查看: 2766|回復: 0
ARDUINO超聲波檢測車距
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
volatile float dist;
LiquidCrystal_I2C mylcd(0x27,16,2);
float checkdistance_4_7() {
  digitalWrite(4, LOW);
  delayMicroseconds(2);
  digitalWrite(4, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(7, HIGH) / 58.00;
  delay(10);
  return distance;
void setup()
  dist = 0;
  pinMode(4, OUTPUT);
  pinMode(7, INPUT);
  mylcd.init();
  mylcd.backlight();
void loop()
  dist = checkdistance_4_7();
  if (dist < 1000) {
    mylcd.clear();
    mylcd.setCursor(0, 0);
    mylcd.print("Distance(cm):");
    mylcd.setCursor(0, 1);
    mylcd.print(dist);
    delay(1000);
