查看: 8039|回復: 8
基于stm32精英版的溫控風扇源碼
用stm32F103ZET6精英版,溫度傳感器是DS18B20,1602液晶顯示屏,利用溫度來控制轉速,液晶顯示屏顯示實時轉速,也可手動調節轉速。(采用pi控制)
電路原理圖如下:
  1. #include "delay.h"
  2. #include "key.h"
  3. #include "sys.h"
  4. #include "timer.h"
  5. #include "lcd1602.h"
  6. #include "encoder.h"
  7. #include "control.h"
  8. #include "usart.h"
  9. #include "usart3.h"
  10. #include "hc05.h"
  11. #include "string.h"
  12. #include "usmart.h"
  13. #include "ds18b20.h"
  14.         u8 w=0;
  15.         int k=0;
  16. extern int real;
  17. vu8 key=0;
  18. u8 reclen=0;
  19. extern int temperature;
  20. int main(void)
  21. {
  22.         delay_init();
  23.         LCD_GPIO_Configuration();
  24.         LCD1602_Init();
  25.         KEY_Init();//按鍵初始化;
  26.   ENCODER_Init();
  27.   TIM2_Int_Init(19999,35);
  28.         TIM3_PWM_Init(7199,0); //不分頻。PWM頻率=72000000/900=80Khz
  29.         DS18B20_Init();
  30. //usmart_dev.init(72);         //初始化USMART
  31.         delay_ms(5000);                        //等待藍牙模塊上電穩定
  32.         LCDshowNum(0,0,"EV:",SpeedSet);
  33.         LCDshowNum(0,1,"RV:", real);
  34.         LCDshowTNum(9,1,"T:",temperature);
  35. //        while(HC05_Init())                 //初始化ATK-HC05模塊
  36. //{
  37. //                delay_ms(500);
  38. //        }
  39. //        delay_ms(100);
  40. //        USART3_RX_STA=0;
  41.
  42. while(1)
  43. {
  44.          delay_ms(200);
  45.          temperature=(int)DS18B20_Get_Temp();
  46.          LCDshowNum(0,0,"EV:",SpeedSet);
  47.          LCDshowNum(0,1,"RV:", real);
  48.          LCDshowTNum(9,1,"T:",temperature);
  49.          key=KEY_Scan(0);
  50.                  switch(key)
  51.             {
  52.                              case KEY0_PRES:
  53.                              SpeedSet+=100;
  54.                                          k++;
  55.                        LCDshowNum(0,0,"EV:",SpeedSet);
  56.                               break;
  57.                             case KEY1_PRES:
  58.                              SpeedSet-=100;
  59.              k++;
  60.                        LCDshowNum(0,0,"EV:",SpeedSet);
  61.                               break;
  62.                              default:break;
  63.                     }
  64.          if(k==0&&temperature>270)
  65.                 {
  66.                                    SpeedSet=2200;
  67.                       LCDshowNum(0,0,"EV:",SpeedSet);
  68.     }
  69.          if(k==0&&temperature<270&&temperature>250)
  70.                  {
  71.                                    SpeedSet=2100;
  72.
  73.                       LCDshowNum(0,0,"EV:",SpeedSet);
  74.
  75.       }
  76.                  if(k==0&&temperature<250&&temperature>200&&temperature==200&&temperature==250)
  77.                  {
  78.                                   SpeedSet=2000;
  79.                       LCDshowNum(0,0,"EV:",SpeedSet);
  80.       }
  81.                  if(k==0&&temperature<200)
  82.      {
  83.                                    SpeedSet=1800;
  84.                        LCDshowNum(0,0,"EV:",SpeedSet);
  85.       }
  86.
  87. }
  88.
  89.          }
test1 - 1602正常 1x4鍵盤 加減調速 加溫控.rar (368.76 KB, 下載次數: 198)
收藏收藏10 分享淘帖 頂1 踩
ID:482003 發表于 2019-2-28 10:45 | 只看該作者
這個設計好不錯哦
ID:633427 發表于 2019-11-2 08:56 | 只看該作者
請問用開發板做的嗎
ID:593339 發表于 2019-12-2 23:59 來自觸屏版 | 只看該作者
電路圖有文件嗎?
ID:792573 發表于 2020-6-29 11:00 | 只看該作者
電路圖有文件嗎?
ID:343056 發表于 2020-7-4 15:33 | 只看該作者
電路圖是用什么畫的,有源文件嗎
ID:821549 發表于 2020-9-22 10:04 | 只看該作者
很棒剛好需要部分內容
ID:525238 發表于 2021-4-22 16:09 | 只看該作者
正準備做個個小項目不錯
ID:1061976 發表于 2023-2-2 10:39 | 只看該作者
我需要原理圖
