MH1608C開發(fā)程序 RC523芯片
2018-9-20 16:25 上傳
- * @file rc523.c
- * @brief rc523 driver.
- * @author
- * INCLUDE FILES
- #include "define.h"
- #include<stdlib.h>
- #include<stdio.h>
- #include<string.h>
- #include "stc_new_8051.h"
- #include "spi.h"
- #include "uart.h"
- #include "timer.h"
- #include "iso14443_4.h"
- #include "mh523.h"
- #define FIFO_SIZE 64
- #define FSD 256 //Frame Size for proximity coupling Device
- #define READ_REG_CTRL 0x80
- #define TP_FWT_302us 2048
- #define TP_dFWT 192
- #define MAX_RX_REQ_WAIT_MS 5000 // 命令等待超時時間100ms
- transceive_buffer XDATA mf_com_data;
- * @brief pcd_init()
- * 初始化芯片
- * @param:
- * @return:
- * @retval:
- void pcd_init()
- pcd_poweron();
- mdelay(5);
- pcd_reset();
- mdelay(5);
- pcd_config('A');
- * @brief pcd_config()
- * 配置芯片的A/B模式
- * @param: u8 type
- * @return:
- * @retval:
- char pcd_config(u8 type)
- pcd_antenna_off();
- mdelay(7);
- if ('A' == type)
- clear_bit_mask(Status2Reg, BIT3);
- clear_bit_mask(ComIEnReg, BIT7); // 高電平
- write_reg(ModeReg,0x3D); // 11 // CRC seed:6363
- write_reg(RxSelReg, 0x86);//RxWait
- write_reg(RFCfgReg, 0x58); //
- write_reg(TxASKReg, 0x40);//15 //typeA
- write_reg(TxModeReg, 0x00);//12 //Tx Framing A
- write_reg(RxModeReg, 0x00);//13 //Rx framing A
- write_reg(0x0C, 0x10); //^_^
- //兼容配置
- u8 backup, adc;
- backup = read_reg(0x37);
- write_reg(0x37, 0x00);
- adc = read_reg(0x37);
- if (adc == 0x11)
- write_reg(0x26, 0x48);
- write_reg(0x37, 0x5E);
- write_reg(0x17, 0x88);
- write_reg(0x38, 0x6B);
- write_reg(0x3A, 0x23);
- write_reg(0x29, 0x12);//0x0F); //調(diào)制指數(shù)
- write_reg(0x3b, 0x25);
- else if (adc == 0x12)
- // 以下寄存器必須按順序配置
- write_reg(0x35, 0xED);
- write_reg(0x3b, 0xA5);
- write_reg(0x37, 0xAE);
- write_reg(0x3b, 0x72);
- write_reg(0x37, backup);
- else if ('B' == type)
- write_reg(Status2Reg, 0x00); //清MFCrypto1On
- clear_bit_mask(ComIEnReg, BIT7);// 高電平觸發(fā)中斷
- write_reg(ModeReg, 0x3F); // CRC seed:FFFF
- write_reg(RxSelReg, 0x88); //RxWait
- //Tx
- write_reg(GsNReg, 0xF8); //調(diào)制系數(shù)
- write_reg(CWGsPReg, 0x3F); //
- write_reg(ModGsPReg, 0x12); //調(diào)制指數(shù)
- write_reg(AutoTestReg, 0x00);
- write_reg(TxASKReg, 0x00); // typeB
- write_reg(TypeBReg, 0x13);
- write_reg(TxModeReg, 0x83); //Tx Framing B
- write_reg(RxModeReg, 0x83); //Rx framing B
- write_reg(BitFramingReg, 0x00); //TxLastBits=0
- //兼容配置
- u8 backup, adc;
- if (adc == 0x11)
