本程序是利用vb讀寫文件來實現的,再通過調用計算機中的explorer運行新建的文件,程序思想是通過dos命令建立虛擬無線熱點,因此你的計算機必須要求帶無線網卡,如果你的計算機有無線網卡但不能運行,請嘗試升級網卡驅動。由于運行當中會調用explorer程序,和某些計算機病毒的投放方法有所相同,所以程序在運行時會引起一些安全軟件的誤判。程序運行時會在C:\Users\Administrator\Documents目錄下生成文件。 還有許多不足,希望大家指出改進!
程序源碼如下:
Public a As Integer, e As Integer, f As Integer, b As String, c As String, d As String Private Sub Command2_Click() b = Text1.Text c = Text2.Text d = "netsh wlan set hostednetwork mode=allow" If b = "" Or c = "" Then MsgBox "請填寫新建無線網絡名稱或密碼!", 48, "錯誤!" Else If Len(c) = 8 Then Open "C:\Users\Administrator\Documents\wifibuild.bat" For Output As #1 Print #1, "netsh wlan set hostednetwork mode=allow", "ssid="; b, "key="; c Print #1, "netsh wlan start hostednetwork" Close #1 Shell "explorer.exe " & "C:\Users\Administrator\Documents\wifibuild.bat", 1 Label5.Caption = "已連接" Timer1.Enabled = True Else MsgBox "密碼長度應為8位!", 48, "錯誤!" End If End If End Sub Private Sub Command3_Click() If Dir("C:\Users\Administrator\Documents\wifibuild.bat") <> "" Then Open "C:\Users\Administrator\Documents\wifiend.bat" For Output As #1 Print #1, "netsh wlan set hostednetwork mode=disallow" Shell "explorer.exe " & "C:\Users\Administrator\Documents\wifiend.bat", 1 Close #1 Timer1.Enabled = False Else MsgBox "您還沒有創建wifi熱點!", 48, "錯誤!" End If End Sub Private Sub Form_Load() a = 0 e = 0 f = 0 End Sub Private Sub Form_Unload(Cancel As Integer) If Dir("C:\Users\Administrator\Documents\wifibuild.bat") <> "" Then Kill "C:\Users\Administrator\Documents\wifibuild.bat" End If If Dir("C:\Users\Administrator\Documents\wifiend.bat") <> "" Then Kill "C:\Users\Administrator\Documents\wifiend.bat" End If End Sub
Private Sub Option1_Click() Text2.PasswordChar = "" End Sub
Private Sub Option2_Click() Text2.PasswordChar = "*" End Sub
Private Sub Timer1_Timer() r: a = a + 1 If a = 60 Then e = e + 1 a = -1 GoTo r End If If e = 60 Then f = f + 1 e = 0 End If Label6.Caption = f & "小時" & e & "分鐘" & a & "秒" End Sub
附圖: 1.未連接 2.已連接 3. 4.打開網絡和共享中心——》更改適配器設置,會發現多了個無線網絡連接2 5.設置寬帶共享 之后你就可以用你的手機連接你的電腦共享網絡上網,再也不怕月末流量報警了有木有! 注意: 程序運行點擊創建wifi時會出現如下情況 點允許執行就行了,我試過用cmd.exe直接打開新建的文件,好像不行,所以只能用explorer了。
完整的Word格式文檔51黑下載地址:
vb建無線wifi熱點(附圖).doc
(224.5 KB, 下載次數: 16)
2018-11-1 14:24 上傳
