查看: 3624|回復: 4
51單片機用蜂鳴器播放歌曲
ID:422343 發表于 2018-11-7 15:09 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit BUZZ = P1^6;
unsigned int code NoteFrequ[] = {
    523,  587,  659,  698,  784,  880,  988,
    1047, 1175, 1319, 1397, 1568, 1760, 1976
unsigned int code NoteReload[] = {
    65536 - (11059200/12) / (523*2),
    65536 - (11059200/12) / (587*2),
    65536 - (11059200/12) / (659*2),
    65536 - (11059200/12) / (698*2),
    65536 - (11059200/12) / (784*2),
    65536 - (11059200/12) / (880*2),
    65536 - (11059200/12) / (988*2),
    65536 - (11059200/12) / (1047*2),
    65536 - (11059200/12) / (1175*2),
    65536 - (11059200/12) / (1319*2),
    65536 - (11059200/12) / (1397*2),
    65536 - (11059200/12) / (1568*2),
    65536 - (11059200/12) / (1760*2),
    65536 - (11059200/12) / (1976*2),
bit enable = 1;
bit tmrflag = 0;
unsigned char T0RH = 0xFF;
unsigned char T0RL = 0x00;
void PlayTwoTiger();
    unsigned int i;
    EA = 1;
    TMOD = 0x01;
    TH0 = T0RH;
    TL0 = T0RL;
    ET0 = 1;
    TR0 = 1;
    while (1)
        PlayTwoTiger();
        for (i=0; i<40000; i++);
fmq.zip
1.87 KB, 下載次數: 30, 下載積分: 黑幣 -5
用蜂鳴器播放歌曲
ID:371381 發表于 2018-12-29 15:30 | 顯示全部樓層
請問,用到的蜂鳴器是無源的還是有源的
ID:316572 發表于 2019-3-5 20:33 | 顯示全部樓層
感謝樓主分享,十分感謝
ID:724709 發表于 2020-4-8 12:22 | 顯示全部樓層
子非魚魚 發表于 2018-12-29 15:30
請問,用到的蜂鳴器是無源的還是有源的
肯定是無啊
ID:724709 發表于 2020-5-23 08:17 | 顯示全部樓層
支持一波
