只需一步,快速開(kāi)始
查看: 7416|回復(fù): 4
hx711重力傳感器arduino例程 1Kg 5Kg 10Kg 20Kg
ID:420039 發(fā)表于 2018-11-3 10:57 | 顯示全部樓層 |閱讀模式
如題,重力傳感器hx711代碼
  1. #include "HX711.h"
  2. float Weight = 0;
  3. void setup()
  4. {
  5.         Init_Hx711();                                //初始化HX711模塊連接的IO設(shè)置
  6.         Serial.begin(9600);
  7.         Serial.print("Welcome to use!\n");
  8.         delay(3000);
  9.         Get_Maopi();                //獲取毛皮
  10. }
  11. void loop()
  12. {
  13.         Weight = Get_Weight();        //計(jì)算放在傳感器上的重物重量
  14.         Serial.print(float(Weight/1000),3);        //串口顯示重量
  15.         Serial.print(" kg\n");        //顯示單位
  16.         Serial.print("\n");                //顯示單位
  17.         delay(1000);                                //延時(shí)1s
  18. }
  1. #include "hx711.h"
  2. long HX711_Buffer = 0;
  3. long Weight_Maopi = 0,Weight_Shiwu = 0;
  4. #define GapValue 215//10kg
  5. //****************************************************
  6. //初始化HX711
  7. //****************************************************
  8. void Init_Hx711()
  9. {
  10.         pinMode(HX711_SCK, OUTPUT);
  11.         pinMode(HX711_DT, INPUT);
  12. }
  13. //****************************************************
  14. //獲取毛皮重量
  15. //****************************************************
  16. void Get_Maopi()
  17. {
  18.         Weight_Maopi = HX711_Read();
  19. }
  20. //****************************************************
  21. //稱重
  22. //****************************************************
  23. long Get_Weight()
  24. {
  25.         HX711_Buffer = HX711_Read();
  26.         Weight_Shiwu = HX711_Buffer;
  27.         Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實(shí)物的AD采樣數(shù)值。
  28.         Weight_Shiwu = (long)((float)Weight_Shiwu/GapValue);
  29.         return Weight_Shiwu;
  30. }
  31. //****************************************************
  32. //讀取HX711
  33. //****************************************************
  34. unsigned long HX711_Read(void)        //增益128
  35. {
  36.         unsigned long count;
  37.         unsigned char i;
  38.         bool Flag = 0;
  39.         digitalWrite(HX711_DT, HIGH);
  40.         delayMicroseconds(1);
  41.         digitalWrite(HX711_SCK, LOW);
  42.         delayMicroseconds(1);
  43.           count=0;
  44.           while(digitalRead(HX711_DT));
  45.           for(i=0;i<24;i++)
  46.         {
  47.                   digitalWrite(HX711_SCK, HIGH);
  48.                 delayMicroseconds(1);
  49.                   count=count<<1;
  50.                 digitalWrite(HX711_SCK, LOW);
  51.                 delayMicroseconds(1);
  52.                   if(digitalRead(HX711_DT))
  53.                         count++;
  54.         }
  55.         digitalWrite(HX711_SCK, HIGH);
  56.         count ^= 0x800000;
  57.         delayMicroseconds(1);
  58.         digitalWrite(HX711_SCK, LOW);
  59.         delayMicroseconds(1);
  60.
  61.         return(count);
  62. }
HX711_1Kg.rar
1.3 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
HX711_5Kg.rar
HX711_10Kg.rar
1.31 KB, 下載次數(shù): 25, 下載積分: 黑幣 -5
HX711_20Kg.rar
1.31 KB, 下載次數(shù): 41, 下載積分: 黑幣 -5
ID:437882 發(fā)表于 2019-1-3 15:14 | 顯示全部樓層
你好,為什么我下載了1Kg的試用后,數(shù)據(jù)一直是0kg?給壓力也沒(méi)變化
ID:833646 發(fā)表于 2020-10-23 21:33 | 顯示全部樓層
你好  我的稱重是負(fù)值是什么問(wèn)題啊
ID:255258 發(fā)表于 2020-10-24 13:09 | 顯示全部樓層
可能是傳感器方向接反了
ID:714430 發(fā)表于 2021-1-31 21:38 | 顯示全部樓層
10千克的為什么下不了,還有這個(gè)文件是您寫的嗎
