查看: 2793|回復: 1
TFT彩屏Z180SN009原理圖與驅動代碼資料包
ID:441142 發表于 2018-12-6 19:02 | 顯示全部樓層 |閱讀模式
TFT彩屏Z180SN009資料包
電路原理圖如下:
  1. void  ST7735_INITIAL ()
  2. {
  3. //------------------------------------ST7735R Reset Sequence-----------------------------------------//
  4. RES =1;
  5. delay (1);                                                              //Delay 1ms
  6. RES =0;
  7. delay (1);                                                              //Delay 1ms
  8. RES =1;
  9. delay (120);                                                              //Delay 120ms
  10. //--------------------------------End ST7735R Reset Sequence --------------------------------------//
  11. //--------------------------------End ST7735S Reset Sequence --------------------------------------//
  12. LCD_WriteCommand(0x11); //Sleep out
  13. delay(120);              //Delay 120ms
  14. //------------------------------------ST7735S Frame Rate-----------------------------------------//
  15. LCD_WriteCommand(0xB1);
  16. LCD_WriteData(0x05);
  17. LCD_WriteData(0x3C);
  18. LCD_WriteData(0x3C);
  19. LCD_WriteCommand(0xB2);
  20. LCD_WriteData(0x05);
  21. LCD_WriteData(0x3C);
  22. LCD_WriteData(0x3C);
  23. LCD_WriteCommand(0xB3);
  24. LCD_WriteData(0x05);
  25. LCD_WriteData(0x3C);
  26. LCD_WriteData(0x3C);
  27. LCD_WriteData(0x05);
  28. LCD_WriteData(0x3C);
  29. LCD_WriteData(0x3C);
  30. //------------------------------------End ST7735S Frame Rate---------------------------------//
  31. LCD_WriteCommand(0xB4); //Dot inversion
  32. LCD_WriteData(0x03);
  33. //------------------------------------ST7735S Power Sequence---------------------------------//
  34. LCD_WriteCommand(0xC0);
  35. LCD_WriteData(0x28);
  36. LCD_WriteData(0x08);
  37. LCD_WriteData(0x04);
  38. LCD_WriteCommand(0xC1);
  39. LCD_WriteData(0XC0);
  40. LCD_WriteCommand(0xC2);
  41. LCD_WriteData(0x0D);
  42. LCD_WriteData(0x00);
  43. LCD_WriteCommand(0xC3);
  44. LCD_WriteData(0x8D);
  45. LCD_WriteData(0x2A);
  46. LCD_WriteCommand(0xC4);
  47. LCD_WriteData(0x8D);
  48. LCD_WriteData(0xEE);
  49. //---------------------------------End ST7735S Power Sequence-------------------------------------//
  50. LCD_WriteCommand(0xC5); //VCOM
  51. LCD_WriteData(0x1A);
  52. LCD_WriteCommand(0x36); //MX, MY, RGB mode
  53. LCD_WriteData(0xC0);
  54. //------------------------------------ST7735S Gamma Sequence---------------------------------//
  55. LCD_WriteCommand(0xE0);
  56. LCD_WriteData(0x04);
  57. LCD_WriteData(0x22);
  58. LCD_WriteData(0x07);
  59. LCD_WriteData(0x0A);
  60. LCD_WriteData(0x2E);
  61. LCD_WriteData(0x30);
  62. LCD_WriteData(0x25);
  63. LCD_WriteData(0x2A);
  64. LCD_WriteData(0x28);
  65. LCD_WriteData(0x26);
  66. LCD_WriteData(0x2E);
  67. LCD_WriteData(0x3A);
  68. LCD_WriteData(0x00);
  69. LCD_WriteData(0x01);
  70. LCD_WriteData(0x03);
  71. LCD_WriteData(0x13);
  72. LCD_WriteCommand(0xE1);
  73. LCD_WriteData(0x04);
  74. LCD_WriteData(0x16);
  75. LCD_WriteData(0x06);
  76. LCD_WriteData(0x0D);
  77. LCD_WriteData(0x2D);
  78. LCD_WriteData(0x26);
  79. LCD_WriteData(0x23);
  80. LCD_WriteData(0x27);
  81. LCD_WriteData(0x27);
  82. LCD_WriteData(0x25);
  83. LCD_WriteData(0x2D);
  84. LCD_WriteData(0x3B);
  85. LCD_WriteData(0x00);
  86. LCD_WriteData(0x01);
  87. LCD_WriteData(0x04);
  88. LCD_WriteData(0x13);
  89. //------------------------------------End ST7735S Gamma Sequence-----------------------------//
  90. LCD_WriteCommand(0x3A); //65k mode
  91. LCD_WriteData(0x05);
  92. LCD_WriteCommand(0x29); //Display on
  93. }
  94. Void ST7735SCPT144PanelTurnOnDisplay (void)
  95. {
  96. Write(COMMAND,0x29); //Display on
  97. }
  98. Void ST7735SCPT144PanelTurnOffDisplay (void)
  99. {
  100. Write(COMMAND,0x28); //Display off
  101. }
  102. Void ST7735SCPT144PanelTurnOnPartial (void)
  103. {
  104. Write(COMMAND,0x30); //Setup the partial area
  105. Write(DATA,0x00);
  106. Write(DATA,PSL); //PSL:Start Line
  107. Write(DATA,0x00);
  108. Write(DATA,PEL); //PEL:End Line
  109. Write(COMMAND,0x12); //Turn on partial mode
  110. }
  111. Void ST7735SCPT144PanelTurnOffPartial (void)
  112. {
  113. Write(COMMAND,0x13); //Turn off partial mode
  114. }
  115. Void ST7735SCPT144PanelTurnOnIdle (void)
  116. {
  117. Write(COMMAND,0x39); //Turn on idle mode
  118. }
  119. Void ST7735SCPT144PanelTurnOffIdle (void)
  120. {
  121. Write(COMMAND,0x38); // Turn off idle mode
  122. }
  123. Void ST7735SCPT144PanelSleepInMode (void)
  124. {
  125. Write(COMMAND,0x10); //Sleep in
  126. Delayms (120); //Delay 120ms
  127. }
  128. Void ST7735SCPT144PanelSleepOutMode (void)
  129. {
  130. Write(COMMAND,0x11); //Sleep out
  131. Delayms (120); //Delay 120ms
  132. }
Z180SN009資料包.zip (2.71 MB, 下載次數: 34)
ID:605302 發表于 2019-8-29 22:33 | 顯示全部樓層
此帖僅作者可見
