查看: 9193|回復(fù): 13
STM32控制WS2812B燈的源碼
ID:407563 發(fā)表于 2018-10-10 15:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這個(gè)文件很有用,分享給大家
單片機(jī)源程序如下:
  1. #include "WS2812B.h"
  2. /* Buffer that holds one complete DMA transmission
  3. *
  4. * Ensure that this buffer is big enough to hold
  5. * all data bytes that need to be sent
  6. *
  7. * The buffer size can be calculated as follows:
  8. * number of LEDs * 24 bytes + 42 bytes
  9. *
  10. * This leaves us with a maximum string length of
  11. * (2^16 bytes per DMA stream - 42 bytes)/24 bytes per LED = 2728 LEDs
  12. */
  13. //#define TIM3_CCR3_Address 0x4000043c         // physical memory address of Timer 3 CCR1 register
  14. //#define TIM3_CCR1_Address 0x40000434        // physical memory address of Timer 3 CCR1 register
  15. #define TIM2_CCR1_Address 0x40000034
  16.
  17. #define TIMING_ONE  50
  18. #define TIMING_ZERO 25
  19. uint16_t LED_BYTE_Buffer[300];
  20. //---------------------------------------------------------------//
  21. void Timer2_init(void)
  22. {
  23.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  24.   TIM_OCInitTypeDef  TIM_OCInitStructure;
  25.   GPIO_InitTypeDef GPIO_InitStructure;
  26.   DMA_InitTypeDef DMA_InitStructure;
  27.
  28.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  29.         /* GPIOA Configuration: TIM2 Channel 1 as alternate function push-pull */
  30.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  31.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  32.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  33.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  34.
  35.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  36.         /* Compute the prescaler value */
  37.         //PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  38.         /* Time base configuration */
  39.         TIM_TimeBaseStructure.TIM_Period = 90-1; // 800kHz
  40.         TIM_TimeBaseStructure.TIM_Prescaler = 0;
  41.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  42.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  43.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  44.         /* PWM1 Mode configuration: Channel1 */
  45.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  46.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  47.         TIM_OCInitStructure.TIM_Pulse = 0;
  48.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  49.         TIM_OC1Init(TIM2, &TIM_OCInitStructure);
  50.
  51.         /* configure DMA */
  52.         /* DMA clock enable */
  53.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  54.
  55.         /* DMA1 Channel6 Config */
  56.         DMA_DeInit(DMA1_Channel2);
  57.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM2_CCR1_Address;        // physical address of Timer 3 CCR1
  58.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                // this is the buffer memory
  59.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                // data shifted from memory to peripheral
  60.         DMA_InitStructure.DMA_BufferSize = 42;
  61.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  62.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        // automatically increase buffer index
  63.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  64.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  65.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                                        // stop DMA feed after buffer size is reached
  66.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  67.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  68.
  69.         DMA_Init(DMA1_Channel2, &DMA_InitStructure);
  70.                 /* TIM3 CC1 DMA Request enable */
  71.         TIM_DMACmd(TIM2, TIM_DMA_Update, ENABLE);
  72. }
  73. /* This function sends data bytes out to a string of WS2812s
  74. * The first argument is a pointer to the first RGB triplet to be sent
  75. * The seconds argument is the number of LEDs in the chain
  76. *
  77. * This will result in the RGB triplet passed by argument 1 being sent to
  78. * the LED that is the furthest away from the controller (the point where
  79. * data is injected into the chain)
  80. */
  81. void WS2812_send(uint8_t (*color)[3], uint16_t len)
  82. {
  83.         uint8_t i;
  84.         uint16_t memaddr;
  85.         uint16_t buffersize;
  86.         buffersize = (len*24)+43;        // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
  87.         memaddr = 0;                                // reset buffer memory index
  88.         while (len)
  89.         {
  90.                                 for(i=0; i<8; i++) // GREEN data
  91.                         {
  92.                                         LED_BYTE_Buffer[memaddr] = ((color[0][1]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  93.                                         memaddr++;
  94.                         }
  95.                         for(i=0; i<8; i++) // RED
  96.                         {
  97.                                         LED_BYTE_Buffer[memaddr] = ((color[0][0]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  98.                                         memaddr++;
  99.                         }
  100.                         for(i=0; i<8; i++) // BLUE
  101.                         {
  102.                                         LED_BYTE_Buffer[memaddr] = ((color[0][2]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  103.                                         memaddr++;
  104.                         }
  105.
