查看: 2020|回復: 0
16x16點陣源碼以及hex
ID:426645 發表于 2018-11-14 20:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
16x16點陣源碼以及hex
#include <REGX51.H>
#define out0 P0
#define out2 P2
#define out1 P1
void delay(uint j)
  uchar i=250;
  for(j=30000;j>0;j--)
    while(--i);
        i=100;
uchar code string[]={
/*--  ???11;  ??????????:?x?=14x14   --*/
/*--  ????8???,????:??x??=16x14  --*/
0x24,0x04,0x48,0x02,0x00,0x01,0xFF,0x1F,0x01,0x10,0x01,0x10,0xFC,0x03,0x00,0x01,
0xC0,0x00,0xFF,0x1F,0x40,0x00,0x40,0x00,0x40,0x00,0x70,0x00,
0x00,0x00,0xFE,0x0F,0x00,0x08,0x00,0x08,0x08,0x08,0x10,0x08,0x10,0x09,0xC0,0x08,
0x30,0x08,0x0C,0x08,0x03,0x08,0x00,0x08,0x00,0x04,0x00,0x03,
0xFC,0x07,0x40,0x00,0xFF,0x1F,0x41,0x10,0x5D,0x17,0x40,0x00,0x5C,0x07,0x00,0x00,
0xFE,0x0F,0x42,0x08,0xFE,0x0F,0x42,0x08,0xFE,0x0F,0x02,0x08,
0x84,0x00,0x84,0x0F,0x44,0x08,0xB5,0x04,0x15,0x03,0xD5,0x1C,0x15,0x02,0x95,0x0F,
0x15,0x02,0x95,0x0F,0x1D,0x02,0xD3,0x1F,0x00,0x02,0x00,0x02,
uchar i,j,n;
    for(j=0;j<4;j++)
                  for(n=0;n<40;n++)
                                for(i=0;i<16;i++)
                                        out1=i%16;
                                        out0=string[i*2+j*32];
                                        out2=string[i*2+1+j*32];
                                        delay(4);
                                        out0=0xff;
                                        out2=0xff;
基于AT89C51單片機的16x16點陣LED顯示器設計.doc
236.86 KB, 下載次數: 12, 下載積分: 黑幣 -5
