只需一步,快速開(kāi)始
查看: 4608|回復(fù): 0
CH455數(shù)碼管的單片機(jī)驅(qū)動(dòng)程序
ID:430347 發(fā)表于 2018-11-21 09:10 | 顯示全部樓層 |閱讀模式
unsigned char CH450_buf2[6];                 //定義6個(gè)數(shù)碼管的數(shù)據(jù)映象緩存區(qū)
//const unsigned char BCD_decode_tab[0x10] = { 0X3F, 0X06, 0X5B, 0X4F, 0X66, 0X6D, 0X7D, 0X07, 0X7F, 0X6F, 0X77, 0X7C, 0X58, 0X5E, 0X79, 0X71 };
void CH455_Init(void)
           unsigned char i;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB        //管腳時(shí)鐘PB
        ,ENABLE);//管腳時(shí)鐘PB        //使能GPIOB時(shí)鐘
        //stm32f103中PB3、PB4、PA15為JTAG引腳,若要作為普通IO口來(lái)使用的話,要禁用JTAG功能。
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
//        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;//GPIO_Pin_6--SCL  GPIO_Pin_7--SDA
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT ;   //輸出
        GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;//推挽輸出  開(kāi)漏輸出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_SetBits(GPIOB,GPIO_Pin_6|GPIO_Pin_7);
        DelayUs(1000);
          CH450_buf_write(CH455_SYSOFF);        // 關(guān)閉休眠
          CH450_buf_write(CH455_7SEG_ON);        // 開(kāi)啟數(shù)碼管
          CH450_buf_write(CH455_SYSON_8);        // 開(kāi)啟亮度
          CH450_buf_write(CH455_SYSON1);        // 開(kāi)啟顯示
                for( i=0; i<4; i++ ) CH450_buf_index( i, 0x00 );  // 清空
//        CH455_Write( CH455_SYSON_8 );                //八段式
* 函數(shù)功能:IIC產(chǎn)生起始信號(hào)函數(shù)
* 輸入?yún)?shù):無(wú)
* 輸出參數(shù):無(wú)
void CH455_I2c_Start(void)
    CH455_SDA_D_OUT();
    CH455_SCL_H;   //SCL = high;
    DelayUs(I2C_DELAY);
    CH455_SDA_H ;   //SDA = high;
    DelayUs(I2C_DELAY);
    CH455_SDA_L ;    //SDA = low;
    DelayUs(I2C_DELAY);
   CH455_SCL_L;    //SCL = low;
    DelayUs(I2C_DELAY);
* 函數(shù)功能:IIC產(chǎn)生停止信號(hào)
* 輸出參數(shù):無(wú)
void CH455_I2c_Stop(void)
    CH455_SDA_D_OUT();
    CH455_SCL_L;;     //SCL = low;
    DelayUs(I2C_DELAY);
    CH455_SDA_L;     //SDA = low;
    DelayUs(I2C_DELAY);
    DelayUs(I2C_DELAY);
    CH455_SDA_H;;    //SDA = high;
    DelayUs(I2C_DELAY);
* 函數(shù)功能:IIC發(fā)送一個(gè)字節(jié)
* 輸入?yún)?shù):一個(gè)字節(jié)
* 輸出參數(shù):無(wú)
void CH455_I2c_WrByte(unsigned char IIC_Byte)
    unsigned char i;
    CH455_SDA_D_OUT();
    for(i = 0; i < 8; i++)
        if(IIC_Byte & 0x80)
            CH455_SDA_H;   //SDA=high;
            CH455_SDA_L;   //SDA=low;
        DelayUs(I2C_DELAY);
        CH455_SCL_H;      //SCL=high;
        DelayUs(I2C_DELAY);
        CH455_SCL_L;       //SCL=low;
        DelayUs(I2C_DELAY);
        IIC_Byte<<=1;
    DelayUs(I2C_DELAY);
    CH455_SDA_H;          //SDA=1;
    DelayUs(I2C_DELAY);
