查看: 2425|回復(fù): 2
stm32風(fēng)力擺源碼 dmp解算姿態(tài)
ID:382827 發(fā)表于 2018-11-16 15:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
暑假做的風(fēng)力擺,有需要的拿走,基于原子的dmp解算的姿態(tài)
  1. #include "mpuiic.h"
  2. #include "delay.h"
  3. //MPU IIC 延時函數(shù)
  4. void MPU_IIC_Delay(void)
  5. {
  6.         delay_us(2);
  7. }
  8. //初始化IIC
  9. void MPU_IIC_Init(void)
  10. {
  11.   GPIO_InitTypeDef  GPIO_InitStructure;
  12.
  13.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//先使能外設(shè)IO PORTB時鐘
  14.
  15.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;         // 端口配置
  16.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
  17.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
  18.   GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據(jù)設(shè)定參數(shù)初始化GPIO
  19.
  20.   GPIO_SetBits(GPIOB,GPIO_Pin_10|GPIO_Pin_11);                                                 //PB10,PB11 輸出高
  21. }
  22. //產(chǎn)生IIC起始信號
  23. void MPU_IIC_Start(void)
  24. {
  25.         MPU_SDA_OUT();     //sda線輸出
  26.         MPU_IIC_SDA=1;
  27.         MPU_IIC_SCL=1;
  28.         MPU_IIC_Delay();
  29.         MPU_IIC_SDA=0;//START:when CLK is high,DATA change form high to low
  30.         MPU_IIC_Delay();
  31.         MPU_IIC_SCL=0;//鉗住I2C總線,準(zhǔn)備發(fā)送或接收數(shù)據(jù)
  32. }
  33. //產(chǎn)生IIC停止信號
  34. void MPU_IIC_Stop(void)
  35. {
  36.         MPU_SDA_OUT();//sda線輸出
  37.         MPU_IIC_SCL=0;
  38.         MPU_IIC_SDA=0;//STOP:when CLK is high DATA change form low to high
  39.         MPU_IIC_Delay();
  40.         MPU_IIC_SCL=1;
  41.         MPU_IIC_SDA=1;//發(fā)送I2C總線結(jié)束信號
  42.         MPU_IIC_Delay();
  43. }
  44. //等待應(yīng)答信號到來
  45. //返回值:1,接收應(yīng)答失敗
  46. //        0,接收應(yīng)答成功
  47. u8 MPU_IIC_Wait_Ack(void)
  48. {
  49.         u8 ucErrTime=0;
  50.         MPU_SDA_IN();      //SDA設(shè)置為輸入
  51.         MPU_IIC_SDA=1;MPU_IIC_Delay();
  52.         MPU_IIC_SCL=1;MPU_IIC_Delay();
  53.         while(MPU_READ_SDA)
  54.         {
  55.                 ucErrTime++;
  56.                 if(ucErrTime>250)
  57.                 {
  58.                         MPU_IIC_Stop();
  59.                         return 1;
  60.                 }
  61.         }
  62.         MPU_IIC_SCL=0;//時鐘輸出0
  63.         return 0;
  64. }
  65. //產(chǎn)生ACK應(yīng)答
  66. void MPU_IIC_Ack(void)
  67. {
  68.         MPU_IIC_SCL=0;
  69.         MPU_SDA_OUT();
  70.         MPU_IIC_SDA=0;
  71.         MPU_IIC_Delay();
  72.         MPU_IIC_SCL=1;
  73.         MPU_IIC_Delay();
  74.         MPU_IIC_SCL=0;
  75. }
  76. //不產(chǎn)生ACK應(yīng)答
  77. void MPU_IIC_NAck(void)
  78. {
  79.         MPU_IIC_SCL=0;
  80.         MPU_SDA_OUT();
  81.         MPU_IIC_SDA=1;
  82.         MPU_IIC_Delay();
  83.         MPU_IIC_SCL=1;
  84.         MPU_IIC_Delay();
  85.         MPU_IIC_SCL=0;
  86. }
  87. //IIC發(fā)送一個字節(jié)
  88. //返回從機有無應(yīng)答
  89. //1,有應(yīng)答
  90. //0,無應(yīng)答
  91. void MPU_IIC_Send_Byte(u8 txd)
  92. {
  93.     u8 t;
  94.         MPU_SDA_OUT();
  95.     MPU_IIC_SCL=0;//拉低時鐘開始數(shù)據(jù)傳輸
  96.     for(t=0;t<8;t++)
  97.     {
  98.         MPU_IIC_SDA=(txd&0x80)>>7;
  99.         txd<<=1;
  100.                     MPU_IIC_SCL=1;
  101.                     MPU_IIC_Delay();
  102.                     MPU_IIC_SCL=0;
  103.                     MPU_IIC_Delay();
  104.     }
  105. }
  106. //讀1個字節(jié),ack=1時,發(fā)送ACK,ack=0,發(fā)送nACK
  107. u8 MPU_IIC_Read_Byte(unsigned char ack)
  108. {
  109.         unsigned char i,receive=0;
  110.         MPU_SDA_IN();//SDA設(shè)置為輸入
  111.     for(i=0;i<8;i++ )
  112.         {
  113.         MPU_IIC_SCL=0;
  114.         MPU_IIC_Delay();
  115.                 MPU_IIC_SCL=1;
  116.         receive<<=1;
  117.         if(MPU_READ_SDA)receive++;
  118.                 MPU_IIC_Delay();
  119.     }
  120.     if (!ack)
  121.         MPU_IIC_NAck();//發(fā)送nACK
  122.     else
  123.         MPU_IIC_Ack(); //發(fā)送ACK
  124.     return receive;
  125. }
風(fēng)力擺.rar (364.67 KB, 下載次數(shù): 23)
ID:1 發(fā)表于 2018-11-16 17:27 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
ID:259503 發(fā)表于 2019-7-12 19:35 | 只看該作者
可以,很好的,謝謝l
