該程序使用到了TM1638,附件中有。
(上一篇文章中的程序包含了此程序的公共代碼部分,但是我忘了把 tm1638.h 放到附件里面了,這次補上)
定時器初值設為00:02:15,結束后重置為23:59:59
源の代碼:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
uint8_t num[8]; //各個數碼管顯示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void)
P3DIR |= BIT5;
P3DIR |= BIT4 + BIT2;
P1DIR |= BIT0; // ACLK set out to pins
P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA) //寫數據函數
unsigned char i;
DIO_OUT;
for(i=0;i<8;i++)
CLK_low;
if(DATA & 0x01)
DIO_high;
DIO_low;
CLK_high;
DATA>>=1;
unsigned char TM1638_Read(void) //讀數據函數
unsigned char i;
unsigned char temp=0;
DIO_IN;
STB_low;
for(i=0;i<8;i++)
temp>>=1;
CLK_low;
_delay_us(100);
if(DIO_READ)
temp |= 0x80;
temp &= 0x7f;
CLK_high;
return temp;
void Write_COM(unsigned char cmd) //發送命令字
CLK_high;
STB_high;
STB_low;
TM1638_Write(cmd);
STB_high;
void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫入數據
Write_COM(0x44);
STB_low;
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
STB_high;
void init_TM1638(void)
unsigned char count = 0;
unsigned char times = 1;
while(times--){
Write_allLED(tab2[count]);
count++;
if(count == 16)
count = 0;
_delay_ms(100);
Write_allLED(0xff);
_delay_ms(100);
Write_allLED(0);
void delay(){
for (int i=0; i<10; i++)
for (int j=0; j<1000; j++);
void Write_allLED(unsigned char DATA){
unsigned char i;
Write_COM(0x8F);//顯示控制
Write_COM(0x40); //數據命令
STB_low;
TM1638_Write(0xc0);
for(i=0;i<16;i++)
TM1638_Write(DATA);
STB_high;
int main(void)
WDTCTL = WDTPW+WDTHOLD;
init_port();
init_TM1638();
int hourA = 0;
int hourB = 0;
int minuteA = 0;
int minuteB = 2;
int secondA = 1;
int secondB = 5;
while(1) {
secondB--;
if(secondB == -1) {
secondB = 9;
secondA--;
if(secondA == -1) {
secondA = 5;
minuteB--;
if(minuteB == -1) {
minuteB = 9;
minuteA--;
if(minuteA == -1) {
minuteA = 5;
hourB--;
if(hourB == -1) {
hourB = 9;
hourA--;
if(hourA == -1) {
hourA = 2;
hourB = 3;
Write_DATA(4*2,tab[hourA]);
Write_DATA(5*2,tab[hourB]);
Write_DATA(6*2,tab[15]);
Write_DATA(7*2,tab[minuteA]);
Write_DATA(0*2,tab[minuteB]);
Write_DATA(1*2,tab[15]);
Write_DATA(2*2,tab[secondA]);
Write_DATA(3*2,tab[secondB]);
delay();
sy2-3-1.zip
2018-11-30 22:42 上傳
下載積分: 黑幣 -5
1.94 KB, 下載次數: 7, 下載積分: 黑幣 -5
定時器
