查看: 10786|回復: 9
STM32F1系列MODBUS RTU主站從站源碼
ID:403544 發表于 2018-10-23 09:57 | 顯示全部樓層 |閱讀模式
因為主站,從站分開兩個工程,這里只能分開貼不然容易混淆
主站代碼這里是用來控制16個燈的
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
USHORT
usMBCRC16( UCHAR * pucFrame, USHORT usLen );
unsigned char MBRTU_RX_BUFF[100];//讀取區
unsigned short int MBRTU_TX_CNT=0;//發送長度
short int *Modbus_InputReg[20];
unsigned char MBRTU_Addr=1;
unsigned char MBRTU_TX_BUFF[100];//傳送區
unsigned short int MBRTU_RX_CNT=0;//讀取長度
unsigned char MBRTU_FrameFlag=0;
unsigned char Modbus_OutputIO[20];
unsigned char Modbus_InputIO[20];
u16 *Modbus_HoldReg[20];
u16 startRegAddr;
u16 RegNum;
u16 calCRC;
void    RTU_05 (void);
//輸出GPIO配置
void Output_Init(void)
        /* GPIOF Periph clock enable */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE); //啟用時鐘
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12;//打開PIN端口
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//模式為推挽或者其他模式在這里配置
        GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_10MHz;//設置頻率
        GPIO_Init(GPIOA, &GPIO_InitStructure);//將&GPIO_InitStructure地址賦值給GPIOA,在這里的意思是 打開GPIOA的PIN端口
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_8|GPIO_Pin_10|
        GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;;//打開PIN端口
        GPIO_Init(GPIOB, &GPIO_InitStructure);//將&GPIO_InitStructure地址賦值給GPIOB,在這里的意思是 打開GPIOA的PIN端口
void USART1_IRQHandler(void)//串口1中斷服務程序
        u8 res;
        if(USART_GetITStatus(USART1,USART_IT_RXNE)!=RESET)
                res=USART_ReceiveData(USART1); //讀接收到的字節,同時相關標志自動清除
                        if((MBRTU_RX_CNT<100))//讀取長度小于100則將讀取值 取出
                                        MBRTU_RX_BUFF[MBRTU_RX_CNT]=res;
                                        MBRTU_RX_CNT++;
                                        TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清除定時器溢出中斷
                                        TIM_SetCounter(TIM3,0);//當接收到一個新的字節,將定時器7復位為0,重新計時(相當于喂狗)
                                        TIM_Cmd(TIM3,ENABLE);//開始計時
void MBRTURun(void)
        u16 recCRC;
        if(MBRTU_FrameFlag==1)
                        if(MBRTU_RX_BUFF[0]==MBRTU_Addr && MBRTU_RX_CNT >= 5)
                                if((MBRTU_RX_BUFF[1]==01)||(MBRTU_RX_BUFF[1]==02)||(MBRTU_RX_BUFF[1]==03)||(MBRTU_RX_BUFF[1]==04)||(MBRTU_RX_BUFF[1]==05)||(MBRTU_RX_BUFF[1]==06)||(MBRTU_RX_BUFF[1]==15)||(MBRTU_RX_BUFF[1]==16))//?????
                                        startRegAddr=(((u16)MBRTU_RX_BUFF[2])<<8)|MBRTU_RX_BUFF[3];
                                        if(startRegAddr<1000)
                                                calCRC=usMBCRC16(MBRTU_RX_BUFF,MBRTU_RX_CNT-2);
                                                recCRC=MBRTU_RX_BUFF[MBRTU_RX_CNT-2]|(((u16)MBRTU_RX_BUFF[MBRTU_RX_CNT-1])<<8);
                                                        if(calCRC==recCRC)
                                                        switch(MBRTU_RX_BUFF[1])
        case 1:
        Modbus_01_Solve();
        break;
        case 2:
        Modbus_02_Solve();
        break;
        case 4:
        Modbus_04_Solve();
        break;
        case 5:
        Modbus_05_Solve();
        break;
        case 15:
        Modbus_15_Solve();
        break;
        case 03:
        Modbus_03_Solve();
        break;
        case 06:
        Modbus_06_Solve();
        break;
        case 16:
        Modbus_16_Solve();
        break;
        MBRTU_TX_BUFF[0]=MBRTU_RX_BUFF[0];
        MBRTU_TX_BUFF[1]=MBRTU_RX_BUFF[1]|0x80;
        MBRTU_TX_BUFF[2]=0x04; //???
