查看: 2274|回復: 1
智能計算機程序給大家學習一下!
5黑幣
#include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rw=P2^5;
sbit rs=P2^6;
sbit e=P2^7;
sbit led=P3^7;
sbit beep=P2^0;
uint8 key,num;
uint8 fuhao;//定義具體的那個符號,是加減還是乘除。
uint8 flag; //定義有沒有按下符號鍵,這個是統稱
long a,b,c,d; //定義運算數據的第一個和第二個及等于的數變量
uint8 k; //定義小數點后面顯示的位數
uint8 biao;
uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數據
void delay(uint16 i)
while(i--);
void lcdwrc(uint8 c)
delay(1000);
rs=0;
rw=0;
e=0;
P0=c;
e=1;
delay(1000);
e=0;
void lcdwrd(uint8 dat)
delay(1000);
rs=1;
rw=0;
e=0;
P0=dat;
e=1;
delay(1000);
e=0;
rs=0;
void lcdinit()
delay(1500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
lcdwrc(0x08);
lcdwrc(0x01);
lcdwrc(0x06);
lcdwrc(0x0c);
key=0;
num=0;
flag=0;
fuhao=0;
a=0;
b=0;
c=0;
d=0;
biao=0;
led=0;
void keyscan()
P1=0xfe;   //令第一行為0,然后判斷是哪一列按下
if(P1!=0xfe)
  delay(1000);
  if(P1!=0xfe)
   key=P1&0xf0;
   switch(key)
    case 0xe0: num=0;break;   //1
    case 0xd0: num=1;break;   //2
    case 0xb0: num=2;break;   //3
    case 0x70: num=3;break;   //加
  while(P1!=0xfe);
  if(num==0||num==1||num==2)  //確認第一行的數1,2,3
   if(flag==0)  //沒有按下符號鍵
    //led=1;
    a=a*10+dat1[num];
    //led=1;
    b=b*10+dat1[num];
  if(num==3)
   //led=0;
   flag=1;
   fuhao=1;//加號+
  lcdwrd(0x30+dat1[num]);
P1=0xfd;    //令第二行為0,判斷是哪一列按下
if(P1!=0xfd)
  delay(1000);
  if(P1!=0xfd)
   key=P1&0xf0;
   switch(key)
    case 0xe0: num=4;break;   //4
    case 0xd0: num=5;break;   //5
    case 0xb0: num=6;break;   //6
    case 0x70: num=7;break;   //減—
  while(P1!=0xfd);
  if(num==4||num==5||num==6)
    //led=1;
    a=a*10+dat1[num];
    //led=1;
    b=b*10+dat1[num];
   flag=1;
   fuhao=2;//帶表減號
P1=0xfb;   //令第三行為0,判斷哪一列按下
if(P1!=0xfb)
  delay(1000);
  if(P1!=0xfb)
   key=P1&0xf0;
   switch(key)
    case 0xe0: num=8;break;   //7
    case 0xd0: num=9;break;   //8
    case 0xb0: num=10;break;  //9
    case 0x70: num=11;break;  //乘*
  while(P1!=0xfb);
  if(num==8||num==9||num==10)
    //led=1;
    a=a*10+dat1[num];
    //led=1;
    b=b*10+dat1[num];
   flag=1;
   fuhao=3;//帶表乘號*
P1=0xf7;   //令第四行為0,判斷哪一列按下
if(P1!=0xf7)
  delay(1000);
  if(P1!=0xf7)
   key=P1&0xf0;
   switch(key)
    case 0xe0: num=12;break;  //0
    case 0xd0: num=13;break;  //清除rst
    case 0xb0: num=14;break;  //等號=
    case 0x70: num=15;break;  //除/
  while(P1!=0xf7);
  switch(num)
   case 12:
      //led=1;
      a=a*10+dat1[num];
      lcdwrd(0x30);
      //led=1;
      b=b*10+dat1[num];
      lcdwrd(0x30);
     break;
   case 13:
     lcdwrc(0x01); //清屏指令
     a=0;
     b=0;
     flag=0;
     fuhao=0;
     break;
   case 15:
     flag=1;
     fuhao=4;
     lcdwrd(0x2f);//除號/
     break;
   case 14:
     if(fuhao==1)//加
      lcdwrc(0x4f+0x80);
      lcdwrc(0x04);//設置光標左移,屏幕不移動
      c=a+b;
      while(c!=0)  //一位一位顯示
       lcdwrd(0x30+c%10);//顯示結果的最后一位在0x4f的位置
       c=c/10;//取前面的結果數據
      lcdwrd(0x3d); //顯示等于號=
      a=0;
      b=0;
      flag=0;
      fuhao=0;//全部清除為0
     if(fuhao==2)   //減
      lcdwrc(0x4f+0x80);
      if(a>b)
       c=a-b;
       c=b-a;
       c=c/10;//取前面的結果數據
      if(a<b) lcdwrd(0x2d); //顯示-號
      a=0;
      b=0;
      flag=0;
      fuhao=0;//全部清除為0
     if(fuhao==3)//乘法
      lcdwrc(0x4f+0x80);
      c=a*b;
       c=c/10;//取前面的結果數據
      a=0;
      b=0;
      flag=0;
      fuhao=0;//全部清除為0
     if(fuhao==3)//乘法
      lcdwrc(0x4f+0x80);
      c=a*b;
       c=c/10;//取前面的結果數據
      a=0;
      b=0;
      flag=0;
      fuhao=0;//全部清除為0
     if(fuhao==4)
      k=0;
      lcdwrc(0x4f+0x80);
      c=(long)(((float)a/b)*1000);//強制轉換為long。
       k++;
       c=c/10;//取前面的結果數據
單片機的智能計算器.rar
398.37 KB, 下載次數: 2, 下載積分: 黑幣 -5
ID:437376 發表于 2018-12-1 21:33 | 只看該作者
為什么我用你這個代碼,LCD1602的第二行不顯示結果呢
