查看: 1304|回復: 0
51單片機電子琴
ID:435069 發表于 2018-11-28 16:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<math.h>
#define u8  unsigned char
#define u16 unsigned int
#define u32 unsigned long
sbit led0=P1^0;
#define _debug 1
#define _fosc 6000000
code u16 fout[7]={262,294,330,349,392,440,494};
//低音1-7
u16 _f=262;//fout[0];//20-20000Hz
u8 bufTL0,bufTH0;
void interrupt0(void) interrupt 0 using 0
    static u8 cnt=0;
    u8 bai=0,ge=0,shi=0;
    if(cnt==6)
      cnt=0;
      cnt++;
    _f=fout[cnt];
    bai=_f/100;
    shi=_f/10%10;
    ge=_f%10;
    P3=(bai<<4)+0x0f;
    P2=shi;
    P2<<=4;
    P2+=ge;
    bufTL0 = (65536-_fosc/12*1/_f/1/2)%256;
    bufTH0 = (65536-_fosc/12*1/_f/1/2)/256;     //定時器賦予初值
    //EX0 =1;
void timer0(void) interrupt 1 using 0
    TL0 = bufTL0;//(65536-1000000*1/_f/1/2)%256;
    TH0 = bufTH0;//(65536-1000000*1/_f/1/2)/256;     //定時器賦予初值         led0=!led0;
    led0=!led0;
void main(void)
   //bufTL0=log(bai);//測試運行時長
   //bufTL0 = (65536-1000000*1/_f/1/2)%256; //--用了2ms
   bai=_f/100;
   shi=_f/10%10;
   ge=_f%10;
   P3=(bai<<4)+0x0f;
   P2=shi;
   P2<<=4;
   P2+=ge;
   EA = 1; //使能總中斷
   EX0 = 1; //使能外部中斷0
   IT0=1; //外部中斷0,采用下跳沿方式觸發
   ET0 = 1;        //允許定時器0中斷
   TMOD = 1;       //定時器工作方式選擇
   //gate c/~t m1 m0
   //0000 0001
   bufTL0 = (65536-_fosc/12*1/_f/1/2)%256;//--用了2ms
   bufTH0 = (65536-_fosc/12*1/_f/1/2)/256;//定時器賦予初值
   TL0=bufTL0;
   TH0=bufTH0;
   TR0 = 1;        //啟動定時器
   while(1);
