設(shè)計(jì)一個(gè)單片機(jī)里程表用的中斷0外部檢測(cè)信號(hào),定時(shí)器1做1秒更新:具體如下
中斷0函數(shù)
count++;
定時(shí)器1函數(shù)
//50ms初值
a++;
if(a==20) //1秒時(shí)間
a=0;
num=count; //count的值給 num, num送到顯示屏
_nop_;
_nop_;
count=0; //count數(shù)清零
問題是,count清零時(shí),num也跟著變了,在顯示屏上的反應(yīng)就是屏上的數(shù)值1S跳動(dòng)一次,可是被測(cè)信號(hào)一直是沒有變的,
看了此論壇好多相似的程序,都是這么操作的,他們?yōu)槭裁纯梢裕业臑槭裁床恍心兀?br />
搞 了幾天了,知道的方法都試了就是不行
2018-9-26 08:28 上傳
完整代碼如下:
- #include"STC15F2K60S2.H"
- //#include <reg52.H>
- #include <intrins.h>
- #include <chinese_code.h>
- //sbit key=P3^2;
- sbit cs1=P1^4;
- sbit reset=P1^5;
- sbit rs=P1^3;
- sbit sclk=P1^0;
- sbit sid=P1^1;
- sbit led=P0^0;
- //sbit cruise =P1^0; // 開關(guān)
- sbit plus_A =P3^7; // 速度上升
- //sbit cool =P1^3; //
- sbit plus_B =P3^6; // 溫度下降
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- uint count;
- static ulong speed;
- uint a;
- uint speed_set, temp_set;
- bit flag;
- /*延時(shí):1毫秒的i倍*/
- void delay(int i)
- int j,k;
- for(j=0;j<i;j++)
- for(k=0;k<110;k++);
- /*延時(shí):1us的i倍*/
- void delay_us(int i)
- int j,k;
- for(j=0;j<i;j++)
- for(k=0;k<1;k++);
- //=============transfer command to LCM===============
- void transfer_command(int data1)
- char i;
- cs1=0;
- rs=0;
- for(i=0;i<8;i++)
- sclk=0;
- if(data1&0x80) sid=1;
- else sid=0;
- sclk=1;
- data1=data1<<=1;
- //-----------transfer data to LCM---------------
- void transfer_data(int data1)
- char i;
- cs1=0;
- rs=1;
- for(i=0;i<8;i++)
- sclk=0;
- else sid=0;
- sclk=1;
- data1=data1<<=1;
- void initial_lcd()
- reset=0;
- delay(100);
- reset=1;
- delay(100);
- transfer_command(0x30); //EXT=0
- transfer_command(0x94); //Sleep out
- transfer_command(0x31); //EXT=1
- transfer_command(0xD7); //Autoread disable
- transfer_data(0X9F); //
- transfer_command(0x32); //Analog SET
- transfer_data(0x00); //OSC Frequency adjustment
- transfer_data(0x01); //Frequency on booster capacitors->6KHz
- transfer_data(0x04); //Bias=1/11
- transfer_command(0x20); // Gray Level
- transfer_data(0x03);
- transfer_data(0x05);
- transfer_data(0x07);
- transfer_data(0x09);
- transfer_data(0x0b);
- transfer_data(0x0d);
- transfer_data(0x10);
- transfer_data(0x11);
- transfer_data(0x13);
- transfer_data(0x15);
- transfer_data(0x17);
- transfer_data(0x19);
- transfer_data(0x1b);
- transfer_data(0x1d);
- transfer_data(0x1f);
- transfer_command(0x30); // EXT1=0,EXT0=0,表示選擇了“擴(kuò)展指令表1”
- transfer_command(0x75); // 頁地址設(shè)置
- transfer_data(0X00); // 起始頁地址:YS=0X00
- transfer_data(0X14); // 結(jié)束頁地址:YE=0x1F 每4行為一頁,第0~3行為第0頁,第124~127行為第31頁(31=0x1f)
- transfer_command(0x15); // 列地址設(shè)置
- transfer_data(0X00); // 起始列地址:XS=0
- transfer_data(0Xff); // 結(jié)束列地址:XE=256(0xff)
- transfer_command(0xBC); //Data scan direction
- transfer_data(0x00); //MX.MY=Normal
- transfer_data(0xA6);
- transfer_command(0x0c); //數(shù)據(jù)格式選擇,0x0C是低位在前D0-D7,0x08是高位在前D7-D0
- transfer_command(0xCA); //顯示控制
- transfer_data(0X00); // 設(shè)置CL驅(qū)動(dòng)頻率:CLD=0
- transfer_data(0X4F); //占空比:Duty=128
- transfer_data(0X20); //N行反顯:Nline=off
