2018-12-11 17:48 上傳
2018-12-11 17:48 上傳
//總源程序
#include<reg51.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit K0=P3^0; //開始搶答按鍵
sbit beep=P3^7; //蜂鳴器
sbit D0=P3^1; //指示燈
sbit K1=P1^0; //1號選手搶答按鍵
sbit K2=P1^1; //2號選手搶答按鍵
sbit K3=P1^2; //3號選手搶答按鍵
sbit K4=P1^3; //4號選手搶答按鍵
sbit K5=P1^4; //5號選手搶答按鍵
sbit K6=P1^5; //6號選手搶答按鍵
sbit K7=P1^6; //7號選手搶答按鍵
sbit K8=P1^7; //8號選手搶答按鍵
char s;
uchar num=0;
char time1; //搶答時間
char time2; //答題限時時間
uint m,n; //T0,T1定時器定一秒時
bit flag1,flag2,flag3,flag4; //標志位
bit aa,bb; //時間調整標志位
//延時子函數
void delay(uint z)
{uint x,y;
for(x=z;x>0;x--)
for(y=120;y>0;y--); }
uchar code table1[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,~0x40};
uchar code table2[]={
//共陽數碼管位碼值
~0xfe,~0xfd,
~0xfb,~0xf7 };
//初始化子函數
void init()
{TMOD=0x11;
TH0=(65536-2000)/256;
TL0=(65536-2000)%256;
TH1=(65536-2000)/256;
TL1=(65536-2000)%256;
ET0=1;
ET1=1;
EA=1;
P0=~0x00;
time1=10;
time2=10;
flag2=1; }
//開始鍵掃描子函數
void key1()
{uchar i=100;
if(K0==0)
{delay(10);
if(K0==0)
{ while(K0==0&&i)
{i--;
delay(10);}
TR0=1;
s=time1;
m=0;
flag1=1;
flag2=1;
flag3=1;
num=0;
beep=1;
D0=1;
flag4=0; //清除違規標志位
aa=0;
bb=0;
//選手搶答按鍵掃描子函數
void key()
{uchar i=100;
if(K1==0)
{delay(10);
if(K1==0)
{while(K1==0&&i)
{i--;
delay(10);}
num=1; //數碼管顯示1號"1"
TR0=0; //關閉定時器0,時間停止
TR1=1; //打開定時器1,使揚聲器響一聲
flag2=0; //關閉開始鍵標志位,使再按其他七個鍵不會響應
if(K2==0) //下面七個鍵的處理同上
delay(10);
if(K2==0)
{while(K2==0&&i)
{i--;
delay(10);}
num=2;
TR0=0;
TR1=1;
flag2=0; //重要
if(K3==0)
{delay(10);
if(K3==0)
{while(K3==0&&i)
{i--;
delay(10);}
num=3;
TR0=0;
TR1=1;
flag2=0;
if(K4==0)
{delay(10);
if(K4==0)
{while(K4==0&&i)
{i--;
delay(10);}
num=4;
TR0=0;
TR1=1;
flag2=0;
if(K5==0)
{delay(10);
if(K5==0)
{while(K5==0&&i)
{i--;
delay(10);}
num=5;
TR0=0;
TR1=1;
flag2=0;
if(K6==0)
{delay(10);
if(K6==0)
{while(K6==0&&i)
{i--;
delay(10);}
num=6;
TR0=0;
TR1=1;
flag2=0;
if(K7==0)
{delay(10);
if(K7==0)
{while(K7==0&&i)
{i--;
delay(10);}
num=7;
TR0=0;
TR1=1;
flag2=0;
if(K8==0)
{delay(10);
if(K8==0)
{while(K8==0&&i)
{i--;
delay(10);}
num=8;
TR0=0;
TR1=1;
flag2=0;
//數碼管顯示子函數
void display()