        //RS485_Send_Data(MBRTU_TX_BUFF,3);
                                        MBRTU_TX_BUFF[2]=0x02; //???
                                MBRTU_TX_BUFF[2]=0x01;
                        MBRTU_FrameFlag=0;
                        MBRTU_RX_CNT=0;
                        RS485_TX_EN=0;
void Modbus_CoilsRefresh(unsigned char *mbOuputs)
        //關聯GPIO端口
        //output
        mbOuputs[15] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_12):GPIO_ResetBits(GPIOA,GPIO_Pin_12);
        mbOuputs[14] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_11):GPIO_ResetBits(GPIOA,GPIO_Pin_11);
        mbOuputs[13] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_10) : GPIO_ResetBits(GPIOA,GPIO_Pin_10);
        mbOuputs[12] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_9) :GPIO_ResetBits(GPIOA,GPIO_Pin_9);
        mbOuputs[11] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_8): GPIO_ResetBits(GPIOA,GPIO_Pin_8);
        mbOuputs[10] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_15) : GPIO_ResetBits(GPIOB,GPIO_Pin_15);
        mbOuputs[9] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_14) : GPIO_ResetBits(GPIOB,GPIO_Pin_14);
  mbOuputs[8] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_13) : GPIO_ResetBits(GPIOB,GPIO_Pin_13);
        mbOuputs[7] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_12) : GPIO_ResetBits(GPIOB,GPIO_Pin_12);
        mbOuputs[6] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_11):GPIO_ResetBits(GPIOB,GPIO_Pin_11);
        mbOuputs[5] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_10) : GPIO_ResetBits(GPIOB,GPIO_Pin_10);
        mbOuputs[4] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_2) :GPIO_ResetBits(GPIOB,GPIO_Pin_2);
        mbOuputs[3] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_1): GPIO_ResetBits(GPIOB,GPIO_Pin_1);
        mbOuputs[2] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_0) : GPIO_ResetBits(GPIOB,GPIO_Pin_0);
        mbOuputs[1] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_7) : GPIO_ResetBits(GPIOA,GPIO_Pin_7);
        mbOuputs[0] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_6) : GPIO_ResetBits(GPIOA,GPIO_Pin_6);
void TIM2_NVIC_Configuration(void)//中斷參數配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void TIM2_Init(void)//時間中斷配置
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
        NVIC_InitTypeDef NVIC_InitStruct;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
        TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInitStruct.TIM_Period = 200-1;//300MS
        TIM_TimeBaseInitStruct.TIM_Prescaler = 7200-1;
        TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseInitStruct);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
        NVIC_InitStruct.NVIC_IRQChannel = TIM2_IRQn;
        NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStruct);
  TIM_Cmd(TIM2, ENABLE);
        TIM2_NVIC_Configuration();
void TIM3_NVIC_Configuration(void)//中斷參數配置
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
void TIM3_Init(void)//時間中斷配置
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        TIM_TimeBaseInitStruct.TIM_Period = 320-1;//32MS////////////此數值 用于 STM32主動發送時間  不可隨意更改表標準值320
        TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV2;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct);
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
        NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn;
  TIM_Cmd(TIM3, ENABLE);
        TIM3_NVIC_Configuration();
void Modbus_02_Solve(void)
        u16 ByteNum;
        u16 i;