- transfer_command(0xF0); //顯示模式
- transfer_data(0X10); //如果設(shè)為0x11:表示選擇4灰度級(jí)模式,如果設(shè)為0x10:表示選擇黑白模式
- transfer_command(0x81); //設(shè)置對(duì)比度,“0x81”不可改動(dòng),緊跟著的2個(gè)數(shù)據(jù)是可改的,但“先微調(diào)后粗調(diào)”這個(gè)順序別亂了
- transfer_data(0x2f); //對(duì)比度微調(diào),可調(diào)范圍0x00~0x3f,共64級(jí) //0x2f
- transfer_data(0x02); //對(duì)比度粗調(diào),可調(diào)范圍0x00~0x07,共8級(jí) //0x02
- transfer_command(0x20); //Power control
- transfer_data(0x0B); //D0=regulator ; D1=follower ; D3=booste, on:1 off:0
- delay_us(100);
- transfer_command(0xAF); //打開顯示
- /*寫LCD 行列地址:X為起始的列地址,Y為起始的行地址,x_total,y_total分別為列地址及行地址的起點(diǎn)到終點(diǎn)的差值 */
- void lcd_address(int x,int y,x_total,y_total)
- x=x-1;
- y=y-1;//+9
- transfer_command(0x15); //Set Column Address
- transfer_data(x);
- transfer_data(x+x_total-1);
- transfer_command(0x75); //Set Page Address
- transfer_data(y);
- transfer_data(y+y_total-1);
- transfer_command(0x5c);
- /*清屏*/
- void clear_screen()
- int i,j;
- lcd_address(0,0,161,11);
- for(i=0;i<20;i++)
- for(j=0;j<161;j++)
- /*顯示160*80點(diǎn)陣的圖像*/
- void disp_160x80(int x,int y,char *dp)
- int i,j;
- lcd_address(x,y,160,10);
- for(i=0;i<10;i++)
- for(j=0;j<160;j++)
- transfer_data(*dp);
- dp++;
- /*顯示160*8點(diǎn)陣的圖像*/
- /*void disp_160x8(int x,int y,char *dp)
- int i,j;
- lcd_address(x,y,160,1);
- dp++;
- /*顯示8*16點(diǎn)陣的漢字或等同于8*16點(diǎn)陣的圖像*/
- void disp_8x16(int x,int y,uchar *dp)
- int i,j;
- lcd_address(x,y,8,2);
- for(i=0;i<2;i++)
- for(j=0;j<8;j++)
- dp++;
- /*顯示8*48點(diǎn)陣的漢字或等同于8*48點(diǎn)陣的圖像*/
- void disp_8x48(int x,int y,uchar *dp)
- int i,j;
- lcd_address(x,y,8,6);
- for(i=0;i<6;i++)
- for(j=0;j<8;j++)
- dp++;
- /*顯示16*32點(diǎn)陣的漢字或等同于16*32點(diǎn)陣的圖像*/
- void disp_16x32(int x,int y,uchar *cc)
- int i,j;
- lcd_address(x,y,16,4);
- for(i=0;i<4;i++)
- for(j=0;j<16;j++)
- transfer_data(*cc);
- cc++;
- void disp_cruise()
- disp_8x16(8*1,5, dac);
- disp_8x16(8*2,5, dar);
- disp_8x16(8*3,5, dau);
- disp_8x16(8*4,5, dai);
- disp_8x16(8*5,5, das);
- disp_8x16(8*6,5, dae);
- disp_8x16(8*10,5, dav);
- disp_8x16(8*11,5, dac);
- disp_8x16(8*12,5, dac);
- disp_8x16(8*15,5, dac);
- disp_8x16(8*16,5, dao);
- disp_8x16(8*17,5, dao);
- disp_8x16(8*18,5, dal); //第一行顯示到此
- disp_8x16(8*9,7, x1);
- disp_8x16(8*10,7, x3);
- disp_8x16(8*11,7, dian);
- disp_8x16(8*12,7, x5);
- disp_8x16(8*13,7, xv); //第二行顯示
- disp_8x16(8*3,9, dao);
- disp_8x16(8*4,9, dan);
- disp_8x16(8*9,9, da3);
- disp_8x16(8*10,9, da5);
- disp_8x16(8*11,9, dadian);
- disp_8x16(8*12,9, da7);
- disp_8x16(8*13,9, da1c);
- disp_8x16(8*16,9, dao);
- disp_8x16(8*17,9, daf);
- disp_8x16(8*18,9, daf);
- disp_8x48(8*8,5,line1); //顯示兩條豎線
- disp_8x48(8*14,5,line1); //顯示兩條豎線
- **********速度顯示函數(shù)*************/
- void disp_speed()
- uchar hundred,ten,ge;
- /* if(flag==1)
- flag=0;
- speed=count*6696/1000;
- count=0;
- a=0;
- hundred=speed/100;
- ten=speed%100/10;
- ge=speed%10;
- disp_8x16(1,2, das); //小S顯示
- switch (hundred)
- case 0: disp_16x32(16*1,1,c0 );
