本代碼自己編寫,51單片機(jī)測(cè)風(fēng)速,LCD1602顯示,需風(fēng)速傳感器
單片機(jī)源程序如下:
- #include "reg52.h"
- #include "LCD.H"
- typedef unsigned char u8;
- typedef unsigned int u16;
- bit flagFrame = 0;
- bit flagTxd = 0;
- u8 cntRxd = 0;
- u8 cntTxd;
- u8 pdata bufRxd[7];
- u8 *ptrTxd;
- u8 crch,crcl;
- u8 datas[10];
- unsigned char pdata buf[40];
- void delayms(u8 ms) //延時(shí)ms
- u8 i;
- while(ms--)
- for(i = 0; i < 120; i++);
- unsigned char GetCRC16(unsigned char *ptr, unsigned char len)
- unsigned int index;
- unsigned char crch = 0xFF; //高 CRC 字節(jié)
- unsigned char crcl = 0xFF; //低 CRC 字節(jié)
- unsigned char code TabH[] ={ //CRC 高位字節(jié)值表
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
- 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- unsigned char code TabL[] = { //CRC 低位字節(jié)值表
- 0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
- 0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
- 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
- 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
- 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
- 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
- 0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
- 0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
- 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
- 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
- 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
- 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
- 0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
- 0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
- 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
- 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
- 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
- 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
- 0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
- 0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
- 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
- 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
- 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
- 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
- 0x43, 0x83, 0x41, 0x81, 0x80, 0x40
- while (len--) //計(jì)算指定長度的 CRC
- index = crch ^ *ptr++;
- crch = crcl ^ TabH[index];
- crcl = TabL[index];
- return((crch<<8)|crcl);
- void UsartInit()
- SCON=0X50; //設(shè)置為工作方式1
- TMOD=0X20; //設(shè)置計(jì)數(shù)器工作方式2
- PCON=0X80; //波特率加倍
- TH1=0XF3; //計(jì)數(shù)器初始值設(shè)置,注意波特率是4800的
- TL1=0XF3;
- ES=1; //打開接收中斷
- EA=1; //打開總中斷
- TR1=1; //打開計(jì)數(shù)器
- void Timer0Init()
- TMOD|=0X01;//選擇為定時(shí)器0模式,工作方式1,僅用TR0打開啟動(dòng)。
- TH0=0XFC; //給定時(shí)器賦初值,定時(shí)1ms
- TL0=0X18;
- ET0=1;//打開定時(shí)器0中斷允許
- EA=1;//打開總中斷
- TR0=1;//打開定時(shí)器
- void UartRxMonitor(unsigned char ms)
- static unsigned char cntbkp = 0;
- static unsigned char idletmr = 0;
- if(cntRxd>0)
- if(cntbkp != cntRxd)
- cntbkp = cntRxd ;
- idletmr = 0;
- else
- if(idletmr<30)
- idletmr += ms;
- if(idletmr>=30)
- flagFrame=1;
- else
- cntbkp=0;
- unsigned char UartRead(unsigned char *buf,unsigned char len)
- unsigned char i;
- if(len>cntRxd)
- len = cntRxd;
- for(i=0;i<len;i++)
- *buf++=bufRxd[i];
- cntRxd=0;
- return len;
- void datapros()
- int c;
- c=buf[3]*256+buf[4];
- datas[0]=c/1000;
- datas[1]=c%1000/100;
- datas[2]=c%1000%100/10;
- datas[3]=c%1000%100%10;
- void UartDriver()
- unsigned char len;
- u16 crc;
- if(flagFrame)
- flagFrame = 0;
- len = UartRead(buf,sizeof(buf));
- if(buf[0]!=0x04)
- return;
- crc=GetCRC16(buf,len-2);
- crch = crc>>8;
- crcl = crc&0xFF;
- if((buf[len-2]=crch)&&(buf[len-1]=crcl))
- return;
- else
- datapros();
- void LcdDisplay()
- LcdWriteCom(0x80);
- LcdWriteData('0'+datas[0]);
- LcdWriteCom(0x81);
- LcdWriteData('0'+datas[1]);
- LcdWriteCom(0x82);
- LcdWriteData('0'+datas[2]);
- LcdWriteCom(0x83);
- LcdWriteData('.');
- LcdWriteCom(0x84);
- LcdWriteData('0'+datas[3]);
- LcdWriteCom(0x85);
- LcdWriteData('M');
- LcdWriteCom(0x86);
- LcdWriteData('/');
- LcdWriteCom(0x87);
- LcdWriteData('S');
- void main()
- u8 i;
- u8 Order[8]={0x04,0x03,0x00,0x16,0x00,0x01,0x65,0x9B};
- UsartInit();
- Timer0Init();
- LcdInit();
- while(1)
- delayms(1000);
- for(i=0;i<8;i++)
- SBUF=Order[i];
- while(!TI);
- TI=0;
- delayms(1000);
- UartDriver();
- LcdDisplay();
- void Usart() interrupt 4
- if(RI)
- RI=0;
- if(cntRxd<sizeof(bufRxd))
- bufRxd[cntRxd++]=SBUF;
- void Timer0() interrupt 1
- TH0=0XFC; //給定時(shí)器賦初值,定時(shí)30ms
- TL0=0X18;
- UartRxMonitor(1); //
485型風(fēng)速傳感器.zip
(53.09 KB, 下載次數(shù): 152)
2018-11-23 10:48 上傳
點(diǎn)擊文件名下載附件
51測(cè)風(fēng)速 (485) 下載積分: 黑幣 -5
