查看: 3068|回復: 0
藍橋杯STC15單片機溫度傳感器(內有初始化)
ID:425442 發表于 2018-11-13 09:12 | 顯示全部樓層 |閱讀模式
#include <STC15F2K60S2.H>
#include <intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit key=P1^4;
u8 code tab[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90,0XBF,0XFF};
u16 yi,er,san,si,wu,liu,qi,ba,jiu;
void Delay100us()
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 2;
        j = 15;
        do
                while (--j);
        } while (--i);
void Delay500us()
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 6;
        j = 93;
        do
                while (--j);
        } while (--i);
void delayms(int ms)
        int i,j;
        for(i=ms;i>0;i--)
                for(j=845;j>0;j--);
void chushihua()
        key=0;
        Delay500us();
        key=1;
        Delay500us();
void write(u8 dat)
        u16 i;
        for(i=0;i<8;i++)
                key=0;
                key=dat&0x01;
                Delay100us();
    key=1;
    dat=dat>>1;
u16 read()
        u16  i;
        u16 dat;
        for (i=0;i<8;i++)
                key=0;
                        _nop_();
                dat=dat>>1;
                key=1;
                if(key==1)
                                dat=dat|0x80;
                        Delay100us();
        return dat;
u16 tempget()
        u16 temp;
        u16 low,height;
        chushihua();
        write(0xcc);
        write(0x44);
        Delay500us();
        Delay500us();/*yidian*/
        chushihua();
        write(0xcc);
        write(0xbe);
        low=read();
        height=read();
        temp=height<<4;
        temp=temp|(low>>4);
        return temp;
void allinit()
        P2=0XA0;
        P0=0X00;
        P2=0X80;
        P0=0XFF;
        P2=0XC0;
        P0=0XFF;
        P2=0XFF;
        P0=0XFF;
void desplay1 (u16 yi,u16 er)
                        P2=0XC0;
                P0=0X01;
                P2=0XFF;
                P0=tab[yi];
                delayms(1);
                P2=0XC0;
                P0=0X02;
                P2=0XFF;
                P0=tab[er];
                delayms(1);
void desplay2 (u16 san,u16 si)
                        P2=0XC0;
                P0=0X04;
                P2=0XFF;
                P0=tab[san];
                delayms(1);
                P2=0XC0;
                P0=0X08;
                P2=0XFF;
                P0=tab[si];
                delayms(1);
void desplay3 (u16 wu,u16 liu)
                        P2=0XC0;
                P0=0X10;
                P2=0XFF;
                P0=tab[wu];
                delayms(1);
                P2=0XC0;
                P0=0X20;
                P2=0XFF;
                P0=tab[liu];
                delayms(1);
void desplay4 (u16 qi,u16 ba)
                        P2=0XC0;
                P0=0X40;
                P2=0XFF;
                P0=tab[qi];
                delayms(1);
                P2=0XC0;
                P0=0X80;
                P2=0XFF;
                P0=tab[ba];
                delayms(1);
        u16 wendu;
        allinit();
                 yi=11;
                er=11;
                san=11;
          si=11;
          wu=11;
          liu=0;
          qi=0;
          ba=0;
                wendu=tempget();
   liu=wendu/100;
                qi=wendu%100/10;
                ba=wendu%10;
                desplay1(yi,er);
                desplay2(san,si);
                desplay3(wu,liu);
                desplay4(qi,ba);
