查看: 3581|回復: 0
C52單片機原理圖以及按下按鍵加減0到16
  1. #include  "reg51.h"    //包含頭文件reg51.h,定義了51單片機的專用寄存器
  2. sbit k1=P2^7;
  3. sbit k2=P2^6;
  4. sbit k3=P2^5;
  5. sbit k4=P2^4;
  6. sbit k5=P2^3;
  7. sbit k6=P2^2;
  8. sbit k7=P2^1;
  9. sbit k8=P2^0;
  10. char code table1[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};//陽極靜態數碼管的16進制編碼
  11. char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x83,0xc6,0xa1,0x86,0x8e};//陰極動態數碼管的16進制編碼
  12. //附屬函數專區開始
  13. void yanchi(unsigned int ms) //延時代碼 - 函數定義
  14.     {
  15.         unsigned int x,y;
  16.           for(x=ms;x>0;x--)
  17.               for(y=110;y>0;y--);
  18.      }
  19. void main()                       //主函數
  20. {          unsigned char i=0;
  21.         P0=0x00;
  22.    while(1)
  23.         {
  24.                 if(k1==0)//按下按鍵k1
  25.                 {
  26.                         yanchi(10);
  27.                         if(k1==0) //確認按下按鍵k1
  28.                         {
  29.                                 i++;
  30.                         }while(!k1);
  31.                 }
  32.                 if(k2==0)//按下按鍵k2
  33.                 {
  34.                         yanchi(10);
  35.                         if(k2==0) //確認按下按鍵k2
  36.                         {
  37.                                 i--;
  38.
  39.                         }while(!k2);
  40.                 }P0=table[i];
  41.         }
  42. }
