#include<reg52.h> #define uint unsigned int #define uchar unsigned char void initial(void); uchar num,co; uchar a[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; main() { initial(); while(1);
void initial(void) //初始化 { P1=0xfe; co=0; num=0; TMOD= 0x01; TH0=(65536-10)/256; TL0=(65536-10)%256; EA=1; ET0=1; TR0=1; } void timeT0() interrupt 1 { TH0=(65536-10)/256; TL0=(65536-10)%256; num++; if(num==1) { co++; num=0; P1=a[co]; if(co==8) co=0; } } |