- write_reg(0x3b, 0xE5);//改為E5 write_reg(0x3b, 0xA5);
- //write_reg(0x37, 0xAE);//去掉
- //write_reg(0x3b, 0x72);//去掉
- else
- return USER_ERROR;
- pcd_antenna_on();
- mdelay(2);
- return MI_OK;
- * @brief pcd_com_transceive()
- * 通過芯片和ISO14443卡通訊
- * @param: pi->mf_command = 芯片命令字
- * @param: pi->mf_length = 發(fā)送的數(shù)據(jù)長度
- * @param: pi->mf_data[] = 發(fā)送數(shù)據(jù)
- * @return: status 值為MI_OK:成功
- * @retval: pi->mf_length = 接收的數(shù)據(jù)BIT長度
- * @retval: pi->mf_data[] = 接收數(shù)據(jù)
- char pcd_com_transceive(struct transceive_buffer *pi)
- u8 XDATA recebyte;
- char XDATA status;
- u8 XDATA irq_en;
- u8 XDATA wait_for;
- u8 XDATA last_bits;
- u8 XDATA j;
- u8 XDATA val;
- u8 XDATA err;
- u8 irq_inv;
- u16 len_rest;
- u8 len;
- u8 WATER_LEVEL;
- len = 0;
- len_rest = 0;
- err = 0;
- recebyte = 0;
- irq_en = 0;
- wait_for = 0;
- switch (pi->mf_command)
- case PCD_IDLE:
- irq_en = 0x00;
- wait_for = 0x00;
- break;
- case PCD_AUTHENT:
- irq_en = IdleIEn | TimerIEn;
- wait_for = IdleIRq;
- break;
- case PCD_RECEIVE:
- irq_en = RxIEn | IdleIEn;
- wait_for = RxIRq;
- recebyte=1;
- break;
- case PCD_TRANSMIT:
- irq_en = TxIEn | IdleIEn;
- wait_for = TxIRq;
- break;
- case PCD_TRANSCEIVE:
- irq_en = RxIEn | IdleIEn | TimerIEn | TxIEn;
- wait_for = RxIRq;
- recebyte=1;
- break;
- default:
- pi->mf_command = MI_UNKNOWN_COMMAND;
- break;
- WATER_LEVEL = read_reg(WaterLevelReg);
- if (pi->mf_command != MI_UNKNOWN_COMMAND
- && (((pi->mf_command == PCD_TRANSCEIVE || pi->mf_command == PCD_TRANSMIT) && pi->mf_length > 0)
- || (pi->mf_command != PCD_TRANSCEIVE && pi->mf_command != PCD_TRANSMIT))
- write_reg(CommandReg, PCD_IDLE);
- irq_inv = read_reg(ComIEnReg) & BIT7;
- write_reg(ComIEnReg, irq_inv |irq_en | BIT0);//使能Timer 定時器中斷
- write_reg(ComIrqReg, 0x7F); //Clear INT
- write_reg(DivIrqReg, 0x7F); //Clear INT
- //Flush Fifo
- set_bit_mask(FIFOLevelReg, BIT7);
- if (pi->mf_command == PCD_TRANSCEIVE || pi->mf_command == PCD_TRANSMIT || pi->mf_command == PCD_AUTHENT)
- #if (NFC_DEBUG)
- printf(" PCD_tx:");
- #endif
- for (j = 0; j < pi->mf_length; j++)
- #if (NFC_DEBUG)
- printf("%02x ", (u16)pi->mf_data[j]);
- #endif
- #if (NFC_DEBUG)
- printf("\n");
- #endif
- len_rest = pi->mf_length;
- if (len_rest >= FIFO_SIZE)
- len = FIFO_SIZE;
- }else
- len = len_rest;
- for (j = 0; j < len; j++)
- write_reg(FIFODataReg, pi->mf_data[j]);
- len_rest -= len;//Rest bytes
- if (len_rest != 0)
