查看: 3318|回復: 5
新人求助 51單片機紅外控制小燈亮滅,怎么改這個程序
#include "reg52.h"    //??????ж????????????Щ??????????
typedef unsigned int u16;   //?????????????????????
typedef unsigned char u8;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit led=P2^0;
sbit IRIN=P3^2;
u8 IrValue[6];
u8 Time;
u8 DisplayData[8];
u8 code smgduan[17]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0X76};
//0??1??2??3??4??5??6??7??8??9??A??b??C??d??E??F??H???????
* ?? ?? ??         : delay
* ????????     : ?????????i=1?????????10us
void delay(u16 i)
while(i--);
* ??????         :DigDisplay()
void DigDisplay()
u8 i;
for(i=0;i<3;i++)
  switch(i)  //λ?????????????????
   case(0):
    LSA=0;LSB=0;LSC=0; break;//?????0λ
   case(1):
    LSA=1;LSB=0;LSC=0; break;//?????1λ
   case(2):
    LSA=0;LSB=1;LSC=0; break;//?????2λ
  P0=DisplayData[2-i];//????????
  delay(100); //????????????
  P0=0x00;//????
* ??????         : IrInit()
void IrInit()
IT0=1;//????????
EX0=1;//???ж?0????
EA=1; //?????ж?
IRIN=1;//????????
* ?? ?? ??       : main
IrInit();
  DisplayData[0] = smgduan[IrValue[2]/16];
  DisplayData[1] = smgduan[IrValue[2]%16];
  DisplayData[2] = smgduan[16];
//     if((DisplayData[0]==0x3f)&&(DisplayData[1]==0x39)&&(DisplayData[2]==0x76))
//  led=!led;
  DigDisplay();
* ??????         : ReadIr()
* ????????     : ?????????????ж????
void ReadIr() interrupt 0
u8 j,k;
u16 err;
Time=0;
delay(700); //7ms
if(IRIN==0)  //?????????????????????
  err=1000;    //1000*10us=10ms,????????????????????
  /*????????????????????????????????????????????????????ó????????
  while((IRIN==0)&&(err>0))
   delay(1);
   err--;
  if(IRIN==1)
   err=500;
   while((IRIN==1)&&(err>0))
    delay(1);
    err--;
   for(k=0;k<4;k++)
    for(j=0;j<8;j++)
     err=60;
      delay(1);
      err--;
     err=500;
      delay(10);  //0.1ms
      Time++;
      err--;
      if(Time>30)
       return;
     IrValue[k]>>=1;  //k????????????
     if(Time>=8)
      IrValue[k]|=0x80;
     Time=0;  //??????????????
  if(IrValue[2]!=~IrValue[3])
   return;
ID:413475 發表于 2018-10-22 15:17 | 只看該作者
如果只是想按一下遙控器小燈亮,再按一下小燈滅,只要在中斷函數 void ReadIr() interrupt 0
u8 j,k;
u16 err;后增加led=!led;就實現了!
參與人數 1黑幣 +60 收起 理由
admin + 60 回帖助人的獎勵!
ID:413475 發表于 2018-10-22 15:18 | 只看該作者
ID:164602 發表于 2018-10-23 08:44 | 只看該作者
你的程序不對啊,按遙控器后,根本不能接收到有效的鍵碼。
我有一個程序,可以做到紅外遙控,你只要遙控燈,我就只放了這個功能。
紅外遙控示例程序
#include<reg51.h>
#include<intrins.h>
#define LED P2//LED燈
sbit HWX=P3^2;//紅外接收管在I/O口
unsigned char HWXSJ[4];
bit JSCG=1;
void Config();
void delay(void)//延時35.5us
        unsigned char i=10;
        while(i--);
void Delay10ms(unsigned char c)
    unsigned char a,b;
    for(;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
        Config();
        LED=0xff;//初始化關燈
                if (JSCG==1)
                        JSCG=0;
                        if (HWXSJ[2]==0x45)//遙控器上電源開關鍵
                                LED=~LED;
void Config()
        IT0=1;
        EX0=1;
        EA=1;
        TMOD=0X10;
        HWX=1;
        unsigned char i,ia;
        TL1=0;
        TH1=0;
        TR1=1;
        while(!HWX)
                if (TH1>40)
                        TR1=0;
                        TL1=0;
                        TH1=0;
                        return;
        TR1=0;
        if(TH1<25)
                return;
        TH1=0;
        TL1=0;
        TR1=1;
        while(HWX)
                delay();
                if(TH1>25)
                        TR1=0;
                        TL1=0;
                        TH1=0;
                        return;
        TR1=0;
        if(TH1<15)
                return;
        for(i=0;i<4;i++)
                for(ia=0;ia<8;ia++)
                        TL1=0;
                        TH1=0;
                        TR1=1;
                        while(!HWX)
                                if(TH1>5)
                                        TR1=0;
                                        TL1=0;
                                        TH1=0;
                                        return;
                        TR1=0;
                        TH1=0;
                        TL1=0;
                        TR1=1;
                        while(HWX)
                                delay();
                                if(TH1>10)
                                        TR1=0;
                                        TL1=0;
                                        TH1=0;
                                        return;
                        TR1=0;
                        HWXSJ[i]>>=1;
                        if(TH1>4)
                                HWXSJ[i]|=0x80;
        if ((HWXSJ[0]==~HWXSJ[1])&&(HWXSJ[2]==~HWXSJ[3]))
                JSCG=1;
                JSCG=0;
參與人數 2黑幣 +108 收起 理由
admin + 100 回帖助人的獎勵!
xiou + 8 很給力!
ID:164602 發表于 2018-10-23 08:46 | 只看該作者
補充電路圖:
參與人數 1黑幣 +8 收起 理由
xiou + 8 贊一個!
ID:405273 發表于 2018-10-23 14:38 | 只看該作者
                JSCG=1;
                JSCG=0;
這個程序能否解釋一下 麻煩大佬。
