查看: 1648|回復: 0
avr Ds3231驅動
ID:418417 發表于 2018-10-31 14:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <iom16v.h>
#include <macros.h>
#define uint  unsigned int
void DelayUs(uchar i);
void CLK(uchar PD);//設置SCL的電平
void IO(uchar PD);//設置IO的電平
void SetIO(uchar i);//設置IO為輸入輸出
//IIC讀寫函數供外部main函數調用
void WriteDs3231_OneByte(unsigned char addr,unsigned char ddata);
unsigned char ReadDs3231_OneByte(unsigned char addr);
void DelayMs(uchar i)
uint count;
for(;i!=0;i--)for(count=100;count!=0;count--);
//設置SCL的電平
void CLK(uchar PD)
{if(PD==1) PORTD|=0x08;//SCL置1
else       PORTD&=~0x08;//SCL置0
//設置IO的電平
void IO(uchar PD)
{if(PD==1) PORTD|=0x04;//IO置1
else       PORTD&=~0x04;//IO置0
//IIC
//*******************Start條件****************//
void Start(void)
CLK(0);DelayMs(2);
IO(1); DelayMs(2);
CLK(1);DelayMs(2);
IO(0); DelayMs(2);
CLK(0);DelayMs(2);
//*******************Stop條件****************//
void Stop(void)
CLK(0);  DelayMs(2);
IO(0);   DelayMs(2);
CLK(1);  DelayMs(2);
IO(1);   DelayMs(2);
CLK(0);  DelayMs(2);
//********************發送數據************//
void SendData(uchar Xdata)
{uchar count;
for(count=0;count!=8;count++)
  CLK(0); DelayMs(2);
  if(Xdata&0x80)
   IO(1);
   IO(0);
  DelayMs(2);
  CLK(1); DelayMs(2);
  Xdata<<=1;
//以下把SDA置1釋放總線
CLK(0);DelayMs(2);
CLK(1);DelayMs(2);
CLK(0);DelayMs(2);
/////////////接收數據///////////////////
uchar  ReceiveData(void)
uchar count;
uchar temp;
uchar value=0;
DDRD&=~0x04;//設置為輸入
  value<<=1;
  CLK(1); DelayMs(2);
  temp=PIND;//讀引腳
  if((temp&0x04)==0x04) value++;
  DelayMs(2);
  CLK(0); DelayMs(2);
DDRD|=0x04;//設置為輸出
//以下輸出NOACK
CLK(0);DelayMs(2);
IO(1);DelayMs(2);
CLK(1);DelayMs(2);
CLK(0);DelayMs(2);
return value;
//////////////以下供main調用/////////////////
//向addr寫一個數據
    Start();
SendData(0xd0);//器件尋址
SendData(addr);//存儲器尋址
SendData(ddata);//寫入數據
Stop();
DelayMs(2000);
//從addr讀一個數據
    uchar temp;
    Start();
Start();
    SendData(0xd1);   //設置讀
temp = ReceiveData();//讀取數據
Stop();
DelayMs(2000);
return temp;
