#include<reg51.h> #include<intrins.h> #define uchar unsigned char #define uint unsigned int uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90} ; uchar a=0,b=0,c=0,d=0,num=0; void xs(); void main() { TH0=(65536-30000)/256; TL0=(65536-30000)%256; TMOD=0X01; EA=1; ET0=1; TR0=1; xs(); while(1) { if(num==20) { num=0; a++; if(a==10) {a=0;b++; } if(b==10) {b=0;c++;} if(c==10) {c=0;d++;} if(d==10) d=0; xs(); } } } void xs() { uchar m,n=1; for(m=0;m<4;m++) { P2=_crol_(n,m); switch(m) { case 0 :P0=table[a];break; case 1 :P0=table;break; case 2 :P0=table[c];break; case 3 :P0=table[d];break; } } } void time() interrupt 1 { TH0=(65536-30000)/256; TL0=(65536-30000)%256; num++; }
 什么問題啊
為什么數碼管上顯示的是 |
