查看: 3724|回復(fù): 0
stc51單片機(jī)的電風(fēng)扇模擬控制系統(tǒng)程序設(shè)計(jì)
ID:442989 發(fā)表于 2018-12-10 08:30 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)源程序如下:
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. code uchar seven_seg[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  5. uchar cp1,cp2,cp,k,m,time;
  6. sbit m1 = P1^1;
  7. sbit m2 = P1^0;
  8. sbit m3 = P3^7;
  9. sbit m4 = P1^2;
  10. sbit m40 = P1^3;
  11. sbit m41 = P1^4;
  12. void delay(uint x){while(x--);}
  13. #include<pwm.c>
  14. #include<key.c>
  15. #include<display.c>
  16. void timer0_isr(void) interrupt 1
  17. {
  18.         TH0 = (65536 - 2000) / 256;
  19.         TL0 = (65536 - 2000) % 256;
  20.         cp1++;
  21.         if((key5 == 0) && (m % 2 != 0))cp2++;
  22.         display();
  23. }
  24. void timer0_init(void)
  25. {
  26.         TMOD = 0x01;
  27.         TH0 = (65536 - 2000) / 256;
  28.         TL0 = (65536 - 2000) % 256;
  29.         EA = 1;
  30.         ET0 = 1;
  31.         TR0 = 1;
  32. }
  33. void main()
  34. {
  35.         m1 = 0,m2 = 0,m3 = 0,m4 = 0;
  36.         STC_pwm_init();
  37.         timer0_init();
  38.         while(1)
  39.         {
  40.                 PWM();
  41.                 key();
  42.         }
  43. }
電風(fēng)扇模擬控制系統(tǒng).zip (28.93 KB, 下載次數(shù): 62)
無效樓層,該帖已經(jīng)被刪除
