查看: 3097|回復: 1
16*96LED點陣屏proteus仿真設計 含單片機源碼
ID:407381 發(fā)表于 2018-10-10 15:20 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
16*96LED點陣屏單片機課程設計的圖:
  1. #include<reg51.h>
  2. typedef  unsigned char uchar;
  3. typedef  unsigned int uint;
  4. sbit E1=P3^4;
  5. sbit ST=P3^5;
  6. sbit SS=P3^6;
  7. unsigned char code mo[6][2][16]=
  8. {{{
  9. 0xF7,0xF7,0xF6,0xF6,0xF7,0xF7,0xF6,0xF6,0xF7,0x87,0xF0,0xF7,0xF7,0xF7,0xF7,0xF7},
  10. {0xEF,0x47,0xF0,0xF7,0xF7,0x40,0xF7,0xE3,0xD3,0xF5,0x35,0xF6,0xF7,0xF7,0xF7,0xF7}},
  11. {{0xFF,0x80,0xFB,0xFB,0xFB,0xC0,0xDB,0xDB,0xDB,0xDB,0xDB,0xD3,0xEB,0xFB,0xFB,0xFB},
  12. {0xEF,0x2F,0xED,0xED,0xED,0x6D,0x6D,0x6D,0x6D,0x6D,0x6D,0x6F,0x77,0xF7,0xFB,0xFD}},
  13. {{0xFE,0xFE,0xFE,0xC0,0xDF,0xEF,0xFD,0xFD,0xFD,0xFA,0xFA,0xF7,0xF7,0xEF,0xDF,0xBF},
  14. {0xFF,0xFF,0xC0,0xDF,0x5F,0x6D,0xAB,0xD7,0xF7,0xEB,0xDB,0x5D,0x7E,0xBF,0xDF,0xEF}},
  15. {{0xFF,0xFE,0xC3,0xDB,0xDB,0xDB,0xDB,0xDB,0xDB,0xD2,0xEB,0xFB,0xFB,0xFB,0x80,0xFF},
  16. {0xFF,0xFB,0x37,0xB7,0xBF,0xBF,0xB0,0xB7,0xB7,0xB7,0x37,0xB7,0xF7,0xEB,0x1D,0xFF}},
  17. {{0xFE,0xFE,0xFE,0x80,0xBF,0xDF,0xFB,0xFB,0xEB,0xDB,0xDB,0xBB,0xBB,0xFB,0xFA,0xFD},
  18. {0xEF,0xEF,0xEF,0x77,0x77,0xB3,0xD3,0xF5,0x76,0x77,0xB7,0xB7,0xD7,0xF7,0xF7,0xF7}},
  19. {{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  20. {0xFF,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xFF,0xFF,0xF7,0xF7,0xFF,0xFF}}};
  21. void yiwei(int i,int j,int k)
  22. {
  23. SBUF=mo[i][j][k];
  24. while(~TI){};
  25. TI=0;
  26. }
  27. void main() /*主函數(shù)*/
  28. {        int i=0,j=0,k=0,n,u;
  29.         uchar l=0;
  30.         SM0=0;
  31.         SM1=0;
  32.         ST=0;
  33.         TI=0;
  34.         yiwei(i,j,k);
  35.         n=0;
  36.         while(1){
  37.                  {for(i=0;i<6-0;i++)
  38.                          {yiwei(i,0,k);
  39.                          yiwei(i,1,k);
  40.                         }
  41.                         i=0;
  42.                         k++;
  43.                         if(k>15)
  44.                         k=0;
  45.                 P2=n;
  46.                         E1=0;
  47.                         ST=1;
  48.                         for(u=0;u<300;u++){}
  49.
  50.                         n++;
  51.                         if(n>16)
  52.                         n=0;
  53.                         E1=1;
  54.                         ST=0;
  55.         }
  56.
  57.         }
  58.
  59. }
xvshuo.rar (41.23 KB, 下載次數(shù): 77)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏2 分享淘帖 頂 踩
ID:51142 發(fā)表于 2018-10-15 00:31 | 只看該作者
這個好,下載學習了
