查看: 10611|回復: 0
STP4435A引腳圖與pdf資料下載
ID:422309 發表于 2018-11-7 14:12 | 顯示全部樓層 |閱讀模式
STP4435A的資料
DESCRIPTION
STP4435A is the  P-Channel logic enhancement mode power field  effect transistor
which is produced using high cell density, DMOS trench technology. This high density
process is especially tailored to minimize on-state resistance. These devices are
particularly suited for low voltage application such as LCD backlight, notebook
computer power management, and other battery powered circuits.
STP4435A引腳圖
完整的pdf格式文檔51黑下載地址:
STP4435.pdf (310.85 KB, 下載次數: 17)
