#include"IIC.h"
#include"OLEDFont.h"
#include "Timer0.h"
*函數(shù)名: void Init_IIC(void)
*函數(shù)功能:IIC 初始化
*輸入?yún)?shù):
*輸出參數(shù):
*Design By: huangrliang
* 說(shuō)明:
void Init_IIC(void)
TRISCbits.TRISC3 = 1; //Configure SCL
TRISCbits.TRISC4 = 1; //Configure SDA
SSPSTAT = 0x80; //Disable SMBus &
SSPCON1 = 0x00; //
SSPCON1bits.SSPM=0B1000;//I2C 主模式,時(shí)鐘為FOSC/(4*(SSPAD+1))
//SSPCON1 = 0x28; //Enable MSSP Master
SSPADD =0x27;//0x9F; //Should be 0x9F 100kHz @FOSC=64MHz
SSPCON2 = 0x00; //Clear MSSP Conrol Bits
PIR1bits.SSPIF=0; //中斷標(biāo)志清零
SSPCON1bits.SSPEN=1;//使能串口并將SDA和SCL引腳配置為串口引腳
*函數(shù)名:signed char WriteI2C( unsigned char data_out )
*函數(shù)功能:IIC寫時(shí)序
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
SSPBUF = data_out; //Load byte to I2C1 Transmit buffer
while (SSPSTATbits.BF); //等待發(fā)送完成 //發(fā)送狀態(tài)位 1 ,正在發(fā)送
if(SSPCON1bits.WCOL)
SSPCON1bits.WCOL=0;
函數(shù):I2C_GetAck()
功能:讀取從機(jī)應(yīng)答位
返回:
0:從機(jī)應(yīng)答
1:從機(jī)非應(yīng)答
說(shuō)明:
從機(jī)在收到每個(gè)字節(jié)的數(shù)據(jù)后,要產(chǎn)生應(yīng)答位
從機(jī)在收到最后1個(gè)字節(jié)的數(shù)據(jù)后,一般要產(chǎn)生非應(yīng)答位
char I2C_GetAck()
return (SSPCON2bits.ACKSTAT); //Return Ack Status
* Function Name: LDByteWriteI2C *
* Parameters: EE memory ControlByte, address and data *
* Description: Writes data one byte at a time to I2C EE *
* device. This routine can be used for any I2C *
* EE memory device, which only uses 1 byte of *
* address data as in the 24LC01B/02B/04B/08B/16B. *
unsigned char LDByteWriteI2C( unsigned char ControlByte, unsigned char LowAdd, unsigned char data )
IdleI2C(); // ensure module is idle
StartI2C(); // initiate START condition
while ( SSPCON2bits.SEN ); // wait until start condition is over
WriteI2C( ControlByte ); // write 1 byte - R/W bit should be 0
if ( I2C_GetAck() ) //讀從機(jī)應(yīng)答信號(hào),0,表示收到從機(jī)應(yīng)答,1表示沒(méi)有收到從機(jī)應(yīng)答
StopI2C();
return 1;
WriteI2C( LowAdd ); // write address byte to EEPROM
StopI2C();
return 1;
WriteI2C ( data ); // Write data byte to EEPROM
StopI2C();
return 1;
StopI2C(); // send STOP condition
while ( SSPCON2bits.PEN ); // wait until stop condition is over
usDelay(5);
return ( 0 ); // return with no error
*函數(shù)名: void Write_IIC_Command(unsigned char IIC_Command)
*函數(shù)功能: IIC 寫命令到12864
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
LDByteWriteI2C(0x78,0x00,IIC_Command);
*函數(shù)名: void Write_IIC_Data(unsigned char IIC_Data)
*函數(shù)功能: IIC 寫數(shù)據(jù)到12864
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
LDByteWriteI2C(0x78,0x40,IIC_Data);
*函數(shù)名: void OLED_WR_Byte(unsigned dat,unsigned cmd)
*函數(shù)功能: OLED寫一個(gè)字節(jié)
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
if(cmd)
LDByteWriteI2C(0x78,0x40,dat);
LDByteWriteI2C(0x78,0x00,dat);
*函數(shù)名: void OLED_Set_Pos(unsigned char x, unsigned char y)
*函數(shù)功能://坐標(biāo)設(shè)置
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
OLED_WR_Byte(0xB0+y,OLED_CMD); //設(shè)置page 0-7
OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD); //set high column address 顯存的地址為0-132,液晶的地址為0-128,所以設(shè)置起點(diǎn)為2(列地址2-130對(duì)應(yīng)0-128)
OLED_WR_Byte((x&0x0f)|0x01,OLED_CMD); //set low column address
*函數(shù)名: void OLED_Display_On(void)
*函數(shù)功能:開(kāi)啟OLED顯示
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
*函數(shù)功能:關(guān)閉OLED顯示
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
void OLED_Display_Off(void)
OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
*函數(shù)名: void OLED_Clear(void)
*函數(shù)功能:清屏函數(shù),清完屏,整個(gè)屏幕是黑色的!和沒(méi)點(diǎn)亮一樣!!!
