查看: 3789|回復(fù): 0
[求助]一直不理解問題出在哪(關(guān)于中斷的)
ID:37411 發(fā)表于 2012-4-5 01:18 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
原本想實(shí)現(xiàn)的功能是:按按鍵1加一,按鍵2減一,按鍵三清零,按鍵4定時(shí)器定時(shí)一秒自動(dòng)加一,按鍵5燈全亮,蜂鳴器響,再按就關(guān)了,按鍵6為P3.2口是中斷,中斷一次實(shí)行流水燈程序
可問題就出在當(dāng)按了中斷后,燈沒有執(zhí)行流水燈程序,反而數(shù)碼管依次輪流閃亮,燈只亮了兩展,不知道問題出在哪
以下是本人的程序,求大俠指點(diǎn)!!!!謝謝啊!!!!!
#include<reg52.h>
#define uchar unsigned int
#define led P2
uint code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};    //0,1,2,3,4,5,6,7,8,9
uint code btm[]={0xe7,0xc3,0x81,0x00} ;
uint code mtb[]={0x7e,0x3c,0x18,0x00} ;
sbit smg1=P1^0;
sbit smg2=P1^1;
sbit smg3=P1^2;
sbit smg4=P1^3;
sbit key1=P3^7;
sbit key2=P3^6;
sbit key3=P3^5;
sbit key4=P3^4;
sbit key5=P3^3;
sbit sb=P1^5;
uint ge,shi,bai,qian,num,tt;
uint count=0;
void dely(uint);
void display(uint);
 void ltr()
 {led=0x7f;
 for(count=0;count<8;count++)
 led=led>>1;
    dely(500);
 return;
 void rtl()
 {led=0xfe;
 led=led<<1;
 dely(500);
   return;
 void bothtomiddle()
 {led=0xff;
 for(count=0;count<5;count++)
 {led=btm[count];
 dely(500);
 return;
   void middletoboth()
   {led=0xff;
   {led=mtb[count];
   dely(500);
   return;
void dely(uint t)
{   uint x,y;
   for(x=0;x<t;x--)
     for(y=0;y<110;y--)
void init()         //初始化T0和INT0
{    EA=1;
    ET0=1;
     EX0=1;
    IT0=0;
     TMOD=0X01;
    TH0=(65536-45872)/256;
    TL0=(65536-45872)/256;
void keyscan()
   if(key1==0)        //按鍵1加一
      dely(10);
      if(key1==0)
      {   num++;
       if(num==10000)
         num=0;
         sb=0;
         dely(1000);
         sb=1;
        while(!key1);
   if(key2==0)          //按鍵2減一
      dely(10);
      if(key2==0)
       if(num==0)
         num=10000;
           sb=0;
         dely(1000);
         sb=1;
         num--;
        while(!key2);
   if(key3==0)             //按鍵3清零作用
      dely(10);
      if(key3==0)
       num=0;
      while(!key3);
   if(key4==0)
        dely(10);
      if(key4==0)         //定時(shí)器工作
           while(!key4);
           TR0=~TR0;
   if(key5==0)            //按鍵5功能
      dely(10);
      if(key5==0)
       while(!key5) ;
        dely(5);            //LED全亮,蜂鳴器響
        led=~led;
        sb=~sb;
        dely(100);
void display(uint number)             //顯示數(shù)據(jù)函數(shù)
{      qian=number/1000;
     bai=number%1000/100;
     shi=number%100/10;
     ge=number%10;
     smg1=0;
     P0=table[qian];
     dely(5);
     P0=0xff;
     smg1=1;
     smg2=0;
     P0=table[bai];
     dely(5);
     P0=0xff;
     smg2=1;
     smg3=0;
     P0=table[shi];
     dely(5);
     P0=0xff;
     smg3=1;
     smg4=0;
     P0=table[ge];
     dely(5);
     P0=0xff;
     smg4=1;
void zhongduan() interrupt 0        //中斷函數(shù)內(nèi)容
   ltr();
   rtl();
   bothtomiddle();
   middletoboth();
   led=0xff;
void main()               //主函數(shù)入口
{       num=0;
     init();           //初始化定時(shí)中斷函數(shù)
         keyscan();
       display(num);
void timet0() interrupt 1         //定義計(jì)數(shù)器功能
     TL0=(63336-45872)/256;
     tt++;
     if(tt==20)
       tt=0;
       num++;
       if(num==10000)
         {num=0;}
