查看: 4176|回復: 1
51單片機矩陣鍵盤16個鍵值控制數碼管的輸出0000到1111
ID:384353 發表于 2018-11-2 17:09 | 顯示全部樓層 |閱讀模式
如何用矩陣鍵盤的16個鍵值對應四段數碼管顯示0000到1111?我寫的一個子函數 dectobin(int n)是先十進制轉化成二進制,再放到數組里,數組里對應鍵值得2進制數,然后再數碼管上顯示出來,我仿真不出來 求解
#include <reg51.h>
#define GPIO_DIG P0
#define GPIO_KEY P1
#define GPIO_PLACE P2
unsigned char code DIG_CODE[2]={0xc0,0xf9};//0xc0 0cf9
unsigned char code DIG_PLACE[4]={0xfe,0xfd,0xfb,0xf7};//fe fd fb f7
unsigned char KeyState;//×′ì¬
unsigned char DigplayDate[4];//????????4????
unsigned char SHUZU[4];
unsigned char KeyValue;//????????????
void Delay10ms(unsigned int c);
void KeyDown();
void dectobin(int n);//?????????
void DigDisplay();//??????
void main(void)
        KeyState=0;
                KeyDown();
                if(KeyState==1)
                         dectobin(KeyValue);
                        /*DigplayDate[3]=SHUZU[0];
                        DigplayDate[2]=SHUZU[1];
                        DigplayDate[1]=SHUZU[2];
                        DigplayDate[0]=SHUZU[3];
                        *///KeyState=0;
                DigDisplay();
KeyState=0;
void DigDisplay()//???????
        unsigned char i;
        unsigned int j;
        for(i=0;i<4;i++)
    if(SHUZU[i]==0)
           DigplayDate[i] = DIG_CODE[0];
           DigplayDate[i] = DIG_CODE[1];
                GPIO_PLACE=DIG_PLACE[i]; //????
                GPIO_DIG=DigplayDate[i];//????
                Delay10ms(1);
                j=10;
                while(j--);
                GPIO_DIG=0xff;//??
void KeyDown(void)
        unsigned int a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)
                Delay10ms(1);
                a++;
                a=0;
                if(GPIO_KEY!=0x0f)
                        KeyState=1;//óD°′¼ü°′ÏÂ
                        //2aêÔáD
                        GPIO_KEY=0X0F;
//                         Delay10ms(1);
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=4;break;
                                case(0X0d): KeyValue=8;break;
                                case(0X0e):        KeyValue=12;break;
//                                default:        KeyValue=17;        //¼ì2a3ö′í»Ø¸′17òa˼êǰÑêyÂë1üè«Ãeμô¡£
                        //2aêÔDD
                        GPIO_KEY=0XF0;
//                        Delay10ms(1);
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue+3;break;
                                case(0Xb0):        KeyValue=KeyValue+2;break;
                                case(0Xd0): KeyValue=KeyValue+1;break;
                                case(0Xe0):        KeyValue=KeyValue;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //°′¼üËéêÖ¼ì2a
                                Delay10ms(1);
                                a++;
                        a=0;
        int i,temp,j=0;
        temp=n;
        for(i=0;i<4;i++)
                if(temp==0)
                SHUZU[i]=0;
                        j=temp%2;
                        SHUZU[i]=j;
                  temp=temp/2;
void Delay10ms(unsigned int c)   //?? 0us
    unsigned char a, b;
        //--c???????????????,???for???????????--//
    for (;c>0;c--)
                for (b=38;b>0;b--)
                        for (a=130;a>0;a--);
ID:111634 發表于 2018-11-2 21:26 | 顯示全部樓層
本帖最后由 zl2168 于 2018-11-3 08:42 編輯
實例75  4×4矩陣式鍵盤
Proteus仿真一下,確認有效。
實例75 4×4矩陣式鍵盤.rar (44.8 KB, 下載次數: 33)
實例76 8279擴展鍵盤和顯示.rar (125.29 KB, 下載次數: 5) 8279.jpg
實例77 74LS595 165擴展8×8鍵盤.rar (65.99 KB, 下載次數: 4)
以上摘自張志良編著《80C51單片機仿真設計實例教程——基于Keil CProteus》清華大學出版社ISBN 978-7-302-41682-1.書中電路和程序設計有詳細說明,程序語句條條有注解。
