例4 數(shù)字鐘的proteus仿真電路及C語言程序設(shè)計(jì)
單片機(jī)源程序如下:
- #include <REG51.H>
- #define uint unsigned int
- #define uchar unsigned char
- uint sec;
- uint min=23;
- uint hour=8;
- uint tcnt;
- unsigned char table[]=
- {0x3f,0x06,0x5b,0x4f,0x66,
- 0x6d,0x7d,0x07,0x7f,0x6f,
- 0x40,0x00};
- //共陰數(shù)碼管 0-9 '-'
- void display(unsigned char a,unsigned char b,unsigned char c);
- //顯示延時(shí) 函數(shù)
- void delay(unsigned int z)
- unsigned int x;
- unsigned char y;
- for(x=z;x>0;x--)
- for(y=200;y>0;y--);
- void display()
- P3=0xfe;P2=0x00;
- P2=table[sec%10];
- delay(3);
- P3=0xfd;P2=0x00;
- P2=table[sec/10];
- delay(3);
- P3=0xfb;P2=0x00;
- P2=table[10];
- delay(3);
- P3=0xf7;P2=0x00;
- P2=table[min%10];
- delay(3);
- P3=0xef;P2=0x00;
- P2=table[min/10];
- delay(3);
- P3=0xdf;P2=0x00;
- P2=table[10];
- delay(3);
- P3=0xbf;P2=0x00;
- P2=table[hour%10];
- delay(3);
- P3=0x7f;P2=0x00;
- P2=table[hour/10];
- delay(3);
- main()
- TMOD=0x02; //設(shè)置模式為定時(shí)器T0的模式2 (8位自動(dòng)重裝計(jì)數(shù)初值的計(jì)數(shù)值)
- TH0=0x06; //設(shè)置計(jì)數(shù)器初值,靠TH0存儲(chǔ)重裝的計(jì)數(shù)值X0=256-250=6
- TL0=0x06;
- TR0=1; //啟動(dòng)T0
- ET0=1; //開啟定時(shí)器T0中斷允許
- EA=1;
- while(1)
- display();
- void t0(void)interrupt 1 using 0 //t0的中斷程序
- tcnt++;
- if(tcnt==4000)//定時(shí)器的定時(shí)計(jì)數(shù),4000次250us為1秒
- tcnt=0;
- sec++;
- if(sec==60)
- sec=0;
- min++;
- if(min==60)
- min=0;
- hour++;
- if(hour==24)
- hour=0;
數(shù)字鐘的proteus仿真電路及C語言程序設(shè)計(jì).rar
(50.94 KB, 下載次數(shù): 35)
2018-11-29 18:36 上傳
點(diǎn)擊文件名下載附件
