查看: 1429|回復: 0
八路搶答器
#include <reg51.h>
#define unreset e==1
sbit e=P2^0;
unsigned int number[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void delay(unsigned int i)
        unsigned int k;
        for(k=0;k<i;k++);
        unsigned char a;
        P1=0xff;
        P2=0xff;
                        a=P1;
                        if(a==P1)
                                delay(1100);//°′¼üÏû¶¶
                                if(P1==a)
                                                switch(a)
                                                case 0xfe:P0=0XF9;while(unreset); break;//1oÅ£
                                                case 0xfd:P0=0XA4;while(unreset); break;//2oÅ
                                                case 0xfb:P0=0XB0;while(unreset); break;//3oÅ
                                                case 0xf7:P0=0X99;while(unreset); break;//4oÅ
                                                case 0xef:P0=0X92;while(unreset); break;//5oÅ
                                                case 0xDf:P0=0X82;while(unreset); break;//6oÅ
                                                case 0xBf:P0=0XF8;while(unreset); break;//7oÅ
                                                case 0X7F:P0=0X80;while(unreset); break;//8oÅ
                                                default:P0=0xff;