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
unsigned char i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD); //設(shè)置頁(yè)地址(0~7)
OLED_WR_Byte (0x02,OLED_CMD); //設(shè)置顯示位置?列低地址
OLED_WR_Byte (0x10,OLED_CMD); //設(shè)置顯示位置?列高地址
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
} //更新顯示
*函數(shù)名: void OLED_OnAll(void)
*函數(shù)功能:全部點(diǎn)亮
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
unsigned char i,n;
for(i=0;i<8;i++)
for(n=0;n<128;n++)OLED_WR_Byte(0xFF,OLED_DATA);
} //更新顯示
*函數(shù)名: void OLED_Init(void)
*函數(shù)功能://初始化SSD1306
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
Init_IIC();
ms_Delay(1000);
ms_Delay(1000);
ms_Delay(1000);
ms_Delay(1000);
OLED_WR_Byte(0xAE,OLED_CMD);//--display off
OLED_WR_Byte(0x02,OLED_CMD);//---set low column address
OLED_WR_Byte(0x10,OLED_CMD);//---set high column address //顯存的地址為0-132,液晶的地址為0-128,所以設(shè)置起點(diǎn)為2(列地址2-130對(duì)應(yīng)0-128)
OLED_WR_Byte(0x40,OLED_CMD);//--set start line address //設(shè)置行地址,0-63,0x40 對(duì)應(yīng)0行,0x7F 對(duì)應(yīng)63行
OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
OLED_WR_Byte(0x81,OLED_CMD); // contract control 對(duì)比度設(shè)置命令
OLED_WR_Byte(0xFF,OLED_CMD);//--128 對(duì)比度設(shè)置參數(shù)00~FF
OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap 掃描順序向右
OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse 正常顯示,RAM為1,點(diǎn)亮對(duì)應(yīng)OLED
OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)//多路復(fù)用
OLED_WR_Byte(0x3F,OLED_CMD);//--1/64 duty //多路復(fù)用
OLED_WR_Byte(0xAD,OLED_CMD);//set charge pump enable // DC-DC Control Mode
OLED_WR_Byte(0x8B,OLED_CMD);//-0x8B 內(nèi)供 VCC // DC-DC Control Mode
OLED_WR_Byte(0x33,OLED_CMD);//-0X30---0X33 set VPP 9V pump 電壓
OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction //設(shè)置掃描方向When C8, Scan from COM [N -1] to COM0.
OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset//行顯示偏移
OLED_WR_Byte(0x00,OLED_CMD);// //行顯示偏移
OLED_WR_Byte(0xD5,OLED_CMD);//set osc division //設(shè)置時(shí)鐘
OLED_WR_Byte(0x80,OLED_CMD);// //設(shè)置時(shí)鐘
OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
OLED_WR_Byte(0x05,OLED_CMD);//
OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
OLED_WR_Byte(0x1F,OLED_CMD);//
OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
OLED_WR_Byte(0x12,OLED_CMD);//
OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
*函數(shù)名: void OLED_ShowCHinese(u8 x,u8 y,u8 no)
*函數(shù)功能:顯示漢字
*輸入?yún)?shù): x,=0-128;y=0,2,4,6
*輸出參數(shù):
* 說(shuō)明:
{0x00,0x00,0x00,0xF8,0x88,0x8C,0x8A,0x89,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0xFF,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,0x00,0x00},
u8 t;
OLED_Set_Pos(x,y);
for(t=0;t<16;t++)
OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
OLED_Set_Pos(x,y+1);
for(t=0;t<16;t++)
OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
*函數(shù)名: void OLED_ShowNum24x24(u8 x,u8 y,u8 no)
*函數(shù)功能:顯示24x24的數(shù)字,對(duì)應(yīng)每天工作 x 小時(shí)
*輸入?yún)?shù):
*輸出參數(shù):
* 說(shuō)明:
{0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x40,0x40,0x40,0x80,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0xF0,0xFE,0x0F,0x01,0x00,0x00,0x00,0x00,0x01,0x07,0xFE,0xF0,0x00,0x00},
{0x00,0x00,0x3F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xFF,0x3F,0x00,0x00},
{0x00,0x00,0x00,0x01,0x03,0x06,0x0C,0x08,0x08,0x08,0x06,0x03,0x01,0x00,0x00,0x00},
void OLED_ShowNum16x32(u8 x,u8 y,u8 no) //一個(gè)數(shù)字占 16列,32行
u8 t;
OLED_Set_Pos(x,y);
for(t=0;t<16;t++)
OLED_WR_Byte(Num16x32[2*no][t],OLED_DATA);
for(t=0;t<16;t++)
OLED_WR_Byte(Num16x32[2*no+1][t],OLED_DATA);
