查看: 4218|回復: 1
STM32紅外循跡程序
ID:427301 發表于 2018-11-15 20:30 | 顯示全部樓層 |閱讀模式
  • /* Includes ------------------------------------------------------------------*/
  • #include "stm32f10x.h"
  • #include "stm32f10x_tim.h"
  • #include "stm32f10x_flash.h"
  • #include "stm32f10x_exti.h"
  • #include "stm32f10x_rcc.h"
  • #include "systick.h"
  • #include "stdio.h"
  • #include "misc.h"
  • #define infra1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7);
  • #define infra2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8);
  • #define tube1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0);
  • #define tube2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1);
  • #define tube3 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2);
  • #define tube4 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_3);
  • TIM_OCInitTypeDef  TIM1_OCInitStructure;
  • extern FlagStatus  Status;
  • extern u16 TIM1Compare1[3] = {0,0x3FFF,0x1FFF};
  • extern u16 TIM1Compare2[3] = {0x7FFF,0x3FFF,0x1FFF};
  • extern u16 TIM1Compare3[3] = {0,0x3FFF,0x1FFF};
  • extern u16 TIM1Compare4[3] = {0x7FFF,0x3FFF,0x1FFF};
  • extern u16 tubecnt;
  • extern u16 flag;
  • extern int add;
  • void GPIO_Configuration(void);
  • void TIM_Configuration(void);
  • void tim2_Configuration(void);
  • void exti_Configuration(void);
  • void nvic_Configuration(void);
  • void zhi1(void);
  • void zhi2(void);
  • void zhi3(void);
  • void zuoxiao(void);
  • void zuoda(void);
  • void youxiao(void);
  • void youda(void);
  • void xunji(void);
  • u16 ceju(void);
  • int main(void)
  •         RCC_Configuration();
  •         GPIO_Configuration();
  •         TIM_Configuration();
  •         delay_init();
  •         while(1)
  •          GPIO_ResetBits(GPIOE,GPIO_Pin_15);
  •          GPIO_ResetBits(GPIOB,GPIO_Pin_11);
  •   GPIO_InitTypeDef GPIO_InitStructure;
  • /*TIM1  PWM  輸出:A9:CH1/A10:CH2                */
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  •   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •   GPIO_Init(GPIOA, &GPIO_InitStructure);
  • /*LED顯示:LED5:PE15 / LED6:PB11 / LED7:PE14 / LED8:PB10         */
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
  •   GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  •   GPIO_Init(GPIOB, &GPIO_InitStructure);
  •                  GPIO_SetBits(GPIOB,GPIO_Pin_10);
  •                 GPIO_SetBits(GPIOB,GPIO_Pin_11);
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;
  •   GPIO_Init(GPIOE, &GPIO_InitStructure);
  •                   GPIO_SetBits(GPIOE,GPIO_Pin_14);
  •                 GPIO_SetBits(GPIOE,GPIO_Pin_15);
  • /*紅外管:infra1-> PC7, infra2-> PC8         浮空輸入  */
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 ;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  •   GPIO_Init(GPIOC, &GPIO_InitStructure);
  • /*光電管:tube1-> PC0, tube2-> PC1, tube3-> PC2, tube4-> PC3        浮空輸入*/
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3;
  • /*超聲波:Trig:PB9                Echo:PB8   */
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  •         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  •         GPIO_ResetBits( GPIOB, GPIO_Pin_9);
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  •         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;            //PB1接受采集上升沿 PB6低電平
  •         GPIO_ResetBits(GPIOB,GPIO_Pin_8);
  •         TIM_TimeBaseInitTypeDef  TIM1_TimeBaseStructure;
  •           TIM_DeInit(TIM1);
  •           /* Time Base configuration */
  •           TIM1_TimeBaseStructure.TIM_Prescaler = 0x0; //設置了用來作為TIMx時鐘頻率除數的預分頻值
  •         TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;         //選擇了計數器模式
  •          TIM1_TimeBaseStructure.TIM_Period = 0xFFFF;  //設置了在下一個更新事件裝入活動的自動重裝載寄存器周期  ARR
  •         TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;  //設置了時鐘分割
  •         TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;         //設置了周期計數器值
  •         TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);//根據TIM_TimeBaseInitStruct中指定的參數初始化TIMx的時間基數單位(5個參數)
  •        //TIM1基本計數器設置(設置PWM頻率) //頻率=TIM1_CLK/(ARR+1)
  •         /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  •         TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  •         TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  •         TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  •         TIM1_OCInitStructure.TIM_Pulse = 0x0;
  •         TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  •         TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  •         TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  •         TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  •         TIM_OC1Init(TIM1,&TIM1_OCInitStructure);          //同TimeBaseStructure        (8個參數)        //TIM1_OC1模塊設置(設置1通道占空比)
  •         TIM1_OCInitStructure.TIM_Pulse = 0x7fff;
  •         TIM_OC2Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  •         TIM_OC3Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  •         TIM_OC4Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  •         TIM_Cmd(TIM1,ENABLE);                  //先設置好了TimeBase、OC、BDTR  使能或者失能TIM1外設
  •         /* Main Output Enable */
  •         TIM_CtrlPWMOutputs(TIM1,DISABLE);        //TIM1_CtrlPWMOutputs(ENABLE); 使能或者失能TIM1的主輸出
  • void zhi1(void)                //直走速度1
  •         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  •         TIM_SetCompare2(TIM1,TIM1Compare2[0]);
  •         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  •         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  •         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  • void zhi2(void)                //直走速度2(慢)
  •         TIM_SetCompare2(TIM1,TIM1Compare2[1]);
  •         TIM_SetCompare4(TIM1,TIM1Compare4[1]);
  • void zhi(void)                //直走速度3(很慢)
  •         TIM_SetCompare2(TIM1,TIM1Compare2[2]);
  •         TIM_SetCompare4(TIM1,TIM1Compare4[2]);
  • void zuoxiao(void)                   //左小轉
  • void zuoda(void)                   //左大轉
  •         TIM_SetCompare2(TIM1,0);
  • void youxiao(void)                   //右小轉
  • void youda(void)                   //右大轉
  • void xunji(void)                           //循跡
  •         zhi1();
  •         if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7)) youxiao();
  •         if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8)) zuoxiao();
  •         if(1)
  •                 tubecnt++;
  •                 zhi1();
  •                 delay_ms(100);
  •                 zuoda();
  •                 delay_ms(100);
  • u16 ceju(void)
  •         u16 juli;
  •         flag=0;
  •         GPIO_SetBits( GPIOB, GPIO_Pin_9);
  •         TIM_Cmd(TIM2,ENABLE);
  •         while(juli==0);
  •         juli=add*3.4;;
  •         flag=0;
  •         return juli;
  •         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  •         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);
ID:380211 發表于 2018-12-23 12:04 | 顯示全部樓層
程序是不完整的
