某寶PM2.5激光傳感器,串口通信,LCD1602顯示PM2.5濃度調(diào)試通過。
單片機(jī)源程序如下:
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- typedef unsigned char U8; // ???8????
- typedef signed char S8; // ???8????
- typedef unsigned int U16; // ???16???
- typedef signed int S16; // ???16???
- typedef unsigned long U32; // ???32???
- typedef signed long S32; // ???32???
- typedef float F32; // ??????32?
- typedef double F64; // ??????64?
- uchar Uart_Con=0;
- uchar Uart_Change=0;
- uint PM25_Data=0;
- uint PM25_Data_L=0;
- uint PM25_Data_H=0;
- uchar PM25_View_Data=0;
- uchar PM25_Set=100;
- uchar PM25_View_change=0;
- uchar num;
- uchar buf;
- uchar PM25set=205;
- //#define Data_0_time 4
- sbit lcdrs=P2^5;
- sbit lcdrw=P2^6;
- sbit lcden=P2^7;
- sbit deng=P1^1;
- sbit BEEP=P1^0;
- sbit A=P2^0;
- uchar table1[]={" PM25= ---ug/m3 "}; // uchar code table[]={" 2016-5-7 sat "};
- uchar table2[]={" PM25_set=200 "}; // uchar code table1[]={" 00:00:00 "};
- uchar PM25,shidu;
- uint n;
- int i=0;
- float v0;
- void delay_1ms(uint t)
- uint i,j;
- for(i=0;i<t;i++)
- for(j=0;j<123;j++)
- void Delay(U16 j)
- { U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void DelayMS(uint x)
- { uchar t;
- while(x--)
- for(t=0;t<80;t++);
- void ddelay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void InitUART(void)
- TMOD |= 0x20;
- SCON = 0x50;
- TH1 = 0xFD;
- TL1 = TH1;
- PCON = 0x00;
- TR1 = 1;
- ES = 1;
- EA = 1;
- void UARTInterrupt(void) interrupt 4 //pm2.5讀取部分
- uchar Uart_Data=0;
- if(RI)
- RI = 0;
- Uart_Data=SBUF;
- switch(Uart_Con)
- case 0:
- if(Uart_Data==0xaa)
- Uart_Con++; A=1;A=1;A=1;A=1;A=1;
- else
- Uart_Con=0;
- break;
- case 1:
- if(Uart_Data==0xc0)
- Uart_Con++;
- else
- Uart_Con=0;
- break;
- case 2:
- PM25_Data_L=Uart_Data;
- Uart_Con++;
- break;
- case 3:
- PM25_Data_H=Uart_Data;
- Uart_Con=0;
- break;
- default:Uart_Con = 0;
- A=0;
- PM25_Data=PM25_Data_H*256+PM25_Data_L;
- Uart_Change=1;
- else
- TI = 0;
- void PM25_disword()
- uchar PM25bai,PM25shi,PM25ge;
- if(Uart_Change==1)
- Uart_Change=0;
- PM25bai=PM25_Data/100+0x30;
- PM25shi=PM25_Data/10%10+0x30;
- PM25ge=PM25_Data%10+0x30;
- table1[7]=PM25bai;
- table1[8]=PM25shi;
- table1[9]=PM25ge;
- PM25_View_change=1;
- void LCD_WriteCom(uchar com)
- lcdrs=0;
- lcdrw=0;
- P0=com;
- ddelay(5);
- lcden=1;
- ddelay(5);
- lcden=0;
- void LCD_WriteData(uchar dat)
- lcdrs=1;
- lcdrw=0;
- P0=dat;
- ddelay(5);
- lcden=1;
- ddelay(5);
- lcden=0;
- void Initlcd()
- ddelay(100);
- LCD_WriteCom(0x38);
- LCD_WriteCom(0x0c);
- LCD_WriteCom(0x06);
- LCD_WriteCom(0x01);
- ddelay(100);
- void Lcd_write(uchar Adress_Com,uchar *Adress_Data)
- uchar i;
- uchar Data_Word;
- LCD_WriteCom(Adress_Com);//寫入字符的顯示位置
- for(i=0;i<16;i++) //寫入字符
- Data_Word=*Adress_Data;
- LCD_WriteData(Data_Word);
- Adress_Data++;
- void main()
- BEEP=0;
- Initlcd();
- InitUART();
- while(1)
- PM25_disword();
- Lcd_write(0x80,table1);
- Lcd_write(0xc0,table2);
- if(PM25_Data>=PM25set)
- BEEP=1;
- deng=0;
- delay_1ms(500);
- BEEP=0;
- deng=1;
- delay_1ms(500);
- else
- BEEP=0;
- deng=1;
PM25.rar
(53.71 KB, 下載次數(shù): 31)
2018-11-7 18:54 上傳
點(diǎn)擊文件名下載附件
串口PM2.5的C51程序