{if(flag1==1) //開始鍵按下,開始計時搶答
{if(num!=0) //如果有人搶答,則顯示相應的幾號
{P0=table1[num]; //顯示幾號搶到了
P2=table2[0];
delay(2);
P0=~0;
P2=~0xff;
else //否則沒人搶答,則前面不顯示幾號
{P0=~0x00;
P2=~0xff;}
P0=table1[s/10]; //下面為顯示搶答倒計時
P2=table2[2];
delay(2);
P0=~0;
P2=~0xff;
P0=table1[s%10];
P2=table2[3];
delay(2);
P2=~0xff;
P0=~0x00;
else //如果開始鍵沒有按下,則顯示F FF(若有違規者,則顯示違規號碼及 FF)或時間調整
{if(flag4==1) //違規顯示
{if(num!=0)
{P0=table1[num]; //顯示幾號違規了
P2=table2[0];
delay(2);
P0=~0x00;
P2=~0xff;
P0=table1[15]; //下面顯示 FF,表示違規了
P2=table2[2];
delay(2);
P0=~0x00; //消隱
P2=~0xff;
P0=table1[15];
P2=table2[3];
delay(2);
P0=~0x00;
P2=~0xff;
P0=~0x00;
P2=~0xff;}
else //沒有人違規才顯示調整時間
{if(aa==1)
P0=~0x76; //第一位數碼管顯示"5(S)"(表示搶答時間調整)
P2=table2[0];
delay(2);
P0=~0x00;
P2=~0xff;
P0=table1[time1/10]; //下面顯示調整的搶答時間
P2=table2[2];
delay(2);
P0=~0x00;
P2=~0xff;
P0=table1[time1%10];
P2=table2[3];
delay(2);
P0=~0x00;
P2=~0xff;
else if(bb==1)
{P0=~0x38; //第一位與第二位數碼管合起來顯示"T",表示答題 時間調整
P2=table2[0];
delay(2);
P0=~0x00;
P2=~0xff;
P0=table1[time2/10];
P2=table2[2];
delay(2);
P0=~0x00;
P2=~0xff;
P0=table1[time2%10];
P2=table2[3];
delay(2);
P0=~0x00;
P2=~0xff;
else //否則顯示F FF
{P0=table1[15];
P2=table2[0];
delay(2);
P0=~0x00;
P0=table1[15];
P2=table2[2];
delay(2);
P0=~0x00; //消隱
P2=~0xff;
P0=table1[15];
P2=table2[3];
delay(2);
P0=~0x00;
P2=~0xff;
{uchar i=100;
init(); //調用初始化子函數
{key1(); //調用開始鍵掃描子函數
if((flag1==0)&(flag2==1)) //違規
{key();
if(num!=0) //開始鍵沒有按下時,有人按下了搶答器,則置違規標志位
{flag4=1;
D0=0;
if((flag1==1)&(flag2==1)) //如果開始鍵按下且搶答鍵沒有人按下,則進行八路 搶答鍵掃描
{key();}
display(); //顯示到數碼管上
//定時器0中斷子函數
void t0() interrupt 1
{TH0=(65536-2000)/256;//2ms
if(flag3) //開始(START)鍵按下,嘟一聲(長1秒),表示開始搶答
beep=~beep;
beep=1;
if(s<5) //搶答時間快到報警,隔1秒響一聲且紅燈閃爍,響三聲
{if(s%2==0)
{flag3=1;
D0=0;}
{flag3=0;
D0=1;}
m++;
if(m==500)//1秒
{m=0;
s--;
flag3=0; //關閉開始鍵按下響一秒的嘟聲
if(s==-1)
{s=20;
TR0=0;
flag1=0; //顯示F FF
flag2=1;
num=0;
D0=1;}
//定時器1中斷子函數
void t1() interrupt 3 //定時器1處理有人按下搶答器嘟一聲(長1秒)
{TH1=(65536-2000)/256;
beep=~beep;
n++;
if(n==500)
{n=0;TR1=0;}
全部資料51hei下載地址:
單片機.zip
(53.98 KB, 下載次數: 62)
2018-12-11 09:20 上傳
下載積分: 黑幣 -5