- write_reg(ComIrqReg, BIT2); // clear LoAlertIRq
- set_bit_mask(ComIEnReg, BIT2);// enable LoAlertIRq
- write_reg(CommandReg, pi->mf_command);
- if (pi->mf_command == PCD_TRANSCEIVE)
- set_bit_mask(BitFramingReg,0x80);
- while (len_rest != 0)
- while(INT_PIN == 0);//Wait LoAlertIRq
- if (len_rest > (FIFO_SIZE - WATER_LEVEL))
- len = FIFO_SIZE - WATER_LEVEL;
- else
- len = len_rest;
- write_reg(FIFODataReg, pi->mf_data[pi->mf_length - len_rest + j]);
- write_reg(ComIrqReg, BIT2);//在write fifo之后,再清除中斷標記才可以
- //printf("\n8 comirq=%02bx,ien=%02bx,INT= %bd \n", read_reg(ComIrqReg), read_reg(ComIEnReg), (u8)INT_PIN);
- if (len_rest == 0)
- clear_bit_mask(ComIEnReg, BIT2);// disable LoAlertIRq
- //printf("\n9 comirq=%02bx,ien=%02bx,INT= %bd \n", read_reg(ComIrqReg), read_reg(ComIEnReg), (u8)INT_PIN);
- //Wait TxIRq
- while (INT_PIN == 0);
- val = read_reg(ComIrqReg);
- if (val & TxIRq)
- write_reg(ComIrqReg, TxIRq);
- if(pi->mf_command == PCD_TRANSMIT)
- return 0;
- if (PCD_RECEIVE == pi->mf_command)
- set_bit_mask(ControlReg, BIT6);// TStartNow
- len_rest = 0; // bytes received
- write_reg(ComIrqReg, BIT3); // clear HoAlertIRq
- set_bit_mask(ComIEnReg, BIT3); // enable HoAlertIRq
- //等待命令執(zhí)行完成
- while(1)
- while(0 == INT_PIN);
- if ((val & BIT3) && !(val & BIT5))
- if (len_rest + FIFO_SIZE - WATER_LEVEL > 255)
- #if (NFC_DEBUG)
- printf("AF RX_LEN > 255B\n");
- #endif
- break;
- for (j = 0; j <FIFO_SIZE - WATER_LEVEL; j++)
- pi->mf_data[len_rest + j] = read_reg(FIFODataReg);
- write_reg(ComIrqReg, BIT3);//在read fifo之后,再清除中斷標記才可以
- len_rest += FIFO_SIZE - WATER_LEVEL;
- else
- clear_bit_mask(ComIEnReg, BIT3);//disable HoAlertIRq
- break;
- #if (NFC_DEBUG)
- printf(" INT:fflvl=%d,rxlst=%02bx ,ien=%02bx,cirq=%02bx\n", (u16)read_reg(FIFOLevelReg),read_reg(ControlReg)&0x07,read_reg(ComIEnReg), val);//XU
- #endif
- write_reg(ComIrqReg, val);// 清中斷
- if (val & BIT0)
- {//發(fā)生超時
- status = MI_NOTAGERR;
- else
- err = read_reg(ErrorReg);
- status = MI_COM_ERR;
- if ((val & wait_for) && (val & irq_en))
- if (!(val & ErrIRq))
- {//指令執(zhí)行正確
- status = MI_OK;
- if (recebyte)
- val = 0x7F & read_reg(FIFOLevelReg);
- last_bits = read_reg(ControlReg) & 0x07;
- if (len_rest + val > MAX_TRX_BUF_SIZE)
- {//長度過長超出緩存
- #if (NFC_DEBUG)
- printf("RX_LEN > 255B\n");
- #endif
- else
- if (last_bits && val) //防止spi讀錯后 val-1成為負值
- pi->mf_length = (val-1)*8 + last_bits;
- else
- pi->mf_length = val*8;
