查看: 3211|回復: 1
我的單片機定時/計數器實例演練—60s定時,含源碼仿真
使用
的是keil4和proteus7.8
如圖,p2口驅動7段LED數碼管模塊,而p1.0與p1.1為兩位數7段LED數碼管模塊的掃描信號,其中p1.0為個位數掃描信號,p1.1為十位數掃描信號。
單片機源程序:
#include<reg51.h>
#define SEG P2
#define SCANP P1
sbit LED=P0^7;
#define count_M1 50000
#define TH_M1 (65536-count_M1)/256
#define TL_M1 (65536-count_M1)%256
int count_T0=0;
#define count_M2 250
#define TH_M2 (256-count_M2)
#define TL_M2 (256-count_M2)
char count_T1=0;
char TAB[10]={ 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x83,0xf8,0x80,0x98};
char disp[2]={0xc0,0xc0};
char seconds=0;
char scan=0;
main()
IE=0x8a;
TMOD=0x21;
TH0=TH_M1;TL0=TL_M1;
TR0=1;
TH1=TH_M2;TL1=TL_M2;
TR1=1;
LED=1;
while(1);
void T0_1S(void) interrupt  1
   if(++count_T0==20)
   count_T0=0;
   seconds++;
   if(seconds==60)
   seconds=0;
   LED=~LED;
  disp[1]=TAB[seconds/10];
  disp[0]=TAB[seconds%10];
  void T1_8ms(void)  interrupt  3
  if(++count_T1==32)
  count_T1=0;
  if(++scan==3) scan=1;
  SEG=0xff;
  SCANP=~scan;
  SEG=disp[scan-1];
全部資料51hei下載地址:
單片機.zip (18.3 KB, 下載次數: 7)
ID:435819 發表于 2018-12-10 09:03 | 只看該作者
好長的代碼,要能加上代碼釋義就好了
