查看: 3771|回復: 1
[討論]請大蝦看看我的紅外解碼程序有什么錯誤啊
ID:37810 發表于 2012-4-13 13:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我的數碼管位和斷碼都為低電平時才亮(有點兒特殊)
紅外接收的頭接到INT0引腳
#include<reg52.h>
uchar irtime;
uchar startflag;
uchar irdata[33];
uchar bitnum;
uchar irreceok;
uchar ircode[4];
//uchar irprosok;
uchar disp[8];
uchar code duan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code wei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void delay_50ms(uint t)
 uint j;
 for(;t>0;t--)
  for(j=6245;j>0;j--);
void delay_50us(uint t)
 uchar j;
 for(;t>0;t--)
  for(j=19;j>0;j--);
void timer0init(void)
 TMOD=0x02;
 TH0=0;
 TL0=0;
 ET0=1;
 EA=1;
 TR0=1;
void int0init(void)
 IT0=1;
 EX0=1;
 EA=1;
void irpros(void)  //解碼
 uchar k,i,j,value;
 k=1;
 for(j=0;j<4;j++)
  for(i=0;i<8;i++)
   value=value>>1;    //相當于7次
   if(irdata[k]>6)
   {       //8次
    value=value  | 0x80;
   k++;
  ircode[j]=value;
 //irprosok=1;
void irwork(void)
 disp[0]=ircode[0]/16;
 disp[1]=ircode[0]%16;
 disp[2]=ircode[1]/16;
 disp[3]=ircode[1]%16;
 disp[4]=ircode[2]/16;
 disp[5]=ircode[2]%16;
 disp[6]=ircode[3]/16;
 disp[7]=ircode[4]%16;
void display(void)
 uchar i;
 for(i=0;i<8;i++)
   P1=duan[disp];
   P2=wei;
   delay_50us(20);
 timer0init();
 int0init();
    if(irreceok)
      irpros();
   irreceok=0;
    //if(irprosok)
      irwork();
  // irprosok=0;
  display();
void timer0() interrupt 1
 irtime++;    // 最大255,等自加到255,又變0
void int0() interrupt 0
  startflag=0;
 if(startflag)
  if(irtime>32) //檢測引導碼
   bitnum=0;
  irdata[bitnum++]=irtime;
  irtime=0;
  if(bitnum==33)
   bitnum=0;
   irreceok=1;
  startflag=1;
  irtime=0;
ID:39750 發表于 2012-5-5 16:19 | 只看該作者
我設計成功的紅外解碼程序,你對照一下吧。
#include <reg52.h>
unsigned char smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char smg_we[]={0x00,0x10,0x20,0x30,0x40,0x50,0x60,0x70};
uchar irtime;
uchar startflag;
uchar irdata[33];
uchar bitnum;
uchar irreceok;
uchar ircode[4];
uchar irprosok;
uchar disp[8];
    uchar j;
 for(;t>0;t--)
   for(j=19;j>0;j--);
    uint j;
 for(;t>0;t--)
  TMOD=0x02;
  TH0=0x00;
  TL0=0x00;
  ET0=1;
  EA=1;
  TR0=1;
void int0init(void)
 IT0=1;
 EX0=1;
 EA=1;
void irwork(void)
   disp[7]=ircode[3]%16;
void display(void)
    uchar i;
 for(i=0;i<8;i++)
 P1=smg_we;
 P2=smg_du[disp];
 delay_50us(20);
void irpros(void)
    uchar k,i,j;
 uchar value;
 k=1;
 for(j=0;j<4;j++)
  for(i=0;i<8;i++)
   value=value>>1;
     if(irdata[k]>6)
      value=value|0x80;
     k++;
     ircode[j]=value;
   irprosok=1;
    timer0init();
 int0init();
    if(irreceok)
       irpros();
    irreceok=0;
  if(irprosok)
       irwork();
    irprosok=0;
  display();
void timer0 () interrupt 1
  irtime++;
void int0 () interrupt 0
    if(startflag)
    bitnum=0;
    irdata[bitnum]=irtime;
    irtime=0;
    bitnum++;
    if(bitnum==33)
      bitnum=0;
   irreceok=1;
     startflag=1;
  irtime=0;
