查看: 3673|回復: 0
簡易籃球比賽計分器仿真與單片機代碼(剩余時間,加分減分歸零,交換場地)
這個單片機小制作的功能很全:有比賽剩余時間 加分減分和歸零,交換場地,暫停開始按鈕,代碼在附件,仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1.                                 #include <reg51.h>
  2.                                         #define DUAN P0
  3.                                         #define WEI  P2
  4.                     #define uchar unsigned char
  5.                     #define uint unsigned int
  6.
  7.                                     unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  8.                                             sbit key0=P3^0;   //歸零
  9.                                           sbit key1=P3^1;        // 歸12
  10.                                           sbit key2=P3^2;        //分鐘加一
  11.                                           sbit key3=P3^3;        //暫停/開始
  12.                                           sbit beep=P3^7;
  13.                                         uint addnum;
  14.                                         uchar miaonum,fennum;
  15.                                         uchar b;
  16.
  17.                                         void delay(unsigned int num)     //時間函數
  18.                                          {
  19.                                          unsigned i,j;
  20.                                          for(i=num;i>0;i--)
  21.                                          for(j=120;j>0;j--);
  22.                                          }
  23.                                  void main()
  24.                      {
  25.                                  TMOD=0x02;
  26.                                          TL0=TH0=6;
  27.                                  ET0=1;
  28.                                       EA=1;
  29.                                           TR0=0;
  30.                                          beep=0;
  31.                                          b=10;
  32.                                           fennum=12;
  33.                                           miaonum=0;
  34.                                           while(1)
  35.                      {
  36.                                   P2=0xff;
  37.                                            WEI=0xef;
  38.                                            DUAN=table[miaonum/10];
  39.                                            delay(5);
  40.                                            P2=0xff;
  41.                                            WEI=0xdf;
  42.                                            DUAN=table[miaonum%10];
  43.                                            delay(5);
  44.                                         P2=0xff;
  45.                                                 WEI=0Xf7;
  46.                                                 DUAN=0X40;
  47.                                                 delay(5);
  48.                                            P2=0xff;
  49.                                            WEI=0xfd;
  50.                                            DUAN=table[fennum/10];
  51.                                            delay(5);
  52.                                            P2=0xff;
  53.                                            WEI=0xfb;
  54.                                            DUAN=table[fennum%10];
  55.                                            delay(5);
  56.
  57.                                                    if(!key0)                 //清零
  58.                                         {
  59.                                         delay(10);
  60.                                            if(!key0)
  61.                                         {
  62.                                         fennum=0;
  63.                                         miaonum=0;
  64.                                     }
  65.                                         while(!key0);
  66.                                         }
  67.
  68.        if(!key1)                 //分鐘歸10
  69.                                         {
  70.                                         delay(10);
  71.                                            if(!key1)
  72.                                         {
  73.                                         fennum=10;
  74.                                     }
  75.                                         while(!key1);
  76.                                         }
  77.
  78.                                                           if(!key2)                 //分鐘加1
  79.                                         {
  80.                                         delay(10);
  81.                                            if(!key2)
  82.                                         {
  83.                                         fennum++;
  84.                                     }
  85.                                         while(!key2);
  86.                                         }
  87.
  88.
  89.                                 if(!key3)           //暫停/開始
  90.                                         {
  91.                                         delay(10);
  92.                                            if(!key3)
  93.                                         {
  94.                                         TR0=~TR0;
  95.                                         while(!key3);
  96.                                         }
  97.                                         }
  98.               }
  99.                   }
  100.
  101.
  102.                                 void timer0() interrupt 1
  103.                                 {
  104.
  105.                        addnum++;
  106.                         if(addnum==400)
  107.                              {
  108.                                    if(fennum!=0)
  109.                                    {
  110.                     if(miaonum==0)
  111.
  112.                              miaonum=59,fennum--,addnum=0;
  113.                       else
  114.                                  miaonum--;
  115.                                  addnum=0;
  116.                                           }
  117.
  118.                                    if(fennum==0)
  119.                                    {
  120.                     if(miaonum==0)
  121.
  122.                              miaonum=0;
  123.
  124.                       else
  125.                                  miaonum--;
  126.                                  addnum=0;
  127.                                           }
  128.                                         if(fennum==0)
  129.                                         {
  130.                                         if(miaonum==0)
  131.                                         {
  132.
  133.                                         if(b==0)
  134.
  135.                                         beep=0;
  136.                                         else
  137.                                                 beep=1,b--;
  138.
  139.                                         }
  140.                                         }
  141.
  142.                   }
  143.             }
  144.
簡易籃球計分器.zip (29.22 KB, 下載次數: 74)
收藏收藏2 分享淘帖 頂 踩