        RegNum= (((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];
        if((startRegAddr+RegNum)<100)
                MBRTU_TX_BUFF[1]=MBRTU_RX_BUFF[1];
                ByteNum=RegNum/8;
                if(RegNum%8) ByteNum+=1;
                MBRTU_TX_BUFF[2]=ByteNum;
                for(i=0;i<RegNum;i++)
                        if(i%8==0) MBRTU_TX_BUFF[3+i/8]=0x00;
                        MBRTU_TX_BUFF[3+i/8]>>=1;
                        MBRTU_TX_BUFF[3+i/8]|=((Modbus_InputIO[startRegAddr+i])<<7)&0x80;
                        if(i==RegNum-1)
                                if(RegNum%8) MBRTU_TX_BUFF[3+i/8]>>=8-(RegNum%8);
                calCRC=usMBCRC16(MBRTU_TX_BUFF,ByteNum+3);
                MBRTU_TX_BUFF[ByteNum+3]=calCRC&0xFF;
                MBRTU_TX_BUFF[ByteNum+4]=(calCRC>>8)&0xFF;
                RS485_Send_Data(MBRTU_TX_BUFF,ByteNum+5);
void Modbus_01_Solve(void)
                u16 ByteNum;
                u16 i;
                                ByteNum=RegNum/8;
        MBRTU_TX_BUFF[3+i/8]|=((Modbus_OutputIO[startRegAddr+i])<<7)&0x80;
        if(i==RegNum-1)
void Modbus_05_Solve(void)
                if(startRegAddr<100)
                                if((MBRTU_RX_BUFF[4]==0xFF)||(MBRTU_RX_BUFF[5]==0xFF)) Modbus_OutputIO[startRegAddr]=0x01;
                                else Modbus_OutputIO[startRegAddr]=0x00;
                                MBRTU_TX_BUFF[2]=MBRTU_RX_BUFF[2];
                                MBRTU_TX_BUFF[3]=MBRTU_RX_BUFF[3];
                                MBRTU_TX_BUFF[4]=MBRTU_RX_BUFF[4];
                                MBRTU_TX_BUFF[5]=MBRTU_RX_BUFF[5];
                                calCRC=usMBCRC16(MBRTU_TX_BUFF,6);
                                MBRTU_TX_BUFF[6]=calCRC&0xFF;
                                MBRTU_TX_BUFF[7]=(calCRC>>8)&0xFF;
                                RS485_Send_Data(MBRTU_TX_BUFF,8);
void Modbus_15_Solve(void)
        u16 i;
        RegNum=(((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];
                        if(MBRTU_RX_BUFF[7+i/8]&0x01) Modbus_OutputIO[startRegAddr+i]=0x01;
                        else Modbus_OutputIO[startRegAddr+i]=0x00;
                        MBRTU_RX_BUFF[7+i/8]>>=1;
void Modbus_03_Solve(void)
                u8 i;
                RegNum= (((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];//???????
                if((startRegAddr+RegNum)<1000)//?????+??????
                                                MBRTU_TX_BUFF[2]=RegNum*2;
        MBRTU_TX_BUFF[4+i*2]= *Modbus_HoldReg[startRegAddr+i]&0xFF;
        MBRTU_TX_BUFF[3+i*2]=(*Modbus_HoldReg[startRegAddr+i]>>8)&0xFF;
                                                calCRC=usMBCRC16(MBRTU_TX_BUFF,RegNum*2+3);
                                                MBRTU_TX_BUFF[RegNum*2+3]=calCRC&0xFF;
                                                MBRTU_TX_BUFF[RegNum*2+4]=(calCRC>>8)&0xFF;
                                                RS485_Send_Data(MBRTU_TX_BUFF,RegNum*2+5);
                else//?????+??????
void Modbus_04_Solve(void)
                u8 i;
        MBRTU_TX_BUFF[4+i*2]=*Modbus_InputReg[startRegAddr+i]&0xFF;
        MBRTU_TX_BUFF[3+i*2]=(*Modbus_InputReg[startRegAddr+i]>>8)&0xFF;
void Modbus_06_Solve(void)
        *Modbus_HoldReg[startRegAddr]=MBRTU_RX_BUFF[5];//?????
        *Modbus_HoldReg[startRegAddr]|=((u16)MBRTU_RX_BUFF[4])<<8;//?????
void Modbus_16_Solve(void)
        u8 i;
                        *Modbus_HoldReg[startRegAddr+i]=MBRTU_RX_BUFF[7+i*2]; //?????
                        *Modbus_HoldReg[startRegAddr+i]|=((u16)MBRTU_RX_BUFF[8+i*2])<<8; //?????
