pragma interrupt_handler Timer1:iv_TIMER1_OVF
void Timer1()
        TCNT1 = 0xfe00 + chushizhi;
    SPK();
#pragma interrupt_handler int0_INT:2
void int0_INT(void)
  key =! key;
        if(key)
                TIMSK |= 0X05;
                led_huayang = 0xe0;
                TIMSK = 0X00;
                PORTC = 0X00;
                PORTD &=~ (1<<7);
完全代碼附件中
avr_bj_led.zip (10.69 KB, 下載次數: 5)        51_bj_led.zip (16.8 KB, 下載次數: 4)
參與人數 2黑幣 +58 收起 理由
站著說話不腰疼 + 8