- break;
- case 1: disp_16x32(16*1,1,c1 );
- break;
- case 2: disp_16x32(16*1,1,c2 );
- break;
- case 3: disp_16x32(16*1,1,c3 );
- break;
- case 4: disp_16x32(16*1,1,c4 );
- break;
- case 5 : disp_16x32(16*1,1,c5 );
- break;
- default:
- break;
- switch (ten)
- case 0: disp_16x32(16*2,1,c0);
- break;
- case 1: disp_16x32(16*2,1,c1 );
- break;
- case 2: disp_16x32(16*2,1,c2 );
- break;
- case 3: disp_16x32(16*2,1,c3 );
- break;
- case 4: disp_16x32(16*2,1,c4 );
- break;
- case 5 : disp_16x32(16*2,1,c5 );
- break;
- case 6: disp_16x32(16*2,1,c6 );
- break;
- case 7: disp_16x32(16*2,1,c7 );
- break;
- case 8: disp_16x32(16*2,1,c8 );
- break;
- case 9: disp_16x32(16*2,1,c9 );
- break;
- switch (ge)
- case 0: disp_16x32(16*3,1, c0);
- break;
- case 1: disp_16x32(16*3,1, c1);
- break;
- case 2: disp_16x32(16*3,1, c2);
- break;
- case 3: disp_16x32(16*3,1, c3);
- break;
- case 4: disp_16x32(16*3,1, c4);
- break;
- case 5 : disp_16x32(16*3,1, c5);
- break;
- case 6: disp_16x32(16*3,1, c6);
- break;
- case 7: disp_16x32(16*3,1, c7);
- break;
- case 8: disp_16x32(16*3,1, c8);
- break;
- case 9: disp_16x32(16*3,1, c9);
- break;
- disp_16x32(16*5,1, ck);
- disp_16x32(16*6,1, cm);
- disp_16x32(16*7,1, c11);
- disp_16x32(16*8,1, ch); //此行和上面3行為 KM/h 顯示
- /*********速度設(shè)定顯示函數(shù)***************/
- void dispspeed_set()
- uchar hundred,ten,one;
- hundred=speed_set/100;
- ten=speed_set%100/10;
- one=speed_set%10;
- switch (hundred)
- case 0: disp_8x16(8*1,7, x0);
- break;
- case 1: disp_8x16(8*1,7, x1);
- break;
- case 2: disp_8x16(8*1,7, x2);
- break;
- case 3: disp_8x16(8*1,7, x3);
- break;
- case 4: disp_8x16(8*1,7, x4);
- break;
- case 5: disp_8x16(8*1,7, x5);
- break;
- case 6: disp_8x16(8*1,7, x6);
- break;
- case 7: disp_8x16(8*1,7, x7);
- break;
- case 8: disp_8x16(8*1,7, x8);
- break;
- case 9: disp_8x16(8*1,7, x9);
- break;
- default:
- break;
- switch (ten)
- case 0: disp_8x16(8*2,7, x0);
- break;
- case 1: disp_8x16(8*2,7, x1);
- break;
- case 2: disp_8x16(8*2,7, x2);
- break;
- case 3: disp_8x16(8*2,7, x3);
- break;
- case 4: disp_8x16(8*2,7, x4);
- break;
- case 5: disp_8x16(8*2,7, x5);
- break;
- case 6: disp_8x16(8*2,7, x6);
- break;
- case 7: disp_8x16(8*2,7, x7);
- break;
- case 8: disp_8x16(8*2,7, x8);
- break;
- case 9: disp_8x16(8*2,7, x9);
- break;
- default:
- break;
- switch (one)
- case 0: disp_8x16(8*3,7, x0);
- break;
- case 1: disp_8x16(8*3,7, x1);
- break;
- case 2: disp_8x16(8*3,7, x2);
- break;
- case 3: disp_8x16(8*3,7, x3);
- break;
- case 4: disp_8x16(8*3,7, x4);
- break;
- case 5: disp_8x16(8*3,7, x5);
- break;
- case 6: disp_8x16(8*3,7, x6);
- break;
- case 7: disp_8x16(8*3,7, x7);
- break;
- case 8: disp_8x16(8*3,7, x8);
- break;
- case 9: disp_8x16(8*3,7, x9);
- break;
- default:
- break;
- disp_8x16(8*4,7, xk);
- disp_8x16(8*5,7, xm);
- disp_8x16(8*6,7, gang);
- disp_8x16(8*7,7, xh);
- /*********溫度設(shè)定顯示函數(shù)***************/
- void disptemp_set()
- uchar set1,hundred1,ten1,one1;
- set1=temp_set;
