查看: 1030|回復: 0
實驗-串口實驗-zibgee
ID:419830 發表于 2018-11-2 19:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
zigbee串口實驗
  1. #include<ioCC2530.h>
  2. #include<string.h>
  3. void initUART0(void);
  4. void initLed(void);
  5. #define uint unsigned int
  6. #define uchar unsigned char
  7. #define LED1 P1_0
  8. #define LED2 P1_1
  9. uchar temp;
  10. char str1[50]="1:led1 on,2:led2 on,3:led1 off,4:led2 off\r\n";
  11. void initUART0(void)
  12. {
  13.   CLKCONCMD &= ~0x40;
  14.   while(CLKCONSTA & 0x40);
  15.   CLKCONCMD &= ~0x47;
  16.   PERCFG = 0x00;
  17.   P0SEL=0x3C;
  18.   P2DIR &= ~0xC0;
  19.   U0CSR |= 0x80;
  20.   U0GCR |=9;
  21.   U0BAUD |= 59;
  22.   UTX0IF =1;
  23.   U0CSR |= 0x40;
  24.   IEN0 =0x84;
  25. }
  26. void UartTX_Send_String(char *data,int len)
  27. {
  28.   uint j;
  29.   for(j=0;j<len;j++)
  30.   {
  31.     U0DBUF=*data++;
  32.     while(UTX0IF==0);
  33.     UTX0IF=0;
  34.
  35.   }
  36. }
  37. void initLed(void)
  38. {
  39.   P1DIR |= 0x03;
  40.   LED1=1;
  41.   LED2=1;
  42. }
  43. void main()
  44. {
  45.   initLed();
  46.   initUART0();
  47.   char receive_buf[2];
  48.   uchar counter=0;
  49.   uchar RT_flag=1;
  50.   UartTX_Send_String(str1,50);
  51.   while(1)
  52.   {
  53.          if(RT_flag==1)
  54.          {
  55.            if(temp!=0)
  56.            {
  57.              if((temp!='\r') &&(counter<2) )
  58.              {
  59.                receive_buf[counter++]=temp;
  60.
  61.              }
  62.              else{
  63.                 RT_flag=3;
  64.              }
  65.
  66.              if(counter==3)
  67.              {
  68.                RT_flag=3;
  69.              }
  70.              temp=0;
  71.          }
  72.       }
  73.       if(RT_flag==3)
  74.       {
  75.         U0CSR &=~0x40;
  76.         receive_buf[1]='\0';
  77.         if(receive_buf[0]=='1')
  78.         {
  79.            LED1=0;
  80.            UartTX_Send_String("LED1 on\n",8);
  81.         }
  82.         if(receive_buf[0]=='2')
  83.         {
  84.            LED2=0;
  85.            UartTX_Send_String("LED2 on\n",8);
  86.         }
  87.         if(receive_buf[0]=='3')
  88.         {
  89.            LED1=1;
  90.            UartTX_Send_String("LED1 off\n",8);
  91.         }
  92.         if(receive_buf[0]=='4')
  93.         {
  94.            LED2=1;
  95.            UartTX_Send_String("LED2 off\n",8);
  96.         }
  97.         U0CSR |= 0x40;
  98.         RT_flag=1;
  99.         counter=0;
  100.       }
  101.
  102. }
  103. }
  104. #pragma vector=URX0_VECTOR
  105. __interrupt void UART0_ISR(void)
  106. {
  107.   URX0IF=0;
  108.   temp=U0DBUF;
  109. }
UART.rar (19.07 KB, 下載次數: 6)