void TIM3_IRQHandler(void)////定時3中斷啟用
        if(TIM_GetITStatus(TIM3, TIM_IT_Update) == SET)
          RTU_05 (); //主站主動發送函數
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
                MBRTU_FrameFlag=1;//定時中斷啟用RTU中間量
u8 RS485_TX_BUFF[12];//發送緩沖區
char set[11]={01,15,00,00,00,16,02,00,00,00,00};//存放15個燈代碼
u16 shuzuB[16];//用來存放計算出的15個值
u16 c,x[16];
char A[8]={1,0,0,1,1,1,1,1};//低位16-24
char B[8]={0,0,1,1,1,1,1,1};//高位25-31  前八個
void RTU_05 (void)//主站主動發送函數
        //if(A[0]==1||A[01]==1||A[2]==1||A[3]==1||A[4]==1||A[5]==1||A[6]==1||A[7]==01)
                        shuzuB[15] = A[7]*128; //0000  0001   01  1
                  shuzuB[14] = A[6]*64; //0000  0010                02        2      7-----------0
                        shuzuB[13] = A[5]*32; //0000  0100                04        3
                        shuzuB[12] = A[4]*16; //0000  1000                08         4
                        shuzuB[11] = A[3]*8;  //0001  0000                10        5
                        shuzuB[10] = A[2]*4;  //0010  0000                20        6
                        shuzuB[9]  = A[1]*2;   //0100  0000                40        7
                        shuzuB[8]  = A[0] *1;  //1000  0000                80        8
           set[7] = shuzuB[8]+shuzuB[9]+shuzuB[10]+shuzuB[11]+shuzuB[12]+shuzuB[13]+shuzuB[14]+shuzuB[15];
//if(B[0]==1||B[01]==1||B[2]==1||B[3]==1||B[4]==1||B[5]==1||B[6]==1||B[7]==01)
                        shuzuB[7] = B[7]*128;  //0000  0001   01  1
                  shuzuB[6] = B[6]*64;  //0000  0010                02        2
                        shuzuB[5] = B[5]*32;  //0000  0100                04        3
                        shuzuB[4] = B[4]*16;  //0000  1000                08         4    低位  7------------0
                        shuzuB[3] = B[3]*8;   //0001  0000                10        5
                        shuzuB[2] = B[2]*4;   //0010  0000                20        6
                        shuzuB[1] = B[1]*2;   //0100  0000                40        7
                        shuzuB[0] = B[0]*1;   //1000  0000                80        8
                        set[8] =shuzuB[0]+shuzuB[1]+shuzuB[2]+shuzuB[3]+shuzuB[4]+shuzuB[5]+shuzuB[6]+shuzuB[7];
                                RS485_TX_BUFF[0]=set[0];
        RS485_TX_BUFF[1]=set[1];
        RS485_TX_BUFF[2]=set[2];
        RS485_TX_BUFF[3]=set[3];
        RS485_TX_BUFF[4]=set[4];
                                RS485_TX_BUFF[5]=set[5];
        RS485_TX_BUFF[6]=set[6];
                                RS485_TX_BUFF[7]= set[7];//
        RS485_TX_BUFF[8]= set[8];    //
                                calCRC=usMBCRC16(RS485_TX_BUFF,9);
                                RS485_TX_BUFF[9]=calCRC&0xFF;
                                RS485_TX_BUFF[10]=(calCRC>>8)&0xFF;
                                RS485_Send_Data(RS485_TX_BUFF,11);
void view32(void)
        view[15] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_12):GPIO_ResetBits(GPIOA,GPIO_Pin_12);
        view[14] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_11):GPIO_ResetBits(GPIOA,GPIO_Pin_11);
        view[13] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_10) : GPIO_ResetBits(GPIOA,GPIO_Pin_10);
        view[12] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_9) :GPIO_ResetBits(GPIOA,GPIO_Pin_9);
        view[11] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_8): GPIO_ResetBits(GPIOA,GPIO_Pin_8);
        view[10] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_15) : GPIO_ResetBits(GPIOB,GPIO_Pin_15);
        view[9] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_14) : GPIO_ResetBits(GPIOB,GPIO_Pin_14);
  view[8] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_13) : GPIO_ResetBits(GPIOB,GPIO_Pin_13);
        view[7] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_12) : GPIO_ResetBits(GPIOB,GPIO_Pin_12);
        view[6] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_11):GPIO_ResetBits(GPIOB,GPIO_Pin_11);
        view[5] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_10) : GPIO_ResetBits(GPIOB,GPIO_Pin_10);
        view[4] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_2) :GPIO_ResetBits(GPIOB,GPIO_Pin_2);
        view[3] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_1): GPIO_ResetBits(GPIOB,GPIO_Pin_1);
        view[2] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_0) : GPIO_ResetBits(GPIOB,GPIO_Pin_0);
        view[1] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_7) : GPIO_ResetBits(GPIOA,GPIO_Pin_7);
