查看: 1442|回復: 1
安防報警器的單片機程序
ID:413418 發(fā)表于 2018-10-22 13:45 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
sbit red=P1^2;
sbit green=P1^1;
sbit spe=P1^0;
sbit bjjc=P1^3;
sbit mjbj=P3^2;
sbit hwbj=P3^3;
void delay(uint ms);
void baojin();
void init0();
void init1();
        P2=0x00;
        delay(100);
                P2=0x3f;
                red=1;
                green=0;
                spe=1;
                IE=0x8f; //10001111
                IP=0x05; //00000101
void delay(uint ms)
        uchar i;
        while(ms--)
                   for(i=0;i<120;i++);
void baojin()
                green=1;
                red=0;
                spe=~spe;
                delay(100);
                red=1;
                delay(100);
                if(!bjjc)
                        P2=0x00;
                        break;
void init0() interrupt 0
        delay(10);
        while(!mjbj&hwbj)
                P2=0x06;  //00000110
                baojin();
void init1() interrupt 2
        delay(10);
        while(mjbj&!hwbj)
                P2=0x5b;//01011011
                baojin();
ID:1 發(fā)表于 2018-10-22 15:30 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
