查看: 6636|回復(fù): 2
ili9486 tft屏硬件規(guī)格書資料(中景園電子3.5寸字庫SPI接口)
ID:402476 發(fā)表于 2018-9-26 07:58 | 顯示全部樓層 |閱讀模式
spi驅(qū)動
中景園3.5寸TFT LCD 帶字庫SPI接口原理圖.pdf
中景園3.5寸TFT LCD 帶字庫SPI接口結(jié)構(gòu)圖.pdf
中景園3.5寸TFT LCD 規(guī)格書 .pdf
中景園3.5寸TFT LCD 驅(qū)動芯片ILI9486規(guī)格書.pdf
字庫芯片GT30L32S4W規(guī)格書.pdf
ILI9486 supports MIPI DSI which can be enabled or disabled by external IM [4] pin. ILI9486 can be accessed
through one PHY lane module which communicates via two lines to a complementary part at the other side of
the lane interconnects. The communication can be separated two different levels between the MCU and ILI9486:
      ● Low level communication what is done on the interface level.
      ● High level communication what is done on the packet level.
ILI9486 uses data and clock lane differential pairs for DSI, The data lane (DATAP and DATAN) is used for data
communication and clock lane (CLKP and CLKN) is used to transmit the clock signal. The Mobile Industry
Processor Interface (MIPI) can be used for communication between the processor and DSI-compliant LCD
driver chip. The selection of this interface is done when IM [3:1] pins are high state (IOVCC level).
全部資料51hei下載地址:
中景園電子3.5寸字庫SPI接口技術(shù)資料.zip (8.78 MB, 下載次數(shù): 177)
ID:369039 發(fā)表于 2020-2-27 00:24 | 顯示全部樓層
   好東西 正在學(xué)習(xí)這些東西
ID:230895 發(fā)表于 2020-3-18 09:47 | 顯示全部樓層
我使用字庫例程,字庫里面的ascii碼可以正常顯示,但漢字亂碼,什么原因
