查看: 8826|回復: 0
一個單片機定時器控制流水燈小程序
ID:419790 發表于 2018-11-2 17:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
新人報到!
前段時間自己寫了這個小程序,也不知算不算入門,歡迎各位大佬指正。
  1.          #include <reg51.h>
  2.                                  #include "intrins.h"
  3.          #include "common.h"
  4.
  5.                                  #define FOSC 11059200ul
  6.          #define T0_H (65536-(50*FOSC)/(12*1000))/256
  7.          #define T0_L (65536-(50*FOSC)/(12*1000))%256
  8.                  uint16_t i = 0;
  9.                        uint16_t i1 = 0;
  10.                                          uint16_t i2 = 0;
  11.                                           uint16_t i3 = 0;
  12.                                         bit ayan = 0;
  13.                                         bit byan = 0;
  14.                                         bit cyan = 0;
  15.                  sbit LED0 = P2^3;
  16.                  sbit LED1 = P2^4;
  17.                  sbit LED2 = P2^5;
  18.                  sbit LED3 = P1^0;
  19.                  sbit LED4 = P1^1;
  20.                  sbit LED5 = P1^2;
  21.                  sbit LED6 = P1^3;
  22.                  sbit LED7 = P1^4;
  23.                  sbit LED8 = P1^5;
  24.                  sbit LED9 = P1^6;
  25.                  sbit LED10 = P1^7;
  26.                  sbit KEY1 = P2^0;
  27.                  sbit KEY2 = P2^1;
  28.                  uint16_t t=1;
  29.                  uint16_t t1=0;
  30.                  void delay_ms(uint16_t dly);
  31.                  void time();
  32.
  33.                  void main()
  34.                  {
  35.                                 P1 = 0xfe;
  36.                                 time();
  37.                                 while(1)
  38.                     {
  39.                                                 if(t1==0)
  40.                                                 {
  41.        delay_ms(1000);
  42.        P1 = _crol_(P1,1);
  43.                                                 }
  44.                         if(KEY1 == 0)
  45.                                                         {
  46.                                                             delay_ms(10);
  47.        while(!KEY1);
  48.        t=!t;
  49.               }
  50.                                                 if(t==0)
  51.                                                 {
  52.        if(ayan)
  53.        {
  54.        ayan = 0;
  55.        LED0 = !LED0;
  56.        }
  57.        if(byan)
  58.        {
  59.        byan = 0;
  60.        LED1 = !LED1;
  61.        }
  62.        if(cyan)
  63.        {
  64.        cyan = 0;
  65.        LED2 = !LED2;
  66.        }
  67.                                                 }
  68.                                                 if (t == 1)
  69.                                                 {
  70.        LED0 = 1;
  71.        LED1 = 1;
  72.        LED2 = 1;
  73.                                                 }
  74.
  75.                                                 if(!KEY2)
  76.                                                 {
  77.        delay_ms(10);
  78.        while(!KEY2);
  79.        t1=!t1;
  80.                                                 }
  81.                                                 if(t1== 1)
  82.                                                 {
  83.        delay_ms(1000);
  84.        P1 = _cror_(P1,1);
  85.                                                 }
  86.                         }
  87.                 }
  88.
  89.                                 void time(){
  90.                                                 TMOD=0x01;
  91.             TH0=T0_H;
  92.             TL0=T0_L;
  93.             EA=1;
  94.             ET0=1;
  95.             TR0=1;
  96.                                 }
  97.
  98.                                 void timer0() interrupt 1 {
  99.            TH0 = T0_H;
  100.            TL0 = T0_L;
  101.                                          if(++i1 >=10){
  102.                                                  i1 = 0;
  103.                                                   ayan = 1;
  104.                                          }
  105.
  106.                                          if(++i2 >= 20){
  107.                                                  i2=0;
  108.                                                   byan = 1;
  109.                                          }
  110.
  111.                                          if(++i3 >= 100){
  112.                                                  i3=0;
  113.                                                   cyan = 1;
  114.                                          }
  115.                                  }
  116.
  117.
  118.                         void delay_ms(uint16_t dly){
  119.           uint8_t i;
  120.           while(dly--)
  121.           for(i = 110; i > 0; i--);
  122. }
  123.
  124.
定時器流水燈小程序.zip (5.13 KB, 下載次數: 16)