- pi->mf_length += len_rest*8;
- #if (NFC_DEBUG)
- printf(" RX:len=%02x,dat:", (u16)pi->mf_length);
- #endif
- if (val == 0)
- val = 1;
- for (j = 0; j < val; j++)
- #if (NFC_DEBUG)
- for (j = 0; j < pi->mf_length/8 + !!(pi->mf_length%8); j++)
- // if (j > 4)
- // printf("..");
- // break;
- // else
- printf("%02X ", (u16)pi->mf_data[j]);
- //printf("%02X ", (u16)pi->mf_data[j]);
- //printf("l=%d", pi->mf_length/8 + !!(pi->mf_length%8));
- printf("\n");
- #endif
- else if ((err & CollErr) && (!(read_reg(CollReg) & BIT5)))
- {//a bit-collision is detected
- status = MI_COLLERR;
- if (recebyte)
- {//長度過長超出緩存
- #if (NFC_DEBUG)
- printf("COLL RX_LEN > 255B\n");
- #endif
- else
- else
- #if (NFC_DEBUG)
- printf(" RX: pi_cmd=%02x,pi_len=%02x,pi_dat:", (u16)pi->mf_command, (u16)pi->mf_length);
- #endif
- if (val == 0)
- val = 1;
- pi->mf_data[len_rest + j +1] = read_reg(FIFODataReg);
- #if (NFC_DEBUG)
- printf("%02X ", (u16)pi->mf_data[j+1]);
- printf("\n");
- #endif
- pi->mf_data[0] = (read_reg(CollReg) & CollPos);
- if (pi->mf_data[0] == 0)
- pi->mf_data[0] = 32;
- #if(NFC_DEBUG)
- printf("\n COLL_DET pos=%02x\n", (u16)pi->mf_data[0]);
- #endif
- pi->mf_data[0]--;// 與之前版本有點映射區(qū)別,為了不改變上層代碼,這里直接減一;
- else if ((err & CollErr) && (read_reg(CollReg) & BIT5))
- //printf("COLL_DET,but CollPosNotValid=1\n");
- //else if (err & (CrcErr | ParityErr | ProtocolErr))
- else if (err & (ProtocolErr))
- #if (NFC_DEBUG)
- printf("protocol err=%b02x\n", err);
- #endif
- status = MI_FRAMINGERR;
- else if ((err & (CrcErr | ParityErr)) && !(err &ProtocolErr) )
- //EMV parity err EMV 307.2.3.4
- {//長度過長超出緩存
- #if (NFC_DEBUG)
- #endif
- else
- else
- #if (NFC_DEBUG)
- printf("crc-parity err=%b02x\n", err);
- printf("l=%d\n", pi->mf_length );
- #endif
- status = MI_INTEGRITY_ERR;
- else
- #if (NFC_DEBUG)
- printf("unknown ErrorReg=%02bx\n", err);
- #endif
- else
- #if (NFC_DEBUG)
- printf(" MI_COM_ERR\n");
- #endif
- set_bit_mask(ControlReg, BIT7);// TStopNow =1,必要的;
- write_reg(ComIrqReg, 0x7F);// 清中斷0
- write_reg(DivIrqReg, 0x7F);// 清中斷1
- clear_bit_mask(ComIEnReg, 0x7F);//清中斷使能,最高位是控制位
- clear_bit_mask(DivIEnReg, 0x7F);//清中斷使能,最高位是控制位
- else
- status = USER_ERROR;
- #if (NFC_DEBUG)
- printf("USER_ERROR\n");
- #endif
- #if (NFC_DEBUG)
- printf(" pcd_com: sta=%bd,err=%02bx\n", status, err);
- #endif
- return status;
- void pcd_reset()
- #if(NFC_DEBUG)
- printf("pcd_reset\n");
- #endif
