STM32F103控制PCA9685舵機驅(qū)動板
- #include "pca9685.h"
- #include "myiic.h"
- #include "delay.h"
- #include "math.h"
- void pca_write(u8 adrr,u8 data)//向PCA寫數(shù)據(jù),adrrd地址,data數(shù)據(jù)
- IIC_Start();
- IIC_Send_Byte(pca_adrr);
- IIC_Wait_Ack();
- IIC_Send_Byte(adrr);
- IIC_Wait_Ack();
- IIC_Send_Byte(data);
- IIC_Wait_Ack();
- IIC_Stop();
- u8 pca_read(u8 adrr)//從PCA讀數(shù)據(jù)
- u8 data;
- IIC_Start();
- IIC_Wait_Ack();
- IIC_Wait_Ack();
- IIC_Start();
- IIC_Send_Byte(pca_adrr|0x01);
- IIC_Wait_Ack();
- data=IIC_Read_Byte(0);
- IIC_Stop();
- return data;
- void pca_setfreq(float freq)//設(shè)置PWM頻率
- u8 prescale,oldmode,newmode;
- double prescaleval;
- freq *= 0.92;
- prescaleval = 25000000;
- prescaleval /= 4096;
- prescaleval /= freq;
- prescaleval -= 1;
- prescale =floor(prescaleval + 0.5f);
- oldmode = pca_read(pca_mode1);
- newmode = (oldmode&0x7F) | 0x10; // sleep
- pca_write(pca_mode1, newmode); // go to sleep
- pca_write(pca_pre, prescale); // set the prescaler
- pca_write(pca_mode1, oldmode);
- delay_ms(2);
- pca_write(pca_mode1, oldmode | 0xa1);
- void pca_setpwm(u8 num, u32 on, u32 off)
- pca_write(LED0_ON_L+4*num,on);
- pca_write(LED0_ON_H+4*num,on>>8);
- pca_write(LED0_OFF_L+4*num,off);
- pca_write(LED0_OFF_H+4*num,off>>8);
- /*num:舵機PWM輸出引腳0~15,on:PWM上升計數(shù)值0~4096,off:PWM下降計數(shù)值0~4096
- 一個PWM周期分成4096份,由0開始+1計數(shù),計到on時跳變?yōu)楦唠娖剑^續(xù)計數(shù)到off時
- 跳變?yōu)榈碗娖剑钡接嫕M4096重新開始。所以當on不等于0時可作延時,當on等于0時,
- off/4096的值就是PWM的占空比。*/
- 函數(shù)作用:初始化舵機驅(qū)動板
- 參數(shù):1.PWM頻率
- 2.初始化舵機角度
- void PCA_MG9XX_Init(float hz,u8 angle)
- u32 off=0;
- IIC_Init();
- pca_write(pca_mode1,0x0);
- pca_setfreq(hz);//設(shè)置PWM頻率
- off=(u32)(145+angle*2.4);
- pca_setpwm(0,0,off);pca_setpwm(1,0,off);pca_setpwm(2,0,off);pca_setpwm(3,0,off);
- pca_setpwm(4,0,off);pca_setpwm(5,0,off);pca_setpwm(6,0,off);pca_setpwm(7,0,off);
- pca_setpwm(8,0,off);pca_setpwm(9,0,off);pca_setpwm(10,0,off);pca_setpwm(11,0,off);
- pca_setpwm(12,0,off);pca_setpwm(13,0,off);pca_setpwm(14,0,off);pca_setpwm(15,0,off);
- delay_ms(500);
- 函數(shù)作用:控制舵機轉(zhuǎn)動;
- 參數(shù):1.輸出端口,可選0~15;
- 2.起始角度,可選0~180;
- 3.結(jié)束角度,可選0~180;
- 4.模式選擇,0 表示函數(shù)內(nèi)無延時,調(diào)用時需要在函數(shù)后另外加延時函數(shù),且不可調(diào)速,第五個參數(shù)可填任意值;
- 1 表示函數(shù)內(nèi)有延時,調(diào)用時不需要在函數(shù)后另外加延時函數(shù),且不可調(diào)速,第五個參數(shù)可填任意值;
- 2 表示速度可調(diào),第五個參數(shù)表示速度值;
- 5.速度,可填大于 0 的任意值,填 1 時速度最快,數(shù)值越大,速度越小;
- 注意事項:模式 0和1 的速度比模式 2 的最大速度大;
- void PCA_MG9XX(u8 num,u8 start_angle,u8 end_angle,u8 mode,u8 speed)
- u8 i;
- u32 off=0;
- switch(mode)
- case 0:
- off=(u32)(158+end_angle*2.2);
- pca_setpwm(num,0,off);
- break;
- case 1:
- if(end_angle>start_angle){delay_ms((u16)((end_angle-start_angle)*2.7));}
- else{delay_ms((u16)((start_angle-end_angle)*2.7));}
- break;
- case 2:
- for(i=start_angle;i<=end_angle;i++)
- off=(u32)(158+i*2.2);
- delay_ms(2);
- delay_us(speed*250);
- else if(start_angle>end_angle)
- for(i=start_angle;i>=end_angle;i--)
- delay_ms(2);
- break;
PCA9685_MG996R.rar
(826.45 KB, 下載次數(shù): 504)
2018-10-19 20:18 上傳
下載積分: 黑幣 -5
