查看: 2327|回復: 0
stm32f767開發板按鍵控制LED源碼
ID:429885 發表于 2018-11-20 14:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序只適用于keil5
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "key.h"
  6. int main()
  7. {
  8.         u8 led0stat=1,led1stat=1;
  9.
  10.         Cache_Enable();
  11.         HAL_Init();
  12.
  13.
  14.         delay_init(80);//(u8 SYSCLK)形參,,是unsigned char 0-255
  15.         Stm32_Clock_Init(432,25,2,9);//外部晶振為25M的時候,推薦值:plln=432,pllm=25,pllp=2,pllq=9.
  16.
  17.         __HAL_RCC_GPIOA_CLK_ENABLE();
  18.         __HAL_RCC_GPIOB_CLK_ENABLE();
  19.         __HAL_RCC_GPIOH_CLK_ENABLE();
  20.         __HAL_RCC_GPIOC_CLK_ENABLE();
  21.         key_init();
  22.         led_init();
  23.
  24.
  25.
  26.         while(1)
  27.         {
  28.                 u8 key;
  29.
  30.                 key=key_scan(0);
  31.                 if(key)
  32.                 {
  33.                 switch(key)
  34.                 {
  35.                         case KEY0_PRES:              //KEY0有效
  36.                                      led0stat=!led0stat;//key0--led0
  37.                                break;
  38.                         case KEY1_PRES:                //KEY1有效
  39.                                led1stat=!led1stat;//key1--led1
  40.                                break;
  41.                         case KEY2_PRES:                    //KEY2有效
  42.                                                         led0stat=!led0stat;//同時反轉
  43.                                                         led1stat=!led1stat;
  44.                                  break;
  45.                         case WKUP_PRES:                   //KEY_UP 有效
  46.                                                  led0stat=!led0stat;
  47.                                                  led1stat=!led0stat;//互斥
  48.                                 break;
  49.
  50.
  51.                      }
  52.                     LED0(led0stat);
  53.                                 LED1(led1stat);
  54.                 }
  55.
  56.
  57.         }
  58. }
003KEY-LED.rar (971.06 KB, 下載次數: 20)