    CH455_SCL_H;          //SCL=1;
    DelayUs(I2C_DELAY);
    CH455_SCL_L;           //SCL=0;
    DelayUs(I2C_DELAY);
unsigned char  CH455_I2c_RdByte( void )                //讀一個(gè)字節(jié)數(shù)據(jù)
    unsigned char i, bytedata;
    CH455_SDA_D_IN();     //將數(shù)據(jù)設(shè)置為輸入模式
    DelayUs(I2C_DELAY);
     CH455_SDA_H;       //數(shù)據(jù)線拉高
    DelayUs(I2C_DELAY);
     CH455_SCL_L;
    DelayUs(I2C_DELAY);
    for(i = 0; i < 8; i++)      //讀8位數(shù)據(jù)
         CH455_SCL_H;
        DelayUs(I2C_DELAY);
        bytedata <<= 1;
        DelayUs(I2C_DELAY);
        bytedata |= (CH455_SDA_IN);
        DelayUs(I2C_DELAY);
         CH455_SCL_L;
        DelayUs(I2C_DELAY);
    CH455_SDA_D_OUT();            //數(shù)據(jù)線設(shè)置回輸出模式
    DelayUs(I2C_DELAY);
    DelayUs(I2C_DELAY);
    DelayUs(I2C_DELAY);
    return(bytedata);//返回?cái)?shù)據(jù)
void CH455_Write( UINT16 cmd )        //寫(xiě)命令
        CH455_I2c_Start();               //啟動(dòng)總線
           CH455_I2c_WrByte(((UINT8)(cmd>>7)&CH455_I2C_MASK)|CH455_I2C_ADDR);
           CH455_I2c_WrByte((UINT8)cmd);     //發(fā)送數(shù)據(jù)
          CH455_I2c_Stop();                 //結(jié)束總線
UINT8 CH455_Read( void )                //讀取按鍵
        UINT8 keycode;
           CH455_I2c_WrByte((UINT8)(CH455_GET_KEY>>7)&CH455_I2C_MASK|0x01|CH455_I2C_ADDR);
           keycode=CH455_I2c_RdByte();      //讀取數(shù)據(jù)
        return keycode;
void        CH450_buf_write( unsigned short cmd )  // 向CH450輸出數(shù)據(jù)或者操作命令,自動(dòng)建立數(shù)據(jù)映象
        if ( cmd & 0x1000 ) {   // 加載數(shù)據(jù)的命令,需要備份數(shù)據(jù)到映象緩沖區(qū)
                CH450_buf2[ (unsigned char)( ( cmd >> 8 ) - 2 ) & 0x07 ] = (unsigned char)( cmd & 0xFF );        // 備份數(shù)據(jù)到相應(yīng)的映象單元
        CH455_Write( cmd );        // 發(fā)出
void        CH450_buf_index( unsigned char index, unsigned char dat )  // 向CH450指定的數(shù)碼管輸出數(shù)據(jù),自動(dòng)建立數(shù)據(jù)映象
// index 為數(shù)碼管序號(hào),有效值為0到5,分別對(duì)應(yīng)DIG2到DIG7
        unsigned short cmd;
        CH450_buf2[ index ] = dat;        // 備份數(shù)據(jù)到相應(yīng)的映象單元
//        cmd = ( CH455_DIG2 + ( (unsigned short)index << 8 ) ) | dat ;        // 生成操作命令
        cmd = ( CH455_DIG0 + ( (unsigned short)index << 8 ) ) | dat ;        // 生成操作命令
void CH450_set_bit(unsigned char bit_addr)     //段位點(diǎn)亮
        unsigned char byte_addr;
        byte_addr=(bit_addr&0x38)>>3;
        if ( byte_addr < 6 ) CH450_buf_index( byte_addr, CH450_buf2[byte_addr] | (1<<(bit_addr&0x07)) );
void CH450_clr_bit(unsigned char bit_addr)     //段位熄滅
        if ( byte_addr < 6 ) CH450_buf_index( byte_addr, CH450_buf2[byte_addr] & ~(1<<(bit_addr&0x07)) );
