T6963C 240x128 液晶顯示屏是由東芝公司生產的產品,也是目前比較流行的顯示屏之一。以下是一個簡單的測試小程序,希望大家能夠喜歡。
- #include "__T6963C.h"
- // T6963C module connections
- char T6963C_dataPort at P3; // DATA port
- sbit T6963C_ctrlwr at P2_2_bit; // WR write signal
- sbit T6963C_ctrlrd at P2_1_bit; // RD read signal
- sbit T6963C_ctrlcd at P2_0_bit; // CD command/data signal
- sbit T6963C_ctrlrst at P2_4_bit; // RST reset signal
- // Signals not used by library, they are set in main function
- sbit T6963C_ctrlce at P2_3_bit; // CE signal
- sbit T6963C_ctrlfs at P2_6_bit; // FS signal
- sbit T6963C_ctrlmd at P2_5_bit; // MD signal
- // End T6963C module connections
- * bitmap pictures stored in ROM
- const code char mikroE_240x128_bmp[];
- const code char einstein[];
- void main() {
- char idata txt1[] = " EINSTEIN WOULD HAVE LIKED mE";
- char idata txt[] = " GLCD LIBRARY DEMO, WELCOME !";
- unsigned char panel; // Current panel
- unsigned int i; // General purpose register
- unsigned char curs; // Cursor visibility
- unsigned int cposx, cposy; // Cursor x-y position
- #define COMPLETE_EXAMPLE // comment this line to make simpler/smaller example
- T6963C_ctrlce = 0; // Enable T6963C
- T6963C_ctrlfs = 0; // Font Select 8x8
- T6963C_ctrlmd = 0; // Column number select
- // Initialize T6963C
- T6963C_init(240, 128, 8);
- * Enable both graphics and text display at the same time
- T6963C_graphics(1);
- T6963C_text(1);
- panel = 0;
- i = 0;
- curs = 0;
- cposx = cposy = 0;
- * Text messages
- T6963C_write_text(txt, 0, 0, T6963C_ROM_MODE_XOR);
- T6963C_write_text(txt1, 0, 15, T6963C_ROM_MODE_XOR);
- * Cursor
- T6963C_cursor_height(8); // 8 pixel height
- T6963C_set_cursor(0, 0); // Move cursor to top left
- T6963C_cursor(0); // Cursor off
- * Draw rectangles
- T6963C_rectangle(0, 0, 239, 127, T6963C_WHITE);
- T6963C_rectangle(20, 20, 219, 107, T6963C_WHITE);
- T6963C_rectangle(40, 40, 199, 87, T6963C_WHITE);
- T6963C_rectangle(60, 60, 179, 67, T6963C_WHITE);
- * Draw a cross
- T6963C_line(0, 0, 239, 127, T6963C_WHITE);
- T6963C_line(0, 127, 239, 0, T6963C_WHITE);
- * Draw solid boxes
- T6963C_box(0, 0, 239, 8, T6963C_WHITE);
- T6963C_box(0, 119, 239, 127, T6963C_WHITE);
- #ifdef COMPLETE_EXAMPLE
- * Draw circles
- T6963C_circle(120, 64, 10, T6963C_WHITE);
- T6963C_circle(120, 64, 30, T6963C_WHITE);
- T6963C_circle(120, 64, 50, T6963C_WHITE);
- T6963C_circle(120, 64, 70, T6963C_WHITE);
- T6963C_circle(120, 64, 90, T6963C_WHITE);
- T6963C_circle(120, 64, 110, T6963C_WHITE);
- T6963C_circle(120, 64, 130, T6963C_WHITE);
- T6963C_sprite(76, 4, einstein, 88, 119); // Draw a sprite
- T6963C_setGrPanel(1); // Select other graphic panel
- T6963C_image(mikroE_240x128_bmp); // Draw an image
- #endif
- for(;;) { // Endless loop
- * If P1.0 is pressed, display only graphic panel
- if(!P1_0_bit) {
- T6963C_text(0);
- Delay_ms(300);
- * If P1.1 is pressed, toggle the display between graphic panel 0 and graphic panel 1
- else if(!P1_1_bit) {
- panel++;
- panel &= 1;
- T6963C_displayGrPanel(panel);
- Delay_ms(300);
- #endif
- * If P1.2 is pressed, display only text panel
- else if(!P1_2_bit) {
- T6963C_graphics(0);
- T6963C_text(1);
- Delay_ms(300);
- * If P1.3 is pressed, display text and graphic panels
- else if(!P1_3_bit) {
- T6963C_text(1);
- Delay_ms(300);
- * If P1.4 is pressed, change cursor
- else if(!P1_4_bit) {
- curs++;
- if(curs == 3) curs = 0;
- switch(curs) {
- case 0:
- // no cursor
- T6963C_cursor(0);
- break;
- case 1:
- // blinking cursor
- T6963C_cursor(1);
- T6963C_cursor_blink(1);
- break;
- case 2:
- // non blinking cursor
- T6963C_cursor(1);
- T6963C_cursor_blink(0);
- break;
- Delay_ms(300);
- * Move cursor, even if not visible
- cposx++;
- if(cposx == T6963C_txtCols) {
- cposx = 0;
- cposy++;
- if(cposy == T6963C_grHeight / T6963C_CHARACTER_HEIGHT) {
- cposy = 0;
- T6963C_set_cursor(cposx, cposy);
- Delay_ms(100);
復制代碼 相關信息:http://www.raoushi.com/bbs/dpj-136722-1.html
2018-10-23 09:04 上傳