- hundred1=set1/100;
- ten1=set1%100/10;
- one1=set1%10;
- switch (hundred1)
- case 0: disp_8x16(8*15,7, x0);
- break;
- case 1: disp_8x16(8*15,7, x1);
- break;
- case 2: disp_8x16(8*15,7, x2);
- break;
- case 3: disp_8x16(8*15,7, x3);
- break;
- case 4: disp_8x16(8*15,7, x4);
- break;
- case 5: disp_8x16(8*15,7, x5);
- break;
- case 6: disp_8x16(8*15,7, x6);
- break;
- case 7: disp_8x16(8*15,7, x7);
- break;
- case 8: disp_8x16(8*15,7, x8);
- break;
- case 9: disp_8x16(8*15,7, x9);
- break;
- default:
- break;
- switch (ten1)
- case 0: disp_8x16(8*16,7, x0);
- break;
- case 1: disp_8x16(8*16,7, x1);
- break;
- case 2: disp_8x16(8*16,7, x2);
- break;
- case 3: disp_8x16(8*16,7, x3);
- break;
- case 4: disp_8x16(8*16,7, x4);
- break;
- case 5: disp_8x16(8*16,7, x5);
- break;
- case 6: disp_8x16(8*16,7, x6);
- break;
- case 7: disp_8x16(8*16,7, x7);
- break;
- case 8: disp_8x16(8*16,7, x8);
- break;
- case 9: disp_8x16(8*16,7, x9);
- break;
- default:
- break;
- switch (one1)
- case 0: disp_8x16(8*18,7, x0);
- break;
- case 1: disp_8x16(8*18,7, x1);
- break;
- case 2: disp_8x16(8*18,7, x2);
- break;
- case 3: disp_8x16(8*18,7, x3);
- break;
- case 4: disp_8x16(8*18,7, x4);
- break;
- case 5: disp_8x16(8*18,7, x5);
- break;
- case 6: disp_8x16(8*18,7, x6);
- break;
- case 7: disp_8x16(8*18,7, x7);
- break;
- case 8: disp_8x16(8*18,7, x8);
- break;
- case 9: disp_8x16(8*18,7, x9);
- break;
- default:
- break;
- disp_8x16(8*17,7, dian);
- disp_8x16(8*19,7, x1c);
- /**********定時(shí)器初始化**********/
- void Init_time0(void)
- TMOD |= 0x02; //定時(shí)器0工作方式2,8位自動(dòng)裝入計(jì)數(shù)
- TH0=0X06; //2.5MS定時(shí)時(shí)間
- TL0=0X06;
- EA=1;
- IT0=0; //外部中斷1工作方式(下降沿有效)
- EX0=1; //打開外部中斷0
- EX1=1; //打開外部中斷1
- IT1=1;
- ET0=1; // 定時(shí)器0中斷允許
- TR0=1; // 定時(shí)器打開
- /*********外部中斷0****************/
- void exter0() interrupt 0
- count++; //脈沖數(shù)取樣
- /*********外部中斷1****************/
- void exter1() interrupt 2
- if(plus_A==1)
- speed_set++;
- if(speed_set>=120)
- speed_set=120;
- else
- speed_set--;
- if(speed_set<=1)
- speed_set=1;
- /* if(plus_B==1)
- temp_set++;
- if(temp_set>=32)
- temp_set=32;
- else
- temp_set--;
- if(temp_set<=16)
- temp_set=16;
- /*******定時(shí)器0,8位自動(dòng)重裝*****/
- void time0() interrupt 1
- TL0=0X06;
- a++;
- if(a==4000) //1S時(shí)間刷新一次
- // EX0=0;
- speed= count*6696/1000; //6696=1.86*3600
- _nop_;
- _nop_;
- _nop_;
- count=0;
- flag=1;
- a=0;
- led=~led;
- // EX0=1;
- void init_io()
- P0M0 = 0x00;
- P0M1 = 0x00;
- P1M0 = 0x00;
- P1M1 = 0x00;
- P2M0 = 0x00;
- P2M1 = 0x00;
- P3M0 = 0x00;
- P3M1 = 0x00;
- P4M0 = 0x00;
- P4M1 = 0x00;
- P5M0 = 0x00;
- P5M1 = 0x00;
- P6M0 = 0x00;
- P6M1 = 0x00;
- P7M0 = 0x00;
- P7M1 = 0x00;
- void main ()
- init_io();
- flag=0;
- Init_time0();
- // Init_time1();
- initial_lcd(); //對(duì)液晶模塊進(jìn)行初始化設(shè)置
- // clear_screen();
- // disp_160x80(1,1,buick); //logo disp
- // delay(3000);
- clear_screen();
- while(1)
- disp_speed();
- disp_cruise();
- disptemp_set();
- dispspeed_set();