  106.                   len--;
  107.         }
  108. //===================================================================//
  109. //bug:最后一個(gè)周期波形不知道為什么全是高電平,故增加一個(gè)波形
  110.           LED_BYTE_Buffer[memaddr] = ((color[0][2]<<8) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  111. //===================================================================//
  112.           memaddr++;
  113.                 while(memaddr < buffersize)
  114.                 {
  115.                         LED_BYTE_Buffer[memaddr] = 0;
  116.                         memaddr++;
  117.                 }
  118.                 DMA_SetCurrDataCounter(DMA1_Channel2, buffersize);         // load number of bytes to be transferred
  119.                 DMA_Cmd(DMA1_Channel2, ENABLE);                         // enable DMA channel 6
  120.                 TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 3
  121.                 while(!DMA_GetFlagStatus(DMA1_FLAG_TC2)) ;         // wait until transfer complete
  122.                 TIM_Cmd(TIM2, DISABLE);         // disable Timer 3
  123.                 DMA_Cmd(DMA1_Channel2, DISABLE);                         // disable DMA channel 6
  124.                 DMA_ClearFlag(DMA1_FLAG_TC2);                                 // clear DMA1 Channel 6 transfer complete flag
  125. }
STM32F1_DMA_PWM_WS2813E_2018_05_06.rar (282.3 KB, 下載次數(shù): 296)
收藏收藏5 分享淘帖 頂1 踩
ID:382758 發(fā)表于 2018-10-11 11:21 | 只看該作者
感謝樓主,在此謝過!
ID:408098 發(fā)表于 2018-10-11 15:44 | 只看該作者
STM32控制WS2812直接發(fā)送數(shù)據(jù)不就可以了嗎
ID:473929 發(fā)表于 2019-1-30 09:37 | 只看該作者
感謝樓主分享啊哈哈哈
ID:254127 發(fā)表于 2019-3-14 17:24 | 只看該作者
學(xué)習(xí)了,謝謝
無效樓層,該帖已經(jīng)被刪除
7#
無效樓層,該帖已經(jīng)被刪除
8#
ID:347104 發(fā)表于 2019-5-13 20:05 | 只看該作者
能請(qǐng)問一下 為什么用的是定時(shí)器2通道1   而DMA 使用的卻是通道2嘛?  對(duì)應(yīng)表的話 應(yīng)該是DMA通道5
ID:561518 發(fā)表于 2019-6-13 10:54 | 只看該作者
"WS2812B.h"文件沒有貼出來啊
無效樓層,該帖已經(jīng)被刪除
11#
ID:411659 發(fā)表于 2019-6-13 12:51 | 只看該作者
學(xué)習(xí)一下了!!!!!!!!!!!
ID:228360 發(fā)表于 2019-7-16 15:25 | 只看該作者
謝謝分享,攢夠積分再下載。
ID:300212 發(fā)表于 2019-7-18 20:14 來自觸屏版 | 只看該作者
feng100520 發(fā)表于 2019-5-13 20:05
DMA通道選用TIMx_UP,別的通道不能用,反正我用不了別的
ID:299054 發(fā)表于 2019-9-5 15:54 | 只看該作者
感謝樓主,在此謝過!
ID:569277 發(fā)表于 2019-10-21 10:01 | 只看該作者
感謝樓主,在此謝過!
ID:358797 發(fā)表于 2019-11-29 09:56 | 只看該作者
感謝樓主
無效樓層,該帖已經(jīng)被刪除
18#
ID:667303 發(fā)表于 2020-7-27 22:29 | 只看該作者
好東西,謝謝樓主分享,真的好用
無效樓層,該帖已經(jīng)被刪除
20#
無效樓層,該帖已經(jīng)被刪除