        view[0] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_6) : GPIO_ResetBits(GPIOA,GPIO_Pin_6);
/*RS485驅動 代碼*/
//485初始化
  void RS485_Config(u32 bound)
                 USART_InitTypeDef usart;
        GPIO_InitTypeDef usart1;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//啟用時鐘
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
        usart1.GPIO_Pin=GPIO_Pin_6;                           //PB6端口配置TX
        usart1.GPIO_Speed=GPIO_Speed_50MHz;
        usart1.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB, &usart1);
        usart1.GPIO_Pin=GPIO_Pin_7;
        usart1.GPIO_Speed=GPIO_Speed_50MHz;//PB7//PB7端口配置RX
        usart1.GPIO_Mode=GPIO_Mode_IN_FLOATING;
        usart.USART_BaudRate= bound;                                 //波特率
        usart.USART_WordLength=USART_WordLength_8b;//8位數據長度設置
        usart.USART_StopBits = USART_StopBits_1;//一位停止位
        usart.USART_Parity =USART_Parity_No;//校驗位
        usart.USART_HardwareFlowControl=USART_HardwareFlowControl_None;//無硬件數據流
        usart.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;//收發模式
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;               //選擇串口1中斷
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //響應式中斷優先級設置為2級
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;//先占優先級為2級
        NVIC_Init(&NVIC_InitStructure);//根據NVICInitStructure制定參數初始化NVIC寄存器
        USART_Init(USART1, &usart);//初始化串口
        USART_Cmd(USART1, ENABLE);//使能串口
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);        // //開啟中斷
        RS485_TX_EN=0;//默認為接收模式
//發送n個字節數據
//buff:發送區首地址
//len:發送的字節數
void  RS485_Send_Data(u8 *buf,u8 len) //modbus發送數據函數
          RS485_TX_EN=1;//切換為發送模式
                while(len--)
                        while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待發送區為空
                        USART_SendData(USART1,*(buf++));
                        while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET);
                        //等待發送完成
                  RS485_TX_EN=0;//切換為接收模式
static const UCHAR aucCRCHi[] = {
    0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
    0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
    0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
    0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
    0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
static const UCHAR aucCRCLo[] = {
    0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
    0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
    0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
    0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
    0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
    0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
    0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
    0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
    0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
    0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
    0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
    0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
    0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
    0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
    0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
    0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
    0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
    0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
    0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
    0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
    0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
    0x41, 0x81, 0x80, 0x40
USHORT
    UCHAR           ucCRCHi = 0xFF;
    UCHAR           ucCRCLo = 0xFF;
    int             iIndex;
    while( usLen-- )
        iIndex = ucCRCLo ^ *( pucFrame++ );
        ucCRCLo = ( UCHAR )( ucCRCHi ^ aucCRCHi[iIndex] );
        ucCRCHi = aucCRCLo[iIndex];
    return ( USHORT )( ucCRCHi << 8 | ucCRCLo );
ID:1 發表于 2018-10-23 15:55 | 顯示全部樓層
樓主能分享下工程包嗎?
ID:403544 發表于 2018-10-24 09:47 | 顯示全部樓層
admin 發表于 2018-10-23 15:55
樓主能分享下工程包嗎?
我找了半天沒有找到添加的地方我再看看
ID:188720 發表于 2018-10-24 10:54 | 顯示全部樓層
請問有沒有51單片機做主站的代碼?
ID:403544 發表于 2018-10-24 16:34 | 顯示全部樓層
紅燒魚頭 發表于 2018-10-24 10:54
請問有沒有51單片機做主站的代碼?
有的 第一段就是主站  我這里有主站和從站的都可以直接用
ID:245836 發表于 2018-11-16 15:03 | 顯示全部樓層
好,收藏了
ID:413674 發表于 2019-1-17 09:24 | 顯示全部樓層
樓主有stm32的從站modbus協議嗎,發我一份看看,謝謝!郵箱:591166140@qq.com
ID:448641 發表于 2019-1-24 10:58 | 顯示全部樓層
沒有下載地址
ID:719420 發表于 2020-3-31 11:56 | 顯示全部樓層
樓主,你好,可以分享這個工程嗎?
ID:111310 發表于 2021-8-27 01:06 | 顯示全部樓層
有工程包最好