- write_reg(CommandReg, PCD_RESETPHASE); //軟復(fù)位數(shù)字芯片
- void pcd_antenna_on()
- write_reg(TxControlReg, read_reg(TxControlReg) | 0x03); //Tx1RFEn=1 Tx2RFEn=1
- void pcd_antenna_off()
- write_reg(TxControlReg, read_reg(TxControlReg) & (~0x03));
- //設(shè)置PCD定時器
- //input:fwi=0~15
- void pcd_set_tmo(u8 fwi)
- write_reg(TPrescalerReg, (TP_FWT_302us) & 0xFF);
- write_reg(TModeReg, BIT7 | (((TP_FWT_302us)>>8) & 0xFF));
- write_reg(TReloadRegL, (1 << fwi) & 0xFF);
- write_reg(TReloadRegH, ((1 << fwi) & 0xFF00) >> 8);
- void pcd_delay_sfgi(u8 sfgi)
- //SFGT = (SFGT+dSFGT) = [(256 x 16/fc) x 2^SFGI] + [384/fc x 2^SFGI]
- //dSFGT = 384 x 2^FWI / fc
- write_reg(TPrescalerReg, (TP_FWT_302us + TP_dFWT) & 0xFF);
- write_reg(TModeReg, BIT7 | (((TP_FWT_302us + TP_dFWT)>>8) & 0xFF));
- if (sfgi > 14 || sfgi < 1)
- {//FDTA,PCD,MIN = 6078 * 1 / fc
- sfgi = 1;
- write_reg(TReloadRegL, (1 << sfgi) & 0xFF);
- write_reg(TReloadRegH, ((1 << sfgi) >> 8) & 0xFF);
- write_reg(ComIrqReg, 0x7F);//清除中斷
- write_reg(ComIEnReg, BIT0);
- clear_bit_mask(TModeReg,BIT7);// clear TAuto
- set_bit_mask(ControlReg,BIT6);// set TStartNow
- while(!INT_PIN);// wait new INT
- //set_bit_mask(TModeReg,BIT7);// recover TAuto
- pcd_set_tmo(g_pcd_module_info.ui_fwi); //recover timeout set
- void pcd_lpcd_config_start(u8 delta, u32 t_inactivity_ms, u8 skip_times, t_detect_us)
- u8 XDATA WUPeriod;
- u8 XDATA SwingsCnt;
- #if (NFC_DEBUG)
- printf("pcd_lpcd_config_start\n");
- #endif
- WUPeriod = t_inactivity_ms * 32.768 / 256 + 0.5;
- SwingsCnt = t_detect_us * 27.12 / 2 / 16 + 0.5;
- write_reg(0x01,0x0F); //先復(fù)位寄存器再進行l(wèi)pcd
- write_reg(0x14, 0x8B); // Tx2CW = 1 ,continue載波發(fā)射打開
- write_reg(0x37, 0x00);//恢復(fù)版本號
- write_reg(0x37, 0x5e); // 打開私有寄存器保護開關(guān)
- write_reg(0x3c, 0x30 | delta); //設(shè)置Delta[3:0]的值, 開啟32k
- write_reg(0x3d, WUPeriod); //設(shè)置休眠時間
- write_reg(0x3e, 0x80 | ((skip_times & 0x07) << 4) | (SwingsCnt & 0x0F)); //開啟LPCD_en設(shè)置,跳過探測次數(shù),探測時間
- write_reg(0x37, 0x00); // 關(guān)閉私有寄存器保護開關(guān)
- write_reg(0x03, 0x20); //打開卡探測中斷使能
- write_reg(0x01, 0x10); //PCD soft powerdown
- //具體應(yīng)用相關(guān),本示例工程配置為高電平為有中斷
- clear_bit_mask(0x02, BIT7);
- lpcd功能開始函數(shù)
- void pcd_lpcd_start()
- #if (NFC_DEBUG)
- printf("pcd_lpcd_start\n");
- #endif
- if (read_reg(0x37) == 0x10)
- write_reg(0x01, 0x00); // idle
- //write_reg(0x3c, 0x30); //設(shè)置Delta[3:0]的值, 開啟32k //0 不能使用
- //write_reg(0x3c, 0x31); //設(shè)置Delta[3:0]的值, 開啟32k
- //write_reg(0x3c, 0x32); //設(shè)置Delta[3:0]的值, 開啟32k
- //write_reg(0x3c, 0x33); //設(shè)置Delta[3:0]的值, 開啟32k
- //write_reg(0x3c, 0x34); //設(shè)置Delta[3:0]的值, 開啟32k
- //write_reg(0x3c, 0x35); //設(shè)置Delta[3:0]的值, 開啟32k XU
- write_reg(0x3c, 0x37); //設(shè)置Delta[3:0]的值, 開啟32k XU
- //write_reg(0x3c, 0x3A); //設(shè)置Delta[3:0]的值, 開啟32k XU
- //write_reg(0x3c, 0x3F); //設(shè)置Delta[3:0]的值, 開啟32k XU
- write_reg(0x3d, 0x0d); //設(shè)置休眠時間
- write_reg(0x3e, 0x95); //設(shè)置連續(xù)探測次數(shù),開啟LPCD_en
- //具體應(yīng)用相關(guān),配置為高電平為有中斷
- void pcd_lpcd_end()
- #if (NFC_DEBUG)
- printf("pcd_lpcd_end\n");
- #endif
- u8 pcd_lpcd_check()
- if (INT_PIN && (read_reg(DivIrqReg) & BIT5)) //TagDetIrq
- write_reg(DivIrqReg, BIT5); //清除卡檢測到中斷
- pcd_lpcd_end();
- return TRUE;
- return FALSE;
- #if 0
- void page45_lock()
- write_reg(VersionReg, 0);
- //打開芯片的page4私有寄存器的寫保護
- void page4_unlock()
- write_reg(VersionReg, 0x5E);
- //打開芯片的page5私有寄存器的寫保護
- void page5_unlock();
- write_reg(VersionReg, 0xAE);
- #endif
- void pcd_set_rate(u8 rate)
- u8 val,rxwait;
- switch(rate)
- case '1':
- clear_bit_mask(TxModeReg, BIT4 | BIT5 | BIT6);
- clear_bit_mask(RxModeReg, BIT4 | BIT5 | BIT6);
- write_reg(ModWidthReg, 0x26);//Miller Pulse Length
- break;
- case '2':
- set_bit_mask(TxModeReg, BIT4);
- set_bit_mask(RxModeReg, BIT4);
- write_reg(ModWidthReg, 0x12);//Miller Pulse Length
- //rxwait相對于106基本速率需增加相應(yīng)倍數(shù)
- val = read_reg(RxSelReg);
- rxwait = ((val & 0x3F)*2);
- if (rxwait > 0x3F)
- rxwait = 0x3F;
- write_reg(RxSelReg,(rxwait | (val & 0xC0)));
- break;
- case '4':
- set_bit_mask(TxModeReg, BIT5);
- set_bit_mask(RxModeReg, BIT5);
- write_reg(ModWidthReg, 0x0A);//Miller Pulse Length
- rxwait = ((val & 0x3F)*4);
- rxwait = 0x3F;
- break;
- default:
- break;
- {//不同速率選擇不同帶寬
- u8 adc;
- if (adc == 0x12)
- if (rate == '8' || rate == '4')//848k,424k
- write_reg(0x3B, 0x25);
- else if (rate == '2' || rate == '1')// 212k, 106k
- write_reg(0x3B, 0xE5);
- #if 0
- void calculate_crc(u8 *pin, u8 len, u8 *pout)
- u8 XDATA i, n;
- clear_bit_mask(DivIrqReg, 0x04);
- set_bit_mask(FIFOLevelReg, 0x80);
- for (i = 0; i < len; i++)
- write_reg(FIFODataReg, *(pin + i));
- write_reg(CommandReg, PCD_CALCCRC);
- i = 0xFF;
- do
- n = read_reg(DivIrqReg);
- i--;
- }while((i!=0) && !(n&0x04));
- #if (NFC_DEBUG)
N12_SDK_STC_V1.9.0-MH523.zip
(202.2 KB, 下載次數(shù): 30)
2018-9-20 09:51 上傳
下載積分: 黑幣 -5
